sd card will this work
1746 14 2017-10-13
fansebeed138
will this sd card work for osmo+  https://www.amazon.com/dp/B00U77 ... colid=2M642DSE6DKFD
thanks
2017-10-13
DJI Elektra
Please note that the maximum capacity of SD card of OSMO is 64GB. I would recommend you use SD card of Class 10/ UHS-1 or more.  Here is the recommended SD card:
1.Lexar 633X Class10 16 GB MicroSDHC UHS-l
2.Panasonic 16 GB MicroSDHC UHS-3
3.Sandisk Extreme 16 GB MicroSDHC UHS-3
2017-10-13
TheAmericanSant
DJI Elektra Posted at 2017-10-13 19:29
This is the second card I buy, $100 later still not working. I have dij phantom 3 SE and scan disk extreme plus 32 gb. Drone reads card but then after 2 seconds of video record it can’t find card? Can you help?
2017-10-20
DJI-Jamie
Flight distance : 112405 ft
TheAmericanSant Posted at 2017-10-20 15:33
Have you already tried reformatting the SD card via the Go app?
2017-10-20
Felipe Olvera
Flight distance : 94849 ft
These are good guide lines... I'd suggest getting a SD card between 32gb-64gb for 4k recording. I have a 32gb extreme sandisk micro sd
2017-10-20
Felipe Olvera
2017-10-20
fansebeed138
I don't understand fully they say UHS 1 or better, and the link provided is better in all aspects not just in capacity but in read/write speed again in all aspects a better drive  Lexar Professional 1000x microSDXC 128GB UHS-II/U3. Why is this not recommended to use?
2017-10-21
SCT
I have been using SanDisk 128GB Extreme PRO microSDHC 275Mb/s without problem but it's not reconmended by DJI but it work and suites my application
2017-10-23
Floyd-Spark
Flight distance : 52644 ft
Why is 64GB the max capacity? Why cant bigger capacity cards be used? I have heard they do but why do DJI state no more than 64GB?
2017-10-24
Floyd-Spark Posted at 2017-10-24 23:03
The compatibility of 128G SD Card cannot be guaranteed, please use the SD in our compatible list, thanks for your understanding.
2017-10-28
Floyd-Spark
Where can I find the SD compatibility list? I am using Sandisk 64GB Extreme. These are designed for 4k use.
2017-10-29
Floyd-Spark Posted at 2017-10-29 16:44
The Osmo supports up to 64GB Micro SD cards.The speed should be Class 10 or higher, or UHS-1.
Following SD cards are shown as below:
Lexar 633X Class10 16 GB MicroSDHC UHS-I SD Card
Panasonic 16 GB MicroSDHC UHS-3 SD Card
Sandisk Extreme 16 GB MicroSDHC UHS-3 SD Card
Lexar 633X Class10 16 GB MicoSDHC UHS-I SD card;
Panasonic 16 GB MicroSDHC UHS-3 SD card;
Sandisk Extreme 16 GB MicroSDHC UHS-3 SD card;
2017-10-29
Afro_Ghost
Flight distance : 36447 ft
Mexico
It's not the price, it's the bus capacity that matters in here. The cards must be at least UHS-I (it supposes a 45MBps bus), the manufacturers print on their cards that them opperate at 90MB, but there's a huge difference bewteen Write/Read bus. If you analyze some of those cards, the bus to Write data will be ~15Mbps, while the Read speed would be 45Mbps (in the case of UHS-I and the manufacturer) - See: bits, not Bytes.
2017-10-29
Floyd-Spark
My Sandisk Extreme 64GB UHS1 is not on the list. Should I be concerned?
2017-10-30
Floyd-Spark Posted at 2017-10-30 21:49
As long as the the write speed is faster than 60Mbps and grade higher than Class 10. (Take note of the write speed. Currently, most SD cards notifies only average/maximum write speed or read speed).
Even though the SD card meets the standard, we cannot guarantee its own manufacture quality, thanks for your understanding.
2017-10-30
