DJI Go 4 lagging like hell on iPad Mini 4 - iOS 11.0.3
5409 40 2017-10-19
ro_flyer
Flight distance : 7557283 ft
Used to be fine, but now DJI Go4 is unusable due to video lagging...
None of the reccomended actions solved the issue:
- is a dedicated device (only DJI Go 4 installed)
- turned off video cache recording on app
- airplane mode when flying the drone
- magnetic side of iPad away from the controller when mounted
- tuned off background tasks in iOS
- using last version iOS / app / MP firmware
- factory reset iPad
- reinstall app
Anyone have something new I could try? I'm using Litchi and everything runs smoothly...
2017-10-19
RichJ53
Flight distance : 1837356 ft
I don't use the iPad mini 4 with my Mavic Pro but I used it 2 days ago with my Inspire 2 using the latest Go 4 App and iOS 11.03. The video was working normally for me. Only flew about 5000 feet away at any one time. But I run the HD video streaming in manual mode on the Inspire 2 picking a clear channel on 2.4G.  The Mavic works a bit differently and I keep in automatic mode using my iPhone 8+
Maybe you can go to the general settings page by tapping on the three dots upper right. go down to video cache, then  clear cache from your device. This will take a lot of space and could help you out.  I keep my cache at 8G but my iPad has 128G storage
Rich
2017-10-19
ro_flyer
RichJ53 Posted at 2017-10-19 21:16
Thanks for the suggestions but I already cleared and turned off the video cache...  Can you give some more advice on how to optimise the HD video streaming?
2017-10-19
alex_markov
Flight distance : 39878160 ft
Bulgaria
just checking, did you by any chance run screen recording?
I use iPad mini 4 with iOS 11.02 and DJI GO 4 (not latest, as I forbid automatic updates) and have only barely visible lag, till I run screen recording than the hell got loose - lag, tears ... see for Yourself
So I never use this wonderful feature
2017-10-19
RichJ53
ro_flyer Posted at 2017-10-19 21:37
ro-flyer,
To be honest, I have not needed to try custom (manual) mode on my Mavic using OcuSync transmission. But you can try this yourself by switching to manual mode and look for a clear channel. I will look at this myself and experiment with the settings to see if I can help you.
Rich
2017-10-19
ro_flyer
RichJ53 Posted at 2017-10-19 22:15
ro-flyer,
Thank you so much, I'll give it a try too.
2017-10-20
randy.sauder
Flight distance : 872572 ft
ro_flyer Posted at 2017-10-20 18:49
Did you happen to just update Go4 to latest version and have the stutter happen?  I updated from 4.1.5 and immediately have tremendous lag...that's the only that changed with my setup; perfect beforehand.
2017-10-20
ro_flyer
randy.sauder Posted at 2017-10-20 20:25
Yes, I had some minor lag situatons before maybe due to interference... but now with this last version Go4 app went crappy... just impossible to use it....
2017-10-20
fansc0fb4145
Flight distance : 521627 ft
For me
- clearing the cache in the app,
- reinstalling the app and
- most importantly making sure there was enough space on my ipad mini 2
solved the issue.
Although it is still on ios 10 , no crashing, buttery smooth video feed, all the new functions available.
2017-10-21
M K ULTRA
Flight distance : 5778337 ft
alex_markov Posted at 2017-10-19 21:45
I use iPad mini 4 with iOS 11.02 and DJI GO 4 (not latest, as I forbid automatic updates) and have only barely visible lag, till I run screen recording than the hell got loose  - lag, tears ... see for Yourselfhttps://youtu.be/Qn9V8W8UeRM
I did.  The first time I tried it, the app disconnected and I had to do a RTH via the remote.  A second attempt worked fine.  I did not experience any noticeable choppy video. I believe I was on IOS 11.03 at the time.
2017-10-21
Adam9997
Flight distance : 2619491 ft
I'm using a dedicated Ipad 4 mini with 11.0.3 and experienced no issues. Perhaps check your cable?
2017-10-21
How long will the lagging continue? Could you upload a short video for better assistance?
2017-10-22
MAVICDLNM
Flight distance : 10696686 ft
I heard from DJI store that the delay caused by IOS11
2017-10-22
Håkan K
Flight distance : 262946 ft
I'm on 4.1.9 and iOS 10 mini2 without issues. It appears something happened in the later GO4 app upgrades and maybe a combination with iOS11 causing these issues.
2017-10-22
ro_flyer
DJI Susan Posted at 2017-10-22 22:50
Since the lagging started I deactivated the video cache, so I don't have any videos to upload, but I'll fly the bird later and I will post here. Tks
2017-10-23
ro_flyer
MAVICDLNM Posted at 2017-10-22 23:08
I hope they fix it soon.....
2017-10-23
Joepub1
Flight distance : 557818 ft
Adam9997 Posted at 2017-10-21 09:15
Same for me, using either port. I don't screen record, Mini 4 is a clean machine, I don't even have google maps installed.
