Just purchased, Wifi says no internet connection
5307 7 2017-12-5
djiuser_Jszp1yO
I followed the instructions to set up the wifi. I entered the default password and it keeps saying no internet connection.
2017-12-5
Betamace
Flight distance : 2133 ft
No problem, disregard that notification. The Remote is a wifi device that will never connect to the "internet" at any time, it only requires a password to connect to your display device. Very similar to "Bluetooth"
2017-12-5
AlanHd
Flight distance : 797365 ft
If it is your device that’s saying that then it’s normal, can you fly ok.
2017-12-5
Hi there, it is normal for P3S as it uses WiFi, no worries.
2017-12-6
djiuser_Jszp1yO
Betamace Posted at 2017-12-5 22:54
I could not see my Phantom 3 Standard camera on my phone. Its just blank. I turned the controller on and the drone. Is there something I am missing?
2017-12-6
ALABAMA
Flight distance : 10442687 ft
Go to settings on your phone and select dji under wifi
2017-12-6
Rene Jensen
turn rc on first and then ac and then wait for the led light on rc to turn green.and then find the phantom wifi on phone under wifi.and then start the go app.if you are connected to the phantom wifi you should be able to see thrue the camera on phone
2017-12-6
Betamace
djiuser_Jszp1yO Posted at 2017-12-6 07:08
Are you seeing the  "Phantom xxxx" on the wifi drop down list in the phone's wifi settings and is it showing connected? If so, verify if the link button on the side of the aircraft is green and also the the led on the right side of the remote's power switch. There is a link procedure explained in the manual to reset the wifi by using the gimbal tilt wheel and S2 switch.
This YouTube video is really good for Phantom3 Standard users that are just starting off. Watching this video may clear up some of the initial confusion experienced by a first timer.
2017-12-7
