Go App Help (Phantom 3 Std)
1753 30 2017-11-23
Brenty
Good Afternoon,
First off, my std3 is my first ever drone and i have only had 1 small flight so far and I have read the manual 4/5 times.
My first flight went great but ever since i have had problems with the app.  I only ever see a screen with the camera feed on and 4 icons (switch vid/pic, red record, setings and play) but i am unable to click any of them (I don't know how to add screen shot, sorry)
and not the 'flight' screen with the options on like i did on my first and only flight.  I am on the latest firmware
Thank you all
2017-11-23
Brenty
2017-11-23
ALABAMA
Flight distance : 10442687 ft
Delete and reinstall the GO app and see if this works, also, what kind of device are you using?
2017-11-23
Brenty
ALABAMA Posted at 2017-11-23 06:50
I'm using the Phantom 3 Standard and have re-installed the app a couple of different times now
2017-11-23
Brenty
I get the 'flight' screen if i turn the app and controller, but as soon as the Phantom 3 turns on it defaults to the screen above
2017-11-23
ALABAMA
I meant what kind of phone, or tablet.
2017-11-23
Brenty
ALABAMA Posted at 2017-11-23 07:06
Sorry, iPhone 6 plus on latest iOS
2017-11-23
ALABAMA
It should be working well with that. Try turning on the p3s first, but this shouldn't make any difference.   Weird thing
2017-11-23
Peterx
Flight distance : 1499708 ft
Turn the RC on first then the AC and last the mobile(choose WIFI SID of the Phantom) and Go app.
2017-11-23
KedDK
Flight distance : 1133038 ft
Keep an eye on this thread too.
2017-11-23
Brenty
At least it looks like it’s not just me! Thank you
2017-11-23
ALABAMA
This is all very weird. Maybe the mods can weigh in.  Seems to be isolated and something new.
2017-11-23
Anssec66
Flight distance : 466 ft
I’m having the same problem
2017-11-23
fansb63f8904
Flight distance : 334754 ft
Philippines
Another Go App IOS bug.
2017-11-23
Brenty
SUCCESS!
Turn off the video cache in background option
Turn on the cache map in the background
5 flights in a row with no problems!
2017-11-24
Brenty
Anssec66 Posted at 2017-11-23 21:50
I've got it working for me
See above post
2017-11-24
Anssec66
Tried your suggestion. Still doesn’t work. Frustrating.. not impressed with DJI
2017-11-24
fans7d311c2f
Same problem here. My iPhone 6 works perfect but my new 7 plus does just what you say above. iOS 11.1.2, latest firmware and app is updated. Not happy!!
2017-11-25
Dockater
Flight distance : 139649 ft
Sometimes it is necessary when updating an App/SW/FW to complete the process by shutting down the iPhone/Pad completely and do a cold start (reboot).
2017-11-25
Hi all, the users who have this issue, I appreciate if you could do me a favour: please help to name the app you are using (DJI GO/DJI GO 4), name the app's version and the mobile device you are using, would like to collect the info. Thank you so much.
2017-11-26
Brenty Posted at 2017-11-24 04:30
SUCCESS!
Glad that you got it worked at the end, and hope it also helps others. And our engineers were aware of this issue and will get it fixed soon.
2017-11-26
fans7d311c2f
Brenty: I have done a ton of research today across all threads and found this issue is affecting all products using dji go and dji go 4 so it is an app issue caused by the update. I also noticed the most common thread is the fact that everyone with the issue is running a plus sized phone.
Here is my response from DJI this morning (26th November 2017)
“We are aware of this issue, our engineers are working on it now, will fix it in the next update.”
Although my check if it’s plus size only:
“I don't think this is related to the size, anyway, the engineers are working on it now, please be patient, will fix it soon.“
So yes, don’t waste time messing about with settings, just wait for the update and borrow another device if you can: I have my old iPhone 6 I was about to sell but a cheapo Android might work for now.
2017-11-26
Peterx
Dockater Posted at 2017-11-25 15:35
You thought that system begins act like Microsoft Windows ?
Hi Thor.
I generally named an app with short name and complete versions number,will it be enough?
2017-11-26
fans7d311c2f
Just confirmed this:
iPhone 6 with iOS 11.1.2 - works
iPhone 7 with iOS 11.1.2 - works
iPhone 7+ with iOS 11.1.2 - does not work
From dji: “Thank you so much, will forward this to the engineers.”
2017-11-26
Rplucas
Flight distance : 22172 ft
I’m using DJI GO
2017-11-26
Anssec66 5
My set up:
DJI go app. Latest version
iPhone 7 Plus IOS 11.1.2
Doesn’t work
2017-11-26
Peterx
Use an older one,see post #29
2017-11-26
Rplucas
I’m using DJI GO app
2017-11-26
Rplucas
Guys,
I’ve updated my app and it’s working now.
The only problem is that I’m getting a critical low voltage warning on both batteries which are full.
Can anyone check if it’s only me getting this warning?
2017-11-29
Nebuchadnezzar
Flight distance : 3462946 ft
Rplucas Posted at 2017-11-29 08:10
Guys,
Try to refresh the app when it happens
2017-11-29
Peterx
Force to stop the app and make a new start of it. If that not helps then make a new start of your mobile device.
2017-11-29
