Broken Quick Release Mounting Plate
3090 18 2015-4-27
Bkackman
Flight distance : 3445020 ft
I came back from a weekend and removed the Inspire from its case for an early morning flight. I was putting on the quick release props.  One of the props didn't go on smoothly.  That caused me to look at it a bit more carefully. When I removed the prop to look, I found the mounting plate (which is plastic) had broken at a line that went straight between the screw holes.
I hadn't had any mishaps that could cause this for over a week's flights. One week ago I had an unplanned take-off in my livingroom where I lost two propellers in a dual with a dining room chair. I suspect mounting plate was cracked at this time (one prop had broken at the hub). I had put new props (this position had been one of them), but didn't detect any problems at that time and have flown several times since.
I'm not quite sure what flight failure this might have cause if I missed it.  Given the location of the split line due to the break, the screws would no longer hold the plate down. However, the plate would not have been able to spin under the propeller since the screws would still retard that movement. It is also trapped from escaping by the propeller. So maybe nothing would have happended.
In any case, I removed it and will try to superglue it.  In the meantime I'm using a self tightening prop with a prop lock in that position. The ESC should account for any minor difference in flight characteristics of that propeller.
2015-4-27
kgarrison
Flight distance : 11736709 ft
In the US you can order replacements/extras
http://www.multicopterwarehouse. ... onnect?search=quick
2015-4-27
mountmotor
If I were you, I would not superglue it...WAY TOO RISKY...
2015-4-27
mountmotor
Also, I would put all the older props back on instead of just using one...You are risking too much man...The newer blades are slightly different so I would not want to risk it...Either use all four old ones, or buy another pair of the new ones.
2015-4-27
bostonlines
Flight distance : 1045558 ft
Please don't use superglue. Structural integrity is lost once it broke in two. If a prop comes off, it will be a falling brick. I would strongly suggest you use all four of the same props like Mount mentioned.
2015-4-27
PeteGould
bostonlines@gma Posted at 2015-4-28 12:12
Please don't use superglue. Structural integrity is lost once it broke in two. If a prop comes off,  ...
+1 on what the other guys are saying.  Superglue on plastic is a really poor joint - and considering how many RPM we're talking about, even the best glued joint isn't good enough.  A replacement quick mount kit (for two motors) is $4.  $4 and some order time weighed against risk of loss of the drone?  Shouldn't be a hard decision.
2015-4-27
Bkackman
Thanks for the feedback. Won't rely on superglue. Have replacement mounting kit on the way from San Diego. Should have it in a couple of days. Will remove quick release props and use older props until them.
Appreciate the advice and input.
2015-4-27
Captain Obvious
Is that a tiny Google Eye face on that top peice lol (The white mark)
2015-4-27
Muzzy
A big thank you to Bkackman, this is one of those pre-flight checks I'll be adding to my manual in the future. If it's OK with you, I'd like to include your image of the damaged part for reference purposes.
As parts are hard to get here in the UK, I think I'll order in a spare set - just in case.
Thank you.
2015-4-27
Bkackman
Muzzy Posted at 2015-4-28 13:12
A big thank you to Bkackman, this is one of those pre-flight checks I'll be adding to my manual in t ...
I'm pleased to have benefited your effort.  Yes, you can absolutely use my image of the damaged part.
2015-4-27
Bkackman
Captain Obvious Posted at 2015-4-28 13:02
I went back and looked at the original piece and it, indeed, looks like a google eye face! I looked at the undamaged one at it's just a solid circle. Good eyes, my friend!
2015-4-27
Captain Obvious
Hopefully these are not going to be another source of pain for the Inspire...I still haven't received mine yet
(Doubt if ever will) They do look like another weak spot to me.
2015-4-28
GoCopter
Flight distance : 73461 ft
A nice solution ;) http://www.droneparts.de/DJI-Matrice-100-DJI-Matrice-100-Teile---Zubehoer-DJI-Matrice-100---Inspire-1---Alu-Propeller-Installation-Set-4-teilig/a53454043_u5094_zb8fd62e1-842e-4fa7-a9d4-316a5a9c2a17/
2015-10-18
RichJ53
Flight distance : 1837356 ft
Pardon me if I am speaking out of turn. In my opinion, this should be treated like a full size aircraft.... if you have a blade strike / or near miss; all of the parts need to be removed and inspected. I would always replace these parts due to the forces involved and the wear and tear on these items.
So, annual inspections are good to do. But if you make contact with the props, then take everything apart to inspect, but replace with new stuff even if it looks good.
Rich
2015-10-18
Alien
Flight distance : 156470 ft
Hi Guys
Pardon my intrusion. I've ditched the plastic, installed alloy mounting plates and CF props. Not trusting a 4K machine's air-worthiness to plastic.
Don
2015-10-23
enkhome
Flight distance : 273038 ft
The self-tighten props with the prop locks are the best. I will never use the quick loose props.
2015-10-23
sasoto1
Just buy a new mount.  I wouldn't glue it and then rely on it.  There like $4 or $5 dollars.
2015-10-23
petevandra
Flight distance : 6939 ft
enkhome Posted at 2015-10-23 23:20
The self-tighten props with the prop locks are the best. I will never use the quick lose props.
I've just decided to change back to the screw on props with locks.
After about 100 plus flights with the quick release version, I was noticing that there was very slight movement in the props (up & down) - firstly with one of them - then with three. The attachments to the motors all looked secure.
I don't think it's my imagination, but the props now seem to be quieter when I fly her past me too.
2015-10-25
enkhome
petevandra@msn. Posted at 2015-10-26 04:30
After about 100 plus flights wi ...
Good choice and in my opinion also the best,
The self tighten props with prop locks as a whole is not only the better fail-safe design but also better balanced because they only can mount exact at the center on the motors with no fraction of lee resulting a smoother operation.
2015-10-26
