8331 Props caused gimbal shake
123Next >
8804 81 2017-10-25
M.C. Pilot
Flight distance : 10278435 ft
Wondering if others had the same issue? Installed the newer 8331 props on the MP but noticed the gimbal shaking uncontrollable (sort of up and down movement) when airborne a few flights ago. It then was followed by a warning that stated, 'Abnormal Gimbal'. I quickly descended and rebooted and it went away. Same issue came back on a few occasions.
Decided to switch back to original props, and what do you know? It completely was gone. No more shaking or abnormal gimbal warnings.
Since swapping the props, I used up a total of 8 batteries and gimbal shake was gone. By the way, I have the latest MP FW.
Weird right? have you guys noticed anything out of the ordinary?
2017-10-25
DroneFlying
Flight distance : 10774613 ft
What firmware version are you using? More specifically, did you upgrade to the latest version that DJI recommends using with the new propellers?
2017-10-25
M.C. Pilot
DroneFlying Posted at 2017-10-25 17:25
Yes I did that's why I was perplexed. I'm convinced that I'll stick with the original ones, call me old fashion
2017-10-25
M.C. Pilot
Oh wait maybe I'll refresh the FW ? on DJI - A2?
2017-10-25
DroneFlying
M.C. Pilot Posted at 2017-10-25 17:33
That's worth a shot. Yes, I'd recommend using Assistant 2 for the upgrade / refresh.
2017-10-25
Airbus350XWB
Flight distance : 705768 ft
Indonesia
mine was fine all the way using MPP props.. you can try calibrate everything to make sure the issues wont return. because i had the same issue when i'm in old firmware, resulting gimbal shake uncontrollable.. lucky i managed to land..
2017-10-25
M.C. Pilot
Yeah thinking maybe the prior FW didn't take.
2017-10-25
RichJ53
Flight distance : 1837356 ft
M.C. Pilot Posted at 2017-10-25 17:32
My new props work great, no shake or anything ... they just work.  So you probably got a pair that is out of balance.
I purchased some third party Red Spark props and they were terribly out of balance. The vibration was awful, so they were returned back using Amazon.
So, get some new props and move on my friend
Rich
2017-10-25
Just to verify, what is the version of your drone now? Please update to the latest v01.04.0000 and check if the issue appears again.
2017-10-25
Mountaindrone
Flight distance : 27735479 ft
my news props works perfectly
2017-10-25
dancopter
Flight distance : 17901030 ft
United Arab Emirates
I got the 'abnormal gimbal vibration' alarm too with the new props. I couldn't visibly see any difference on the screen though and I was descending at 3m/s and doing a turn at the same time, but not in sport mode.
Went away once I leveled out. Never saw it on my old props though and first time I have seen the alarm.
2017-10-25
Eagle_Eye
Flight distance : 4137720 ft
I got @ least 10 full batt flight w/ FW 400 and new LNP, everything's GOOD!
2017-10-26
R&L Aerial
Flight distance : 298100 ft
The only thing it could be is defective, out of balance props...
2017-10-26
M.C. Pilot
DJI Thor Posted at 2017-10-25 21:20
Yes, I have the most current FW on the Mavic.  I'll refresh again to see if that works if not then I'll stick with the original props. Like them too.
2017-10-26
M.C. Pilot
R&L Aerial  Posted at 2017-10-26 04:04
Possibly. I purchased these from the DJI website...
2017-10-26
M.C. Pilot
RichJ53 Posted at 2017-10-25 20:21
Picked these up from the DJI website. I although I did see these 8331 props on Amazon, I wouldn't even take a chance b/c of the phony props out there.
2017-10-26
R&L Aerial
M.C. Pilot Posted at 2017-10-26 05:11
Picked these up from the DJI website. I although I did these 8331 props on Amazon, I wouldn't even take a chance b/c of the phony props out there.
I’ve got a couple of pairs of the 8331 props coming from some shady dealer in the land of China, I ordered them a month ago. Still haven’t shipped but if I ever get them I hope they work on .700 because I’m never updating....
2017-10-26
M.C. Pilot
Just refreshed the FW on the MP but for now sticking with the original props !
2017-10-26
M.C. Pilot Posted at 2017-10-26 16:19
So it doesn't work when refreshing the firmware, right? Just to verify, are there any broken parts on the props or something? If it is possible, would you mind providing me with a short video which contains this case, please calibrate the IMU and compass before the test. I would like to check. Any help is highly appreciated.
