Flight distance : 11959747 ft
Having looked at your log, because you were using your phone it doesn’t register on this log, but what simply happened was you picked up some magnetic interference and your aircraft went into Atti mode , when in Atti mode you should be able to control aircraft it will hold its altitude which helps but can be difficult, you need to already to have a plan for when this might occur, looking at your log your aircraft was close to you in open ground you should really have made an attempt at lowering your craft, but your log only shows you trying to initiate landing which will not work without gps.
I know it can be daunting but controls are all you have at this stage using only phone makes it twice as difficult, I understand this.
Wind is a real factor and judging by the speed aircraft traveled there was some wind around, your aircraft would have continued on its heading until it reached 10% critical battery and then forced landed, so judging by the amount of battery and speed it was travelling it would be quite a bit away from when you last saw it, it also could have regained gps but it was out of RC range very quickly.
Both landing and RTH will not work without gps.
This will be up to dji I have seen warranty being offered and also turned down with offer of 30%, so you will have to wait to hear from them.
I wish you luck and hope it goes your way. |
