Hallmark007
Flight distance : 12400594 ft
You’re correct manual wheel only reaches 2” max, and if you need longer SS you need to use the onscreen slide. As labroids Said this is basically tech added to simulate longer exposures and not the electronic shutter which you’re controlling through the wheel. I think the 2.5”, 3.2” , 4”, 5” & 8” are marked by hyphen or lines.
However in reasonable weather and night time they work really well. Maybe it cannot go on to the wheel that connects to the actual electronic shutter setting. |
