bobwaz44\
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Aardvark Posted at 2017-10-13 12:07
You mentioned C1, C2 & Record to initiate Link, was it as below :-
* Turn on both the aircraft and the controller, wait 30 seconds for aircraft to initialise.
Aardvark, thanks for the help. Turns out the light on my remote control was not red....it was actually a pink/purple color. I tried the solution you provided multiple times, but that did not fix the problem. I eventually found a post where someone mentioned holding down C1, C2 and the SHUTTER button (not the record button). While holding all three buttons down, turn off power to the remote control. Then, while still holding all three buttons, turn on the remote control again. This solved the problem for me. I was able to connect to the aircraft as expected. Once that worked, I was able to upgrade the aircraft to the latest BETA firmware. Did a 15 minute test flight, including using tripod mode. No issues with stability. No issues with camera recording at 4K. No gimbal issues. At least for me, DJI is finally getting close to a useable fix! |
