Hey everyone,
I’m posting here because DJI Support has been unable to provide a clear explanation for my drone’s crash, and I’d love to hear insights from the community.
I overlayed my stick inputs with the drone fly-away footage and provided the logs from AirData here: https://www.dropbox.com/scl/fo/cgj6y37pdg0rljoo35pap/AH0d9Vz-nVFOwTSQ5cy2wPE?rlkey=xk9s5jfwxumdgthejrhvywdn8&st=t9kj4h1x&dl=0
Flight conditions
I was flying my DJI Air 2S over open water with weak satellite positioning and in sport mode. About 1 minute and 10 seconds into the flight, my drone unexpectedly lost about 40 feet of altitude and crashed into the ocean rapidly, completely ignoring my manual throttle-up input through the whole descent. • No obstacles were present, I was flying 40ish feet above open water. • I did NOT let go of the sticks or descend intentionally - the drone simply ignored my throttle-up command and dropped into the ocean. • The DJI flight logs indicate weak GPS throughout the flight, but signal strength was strong (100% uplink/downlink) meaning my throttle up command should have worked and avoided a crash. I have no problem flying the drone manually and have flown in ATTI mode before with no issues. • DJI’s support response blames weak GPS/ATTI mode, but the manual only describes ATTI mode causing horizontal drifting, not altitude loss: “The aircraft automatically changes to Attitude mode when Vision systems are unavailable or disabled and when the GNSS signal is weak or the compass experiences interference. In ATTI mode, the aircraft may be more easily affected by its surroundings. Environmental factors, such as wind, can result in horizontal shifting, which may present hazards, especially when flying in confined spaces.”
Questions: 1. Should a drone in ATTI mode / Sport Mode lose altitude uncontrollably? The manual states that ATTI mode results in drifting due to wind but does not mention loss of altitude. The footage suggests an abnormal lurch, with the propeller entering the field of view, as if the drone lost stability mid-flight and then promptly flys in reverse and descending while I input forward and throttle up. 2. Does Sport Mode impact altitude control? I understand that Sport Mode disables obstacle avoidance and increases braking distance, but does it have any effect on altitude hold? If so, where is this documented? 3. Has anyone else experienced a similar incident? If this is something that can happen without warning, pilots need to be aware of it, as it is not addressed in the manual. 4. In the case of sport mode / weak GPS, is the drone unable to balance itself?
Any insights, explanations, or similar experiences would be greatly appreciated!
Thanks in advance.
