Advocate
Flight distance : 1076909 ft
Geebax - I agree, but that isn't obvious to someone looking to buy their first Quad, as I was. It was only because (for the first time in my life) I spent AGES reading about them that I happened to stumble across an honest post on a website detailing all the problems that 3DR was having that made me think twice about 3DR. But then when I bought my P4 and started using it I realised that " Hang on! 3DR says no-one else can do MPCC but this waypoint feature is EXACTLY the same as MPCC" etc etc. Basically only by buying DJI did I find out that they not only match 3DR features but they also surpass them in other ways.
Labroides - Your first sentence is exactly what I'm talking about. DJI's marketing dept need to reply and show that not only does the Phantom series (I was going to say P4 but the P3 also does) match the Solo, it beats it!
Amatthews - the Phantom series can ALREADY DO MPCC. If you've watched the tutorials for 3DR Solo as I have you'd realise that to set up their "Cable Cam" and now "Multi Point Cable Cam" is exactly the same way you set up waypoints in the DJI Go! app. Fly the P4 to point 1, point the cam where you'd like it to point when flying, press C1. Then repeat for further waypoints and points of interest, when you've finished setting them all up return to WP1 and press go. The P4 will then fly the mission as you planned it, and with the right option selected will point the camera in the same direction you had it when setting up the waypoints, and smoothly transition between them as it flies. That IS Multi Point Cable Cam! |
