dji phantom 3 pro beeping after crash and repair
5897 14 2017-11-7
fans88ff7e61
Ukraine
Hi, I have a problem with my drone. After crash I repaired gimbal and flexible cable, but now drone does not turn on. It make strange beep sound. Any suggestion? I add video with it in first comment.
2017-11-7
fans88ff7e61
Ukraine
2017-11-7
edifier
should have a green rc link led showing
try relinking the controller to the drone again
2017-11-7
fans88ff7e61
Ukraine
edifier Posted at 2017-11-7 05:26
Thank you, I just do it, now it green, but beeping the same
2017-11-7
edifier
ok try reformatting the sd card then try again the led on the gimbol should be a solid green if all is ok
2017-11-7
fans88ff7e61
Ukraine
edifier Posted at 2017-11-7 06:06
Led on the gimbal is solid green, but it still beeping the same way. There is no sd card inside the drone. But it should turn on normally, even without sd card.
2017-11-7
edifier
ok
try reformatting the sd card in the gimbol the green led on the gimbol should stay solid green if all is ok
also make sure the ribbon lead you fitted has all the connection made firmly
2017-11-7
edifier
have you tried also a recalibration of the gimbol etc
2017-11-7
RicardoGray
Flight distance : 4356421 ft
Couldn't see what the LED's are flashing on the aircraft. Are they green or yellow, red?????
RC led should be green if you are connected to the aircraft. If not a re-link is needed. If camera LED is green it should be good to go.
What did you do inside the phantom? Gimbal ribbon repair doesn't required taking the top off? Just asking. A little more info might help all of us in helping you.
2017-11-7
fans88ff7e61
Ukraine
edifier Posted at 2017-11-7 06:15
There is "no image transmission signal error" on laptop screen. Card formatting doesn't help.
2017-11-7
fans88ff7e61
Ukraine
RicardoGray Posted at 2017-11-7 06:58
Part of the main board was broken, but i fixed it. Led lights does not flash at all. Led light on gimbal blinkin red. Problem with gimbal?
2017-11-7
RicardoGray
fans88ff7e61 Posted at 2017-11-7 07:07
That looks a bit more than I am familiar with. That piece that broke off is the IMU I believe. You say you fixed it, but did you feel you got it properly back on the board? Just asking. You should have some response from your aircraft LED lights I would think. The no image transmission is because it is not connecting to your RC I would imagine. And maybe it cannot because of some transmission issue with the aircraft. Sorry, but after seeing your picture, it is over my head at this point. I may be wrong but I would suspect your problem may be with the IMU. Maybe someone else with more knowledge could jump in here. Sorry for your mishap. You may be faced with sending the aircraft in.
2017-11-7
edifier
I agree even with a fix i would not trust flying it until dji take a look at it
that's an important bit of the kit
2017-11-7
The aircraft performance can not be ensured after crash. In order to get a working drone, please consider to send it in for fully diagnosis and repair: http://www.dji.com/support
2017-11-7
fansf68a87c6
Hi may I know does any have the answer ? End up what’s the result and solution ?
I’m facing this problem now ... my drone board was fine but I Change the gimbal flex and the result turn out just like the video it show .. please help
2019-12-29
