File name count
3333 41 2017-12-14
pmshop
Flight distance : 8073271 ft
Is anyone else having an issue with the Spark not keeping the proper filename count?
For example,
A Spark I bought as a spare and used infrequently got up to a file name of DJI_0020 and then the next file recorded was DJI_0001
This has happened to me several times with the same unit.
Got to 25 day before the upgrade then after, DJI_0001
Craziest thing is with no changes after the upgrade and getting that DJI_0001, I got DJI_0002 but then DJI_0001 on the very next recording.
Quite annoying!
Any help appreciated!
2017-12-14
DJI Diana
Flight distance : 2408 ft
Hi there, what kind of files did you record? Are they panorama photos?
2017-12-14
pmshop
DJI Diana Posted at 2017-12-14 20:09
I am recording video and photo files.
I saw right away that panos start over in their own collection.
It is the regular video files and photo files that will not "keep" the counting up naming convention.
My other Spark does not have this issue.
2017-12-15
DJI Diana
pmshop Posted at 2017-12-15 02:04
Could you please refer to the video below to export the black box data for analysis? Please also provide me with some original files and some screenshots of this issue, you can upload them to the Dropbox, then provide me with a link to download them. Thank you in advance.
2017-12-15
Enri
Flight distance : 683501 ft
For me it's quite good following progressive file numbers.
Since I lost most of my flight records having the habit to take a pic every take off (with axis check) and before every landing (to celebrate his returning to owner) I'd say that having a backup of all the shots I took file timestamps remains the only reference about time flown I have.
2017-12-15
pmshop
Wonderful...it is not exporting
Just shows the progress circle but nothing is populating the WM100Export folder.
I also noted Data Upload list does not populate either.
**UPDATE**
Let it try to import for 10 minutes....progress still spinning, nothing populated
2017-12-15
pmshop
Should I be concerned I cannot download the black box data?
2017-12-19
FXF
Flight distance : 68123 ft
Austria
...I have experienced the same problem - spiining wheel but no export of black box data or no Import of data records dat files with Windows 10 (and Acer Switch Notebook). Solution would be fine if anyone knows. Thank you!
2017-12-19
S-e-ven
Flight distance : 5922034 ft
Newest version off assistant 2?
2017-12-19
pmshop
S-e-ven Posted at 2017-12-19 07:37
Yes, latest downloadable version.
And, I have 2 Sparks
First imports, the second does not.
2017-12-19
S-e-ven
pmshop Posted at 2017-12-19 07:52
Firmware on both Sparks the same?
Same battery used?
If yes, maybe try to install the firmware again.
I just shooting in the blue here, but till you get an admin or mod to chat with you, ....
2017-12-19
pmshop
S-e-ven Posted at 2017-12-19 07:57
Same battery used?
All yes
And there was an admin chatting with me
2017-12-19
S-e-ven
pmshop Posted at 2017-12-19 08:06
All yes
2017-12-19
FXF
Austria
All yes
dear pmshop, did admin gave you advice - would be interesting for me as i do have same habit with Assistant 2 and spark connected, latest firmware 0800 (firmware update w/o any issue).
Thank you for reply
2017-12-19
pmshop
FXF Posted at 2017-12-19 09:20
Thank you for reply
Yes,
Admin said to download the black box file and send.
However, the black box on the Spark in question will not download.
Waiting admin's reply
2017-12-19
FXF
Austria
pmshop Posted at 2017-12-19 09:41
Yes,
Thank you - pls keep me updated if you get an solution.
2017-12-19
DJI Diana
Yes,
Could you please reinstall the DJI Assistant 2, then try to export the data again? Please also try other computers if you can. If it persists, please provide me with the flight controller log data, some original files and some screenshots of the file name issue first. BTW, please click the Reply button under my post when you aim to reply my post, then I can get a reminder, thank you in advance.
2017-12-20
DJI Diana
FXF Posted at 2017-12-19 12:05
Hi FXF,  please also try the steps I mentioned in the post 17#, reinstall the DJI Assistant 2, or try other computers, see if it works.