2017-10-23
WolfgangStiller
Flight distance : 599416 ft
I am on 11.0.2 and just flew with lastest firmware and DJI Go and didn't notice any lag on my Mini 4. Guessing this must be due to 11.0.3.  I guess I'll hold off on the update.  How much memory do you have on your Mini 4?  The new IOS could be more of a memory hog or just doesn't manage it as well for a performance sensitive app like DJI Go.  Mine has 128gb and works great so far (on 11.0.2 that is)
2017-10-23
Eagle_Eye
Flight distance : 4137720 ft
You're lucky.....mine won't even connect to the RC.
2017-10-23
Adam9997
Joepub1 Posted at 2017-10-23 06:21
Perhaps that's key. I also don't screen record. Next time I'll try and sse if that's the issue
2017-10-23
ro_flyer
Thanks for all suggestions, neither of them seems to solve the issue though.... Moving to Litchi and waiting for an update that solves the problem....
2017-10-23
MAVICDLNM
WolfgangStiller Posted at 2017-10-23 06:35
Ipad capacity size and memory are completely different topic.  128G size won’t boost your iPad mini speed up.
We are having issue mainly with iPhone 7 and 7plus after upgrade to ISO11.0x and DJI confirmed that is an OS issue.
2017-10-23
MAVICDLNM
ro_flyer Posted at 2017-10-23 17:30
Yes!  Guess I go to give Litchi a try out, as I haven’t use my Litchi after sold my P4.
2017-10-23
DRONE-flies-YOU
Flight distance : 1638323 ft
ro_flyer Posted at 2017-10-23 04:05
Well they've got a lot of us beta testing this software, so yea... Hopefully soon.
This GO 4 ruins an otherwise awesome experience. The Mavic is so sophisticated & then it's paired with that... Doesn't make sense.
2017-10-23
ro_flyer
DRONE-flies-YOU Posted at 2017-10-23 20:08
What surprises me is that we don't have a single word from DJI regarding this....
2017-10-24
WolfgangStiller
ro_flyer Posted at 2017-10-24 05:14
Me too. It would be great to have an official warning relative to IOS 11.0.3. I am holding off upgrading my mini 4 for that reason. I do have 11.0.3 on the iPhone 7 and it seems to work fine with the latest DJI Go4.
2017-10-24
TroutboyNZ
Flight distance : 1726486 ft
I upgraded to iOS 11.0.3 on the iPhone 7 with the Mavic on 0000 and the latest Go4 app and it's bee flawless, no issues at all even when screen recording a 22min flight and caching at the same time, very smooth and went out to 4km with full signal all round, impressed. Bizzare some are having issues, especially on the Mini4 which I always throught was the "flagship" device, I liked mine, but sold it as the ergonomics were a bit big, still the screen, wow.
2017-10-24
Keule
Flight distance : 3733015 ft
Today (Oct 25, 2017)  a new version of GO4 appeared: 4.1.14 - Maybe DJI improved the connectivity issues with the latest IOS versions (As usual, nothing is mentioned in the description of the new version)
2017-10-24
ro_flyer
Keule Posted at 2017-10-24 22:46
Let's give it a try....
to be continued....
2017-10-25
ro_flyer Posted at 2017-10-23 04:04
Noted with thanks! I'll wait for your update.
2017-10-25
DIott3113
Flight distance : 1797516 ft
DJI Susan Posted at 2017-10-25 02:14
Hmm - I'm on 4.1.12 I checked for updates via the DJI GO app, Assistant 2 and the itunes app store and none indicate that an update to GO is available....what am i missing / doing wrong?
2017-10-25
Keule
DIott3113 Posted at 2017-10-25 06:59
Maybe DJI is releasing the update depending on the region you are in ... So keep looking in the App Store.
2017-10-25
DIott3113
Keule Posted at 2017-10-25 07:22
Thanks.. will do!
2017-10-25
Håkan K
Popped up here now (EU, Sweden)
2017-10-25
ro_flyer
Installed new Go 4 version... despite there are no mentioned improvings for the Mavic...  I will make a test flight this afternoon...
2017-10-25
Locoman
Flight distance : 748675 ft
I updated the GO4 4.1.14 on my Mini4 today and flew, no problems at all. Don't know what was updated to the app. The only thing I had to do was celibate the compass, which for me is normal for almost every flight. Also i am runnig most current FW, iOS (not Beta), GeoFence software.
2017-10-25
ro_flyer
Locoman Posted at 2017-10-25 17:24
Did you have lagging problems in the previous version?
2017-10-25
Locoman
ro_flyer Posted at 2017-10-25 22:53
Not that I am aware of, not 100% sure what you mean, by lagging problems though
2017-10-27
The latest APP was released in phases. It will pop up soon, please check later.
2017-10-27
ro_flyer
Locoman Posted at 2017-10-27 01:33
Video feed back freezing
2017-10-27