2017-10-27
$gambino$
Flight distance : 1563980 ft
I notice alot of people having issues with the low noise props. Personally I think it's due to vibrations with the props not being properly balanced because I have read a few threads where people were getting blinking yellow light fast means imu vibrations. I have even seen it one time on mine so I'm wondering if the vibrations are causing your gimbal to act all crazy. On top of that a lot of these props are coming to the end user a little bent on the Leading Edge
2017-10-27
$gambino$
Im with R&L Aerial on this one for sure. Especially if you can go back to the old props and everything's peachy
2017-10-27
M.C. Pilot
No thanks to those newer MPP props....Since I flown 8 batteries and the (abnormal shaking uncontrollable gimbal) [/b ] issue never came up again...well....no need to go any further, I'm sticking to the older version. As the old saying goes, 'if it ain't broke, don't fix it'...
2017-10-27
RobbinB
Flight distance : 59839 ft
Im getting horizontal lines in video when on full throttle with the 8331. I checked balance and found 1 propeller a little off, will test again tomorrow and see if the lines are still there.
No lines with original props
2017-10-30
RobbinB
RobbinB Posted at 2017-10-30 13:07
Here is a video from the cached data.
In the original video you also see small, small lines.
In this low res video you only see the mayor ones.
2017-10-30
eyecapture
Flight distance : 517848 ft
That's PROP SHADOW. You will get that with any prop. It's  normal when you face the sun.
2017-10-30
M.C. Pilot
^^^ yeah it does seem that way...
2017-10-30
FlyingFish82
Flight distance : 3937539 ft
like they mentioned before, it is prop shadows when flying towards or sideways from the sun, ND/PL filters help correcting it .
Cheers
2017-10-30
RobbinB
thanks guys.
Thumbs up
2017-10-30
SnEEkEE
Flight distance : 817159 ft
Sorry, a bit late to the party here, but I have a similar issue with the 8331 props. I've had this sent in to our local DJI repair center and the props tested fine with their inhouse Mavic Pro. They had my unit in for 3 weeks and finally determined it had to go back to DJI in China for analysis. Needless to say, i'm pushing for a replacement as it's barely two months old.
2017-11-1
M.C. Pilot
SnEEkEE Posted at 2017-11-1 13:31
https://www.youtube.com/watch?v=AXxTkJYly7M
That's exactly how mine reacted once I installed the 8331 props so I took them off and threw them in the trash.
Reinstalled the original props and all is back to normal.
2017-11-1
DT Hai
Flight distance : 325600 ft
Vietnam
M.C. Pilot Posted at 2017-11-1 14:04
Me too. It shake and never give me the peace of mind
2017-11-1
CalvinC
Flight distance : 1267831 ft
There must be some bad batches of the new props out there.  I checked the ones that I've received and they are very well balanced.
2017-11-1
RobbinB
CalvinC Posted at 2017-11-1 18:09
i bought 3 pairs of 8331 and 1 propeller was quite bad balanced. so i threw that one away.
i could not see any vibration on the gimbal, but in my video i posted here i saw some lines that i thought was due to vibration. but it wasnt.
so all is working fine here, im on latest FW.
2017-11-1
SnEEkEE
Here's a slightly better video I took tonight:
Yes, I could just ditch the props, but:
A. They seem to work okay with other Mavic's, so why not mine?
B. I love (LOVE) the quieter props as I can launch it from my backyard without bothering anyone.
2017-11-2
M.C. Pilot
I doubled check the props and they seemed balanced with no flaws. Yeah I don't get why the MP would still shake.
2017-11-2
QuadKid
Flight distance : 482349 ft
M.C. Pilot Posted at 2017-11-2 04:01
When you say you "Checked the Balance" of the props, was that while they are mounted to the MP?
I purchased a balance rod for checking my props for the P3P which consists of a perfectly balanced 4mm steel rod and a roll platform, but cannot use it for any quick mount props IE: MP & P4P. Do they make a balance device for balancing Quick Mount Foldable Props?
2017-11-2
M.C. Pilot
QuadKid Posted at 2017-11-2 04:56
"When you say you "Checked the Balance" of the props, was that while they are mounted to the MP?"
Yes. Off and on the MP. Looked for any marks, bending of the props or any other indentations that would cause a potential problem but didn't find anything. I didn't have any special tools although it wouldn't be a bad idea to have one.
2017-11-2
QuadKid
M.C. Pilot Posted at 2017-11-2 05:01
Thanks, I haven't had any issue with the 1st set of 8331's just got a 2nd set yesterday will keep my fingers crossed they are OK as well.
2017-11-2
Bucefalo
Flight distance : 444944 ft
SnEEkEE Posted at 2017-11-2 02:01
https://www.youtube.com/watch?v=3qeaj4fzB-4
holy sh**it.. did you call an exorcist ?  :-P
uhmmm i was so tempted to buy new props... but that looks bad !
2017-11-3
M.C. Pilot
Bucefalo Posted at 2017-11-3 01:26
agree, really in my opinion not even worth it. Rather just purchase an MPP use them with the newer ESUs'
2017-11-3
123Next >
