Phantom 3 standard shaking - please help
5040 19 2017-11-17
ICEBERG03
Hello guys,
I just purchased new P3 standard.
Firmware is up to date. I did calibrate IMU. I did calibrate compass. I did try second set of propellers.
But once I take off, drone shakes/vibrates like crazy.
Does anyone have the same problem? Any ideas what the cause might be and how to fix it? Or is the drone defective?
(I have a video of that drone's shake while hovering, but it doesn't allow me to post URL here)
Thank you do much for any tip or advise?
Paul
2017-11-17
ICEBERG03
URL link to the video of my drone hovering - and shaking is
2017-11-17
SunSets
Flight distance : 311089 ft
Yikes....  Check you have "Black props" installed on black dot motors. And Silver props on silver.... try again.
2017-11-17
SunSets
Hmmm....  If it's more than that, because it' new. I'd send it in to DJI. Maybe.
2017-11-17
Try running the motors up without the props to see if it still shakes. And BTW, you appear to have all four anti-drop pins fitted to the gimbal, it should only be two in the diagonally opposite corners.
2017-11-17
SunSets
Don't run -up the motors , you may have chracks between the screws, located under each motor...  check for chracks between screws on each motor underside.
2017-11-17
SunSets Posted at 2017-11-17 20:48
Pardon? There is no problem in running the motors without props. Also, check you have removed the plastic packing piece behind the gimbal arm. Or provide a photo of the gimbal. And BTW, you cannot fit the wrong props to the motors, they are left and right hand threads.
2017-11-17
NuminousD
I had the same problem but I fixed it. I took a video with my iPhone of the drone flying, and because of the way the spinning propellers show up in the video, I could clearly see that one motor was running slower than the rest. I replaced the motor and the shaking went away.
2017-11-17
Is the gimbal calibration successful? Please make sure the propellers are mounted well and check again.
2017-11-17
ICEBERG03
Hi guys,
thank you all for your feedbacks. To answer some of your questions:
- yes, props are installed properly - silver on silver/black on black
- no cracks under the motor
- without props, there is no shake
- no plastic behind gimbal
- I will try to do gimbal calibration one more time
ONE NOTE, with first set of propellers, I noticed that one prop is spinning slower. With the second set, it seems like they are all spinning the same speed
I will definitely contact DJI on Monday.
Thank you guys again for your support.
P
2017-11-18
ALABAMA
Flight distance : 10442687 ft
Send it back, a brand new one shouldn't be doing this.  Poor quality control a it's worst to let this get out.
2017-11-18
solentlife
Flight distance : 1087530 ft
Latvia
SunSets Posted at 2017-11-17 20:36
Not possible to get wrong - threads would not match. And even if you could - the AC would then try to bury itself in the ground !!
Nigel
2017-11-18
solentlife
Latvia
Geebax Posted at 2017-11-17 22:12
Agree ... (it is generally not wise though to run BL motor to full speed for more than a few seconds though).
Standards do not have the Plastic Packing piece in the gimbal as shipped on Pro / Adv ... only the gimbal lock.
I wonder if a motor may be flexing or mount damaged in any way ? Could be a shot bearing in one or more motors - but normally you would hear sounds.
DJI warranty here we go ....
Nigel
2017-11-18
ICEBERG03
solentlife Posted at 2017-11-18 09:56
Thanks Nigel for your feedback. Yeah, I don't hear any strange noises.
2017-11-18
ICEBERG03
ALABAMA Posted at 2017-11-18 08:54
Yes, I will definitely send it back. I bought it 2 weeks ago, and only did 2 flights.
2017-11-18
LarBear360
Flight distance : 63537 ft
I have heard that the customers/pilots are the DJI quality control. They don't test, we do. Sometimes it makes more sense to purchase from a brick and mortar retailer. Just take it back and exchange it for another one. No hassle. No waiting.
2017-11-23
Dhillskiier1653
Flight distance : 391818 ft
I had this exact issue but didn't try anything because I was a new flyer so I just returned and got it exchanged. The second one worked fine and there was no shaking. How long ago did you buy it?
2017-11-29
ICEBERG03
Dhillskiier1653 Posted at 2017-11-29 05:05
Thank you for your input. Yeah I actually did the same. Luckily the store I brought it at did exchanged it for me. The new one works fine.
Cheers
2017-12-5
Nebuchadnezzar
Flight distance : 3462946 ft
ICEBERG03 Posted at 2017-12-5 10:53
Cheers
Nice to hear That !! Enjoy & Fly Safe
2017-12-5
ICEBERG03
Nebuchadnezzar Posted at 2017-12-5 10:57
Thank you. Yeah it is fun, but I am still learning. Cheers,
Paul
2017-12-5
