Top cover swap on Spark
6636 4 2017-11-28
Philip Holden
Is it possible to replace (swap out) the top cover on the Spark so as to be able to change the color of the drone?
2017-11-28
CabinPete
Flight distance : 98 ft
There is a video on YouTube on how to remove the top cover but no idea where you can get just the cover in the color you want.
2017-11-28
FireSauce
I used a cricut to cut a template out of black vinyl.  Works pretty nice with some heat to help apply.  If you know anybody with a cricut or other vinyl cutter it’s an option.  If you get sick of it you can always peel it and do a different design.  I got the template by shopping for a skin from one of the main sources, and it shows you the shape.
2017-11-28
DJI Elektra
We would not recommend users change it on your own as you may damage the drone. Thanks for your understanding.
2017-11-29
fans09391f73
Flight distance : 518 ft
Don,t do this if your spark is under warranttee. If you still want to you can obtain the original part on Aliexpress. Down load the Aliexpress app and type in Dji spark assessories. The item you want is sold by RC  ports store. When you get your new cover note where the position of the locating tags then starting at the rear corner on one side lever the cover very slowly up with a blunt knife, sliding it along to the tags one at a time the lift. Do the same on the other side. You will need to remove the 6 retaining screw first. The middle 2 screws have plastic seals in them which you will need to pick out with a pin
2017-12-21
