christian.melch
Hi there,
we are using our OSMO since we bought a couple of month ago, but only recently we've started to encountering this issue :
once we've just replaced the battery with a fully charged one, sometimes OSMO starts with a solid red led on left, and a blinking red led on right; gimbal try to do the normal startup movement but it early stops to move, and right solid red led stay up.
we have 3 original batteries, 2 bought a few weeks after the OSMO
we've encountered the same problem even using X5R coming from our Inspire 1 raw
this is our current OSMO's situation :
20160904 X3 - FW : 1.6.2.10
20160904 X5R - FW : 1.3.0.40
Battery 1 (coming in bandle with osmo):
Label 1011101537010477
SW SN : 1724 (12/10/2015)
Battery 2:
Label 1011101545087727
SW SN : 212 (04/12/2015)
Battery 3:
Label 101101551005399
SW SN : 14235 (02/07/2016)
The temporary workaround I've found when it happens is :
Switch quickly the power button when OSMO is booting with error (like to put it in standby mode)
Once in standby mode, remove the battery and insert again
Switch on, and most of the time it works...
but it's happening very often...
Is there someone who ever noticed something like this?
Do you have some solution?
Thank you
Christian
