Goggles RE + Spark = No Flight Data ???
1663 4 2017-12-13
DocQuicksand
Flight distance : 1048652 ft
I recieved the Goggles the other day, connected it to the Mavic through Occusync and it works flawlessly. I understand that Goggles sync to the Spark differently (through an OTG connection from RC to Goggles), but when I make that connection, the DJI Go App (running on my iPhone 7) disconnects completely. Not a big deal except that when the DJI Go app disconnects, no flight data is being recorded. I actually lost 13 minutes of flight time when flying with the Goggles because of this (not cool).
Is this normal? I would expect that all systems should be talking, either through the OTG connection or via the established WiFi connection, and that flight data should be recorded regardless. Am I missing some setting on one of the devices being used, or is there a bug / limitation?
Any input would be greatly appreciated!
DocQuicksand
2017-12-13
DJI Elektra
Hi, sir. Did you try to change OTG cable? Please note that the flight records were saved in goggles and you can connect it with DJI Assistant 2 to export the flight data. And it can not be added into the flight records of app. And our engineers are working on that. Thanks for understanding.
2017-12-14
DocQuicksand
Dirty Bird Posted at 2017-12-14 03:49
It would be greatly appreciated if we could connect our birds to the Assistant & have the onboard records exported to our online flight records.  I have requested this ability several times.
So I am assuming that you have the same issue? I don't have the issue with my Mavic...
2017-12-14
DocQuicksand
DJI Elektra Posted at 2017-12-14 01:54
It is a brand new OTG cable, haven't had any issue using it. Don't believe that it is a OTG issue, just don't understand why when we connect the OTG cable, it shuts down the WiFi connection between the phone and RC...
2017-12-14
DocQuicksand
Dirty Bird Posted at 2017-12-14 07:34
No it's that most of my flights are long programmed Litchi missions so, because they run under Litchi, they don't get synced or recorded to my flight logs.  They are still logged by the bird's onboard flight recorder & it would be great to be able to use the Assistant to sync them.
Downloaded and started running Litchi last week. What an awesome tool! I will post some flight missions soon...
2017-12-19