2017-12-20
FXF
Austria
DJI Diana Posted at 2017-12-20 20:34
Hallo DJI Diana, thank you taking care of my "minor" problem. I did reinstall the DJI Assistant several times but that didn't solve the problem - spinning wheel resists. So i dig a little bit more in the issue and found threads here which seemed to me similar - there might be a problem with the libusb driver which showed a problem in my device manager program (I'll try to upload a screenshot)
I also tried to install the DJI Assistant 2 with the Windows 10 modus to allow non signed drivers to be installed. The procedure didn't help.
BTW - updating worked very well and smooth (I updated just some minutes ago 0900 firmware and 3 batteries)
Hope you may give additional advice.
Thank you!!
2017-12-21
pmshop
I have reinstalled twice with no resolve
I have tried 2 computers - same effect, cannot download the black box.
And, correction on earlier post: I have 2 Sparks that show the same behavior - cannot download the black box.
Current Windows config:
Windows 10 Pro
V1709
Build 16299.125
I do not have the same driver issue as FXF.
2017-12-21
DJI Diana
FXF Posted at 2017-12-21 14:41
Thanks for the info, I've forwarded this to the engineers for a check, I'll let you know if I got a response from them.
2017-12-21
DJI Diana
pmshop Posted at 2017-12-21 16:17
Thanks for the info, I've forwarded it to the engineers for a check. For the file name issue, could you please provide me the other info I asked in the post 17# first?
2017-12-21
pmshop
DJI Diana Posted at 2017-12-21 20:11
There is nothing else to send.
Screenshot can be easily described - a series of videos/ pictures on one flight can be named DJI_0025, DJI_0026, DJI_0027, DJI_0028. Then the next flight will be named DJI_0001, DJI_0002, DJI_0003, DJI_0004
The Spark randomly restarts the naming convention.
Again, these are not panoramas. These are video files and single shot photos.
2017-12-22
FXF
Austria
DJI Diana Posted at 2017-12-21 20:01
Dear DJI Diana, thank you for your efforts. I am very curious what engineers will advice.
2017-12-23
DJI Diana
pmshop Posted at 2017-12-22 06:18
We also need some original files, we need to forward them to the engineer for analysis. A description of an issue can't be analyzed, please kindly provide the details I asked so we can move forward, your cooperation will be highly appreciated.
2017-12-24
pmshop
DJI Diana Posted at 2017-12-24 03:09
I would greatly send you the black box files but as I have stated, they will not download
2017-12-24
pmshop
Here you go. Thought it was a temporary glitch but as you can see, file number DJI_0001, DJI_0002, DJI_0003 and DJI_0004
Dated folder structure is at the file explorer address bar.
Just yesterday, my file count was the highest ever before SELF resetting; DJI_0091
2017-12-30
pmshop
Here you go. As you can see, file number DJI_0001, DJI_0002, DJI_0003 and DJI_0004
2018-1-4
DJI Diana
pmshop Posted at 2018-1-4 09:53
Thanks, I've forwarded this to the engineers for a further check. If you could upload an original video file from the SD card to the Dropbox or Google Drive, then provide me a link to download it, that will be better.
2018-1-5
pmshop
DJI Diana Posted at 2018-1-5 05:11
https://drive.google.com/open?id ... L3EEvthHtWAIk5gUNFP
2018-1-5
DJI Diana
pmshop Posted at 2018-1-5 15:43
https://drive.google.com/open?id=1G_1PwUi-NNBTiL3EEvthHtWAIk5gUNFP
Thank you so much, I've also forwarded this to the engineers. Will keep you updated.
2018-1-6
pmshop
DJI Diana Posted at 2018-1-6 01:01
Thanks.
Anything else I can do to try to get the black box?
It still will not download.
2018-1-6
DJI Diana
pmshop Posted at 2018-1-6 16:35
Thanks.
Not yet, as for the download issue, I've also forwarded to the engineers, they are looking into it now. Anyway, will let you know once I get a response from them.
2018-1-7
pmshop
DJI Diana Posted at 2018-1-7 20:28
And now the first Spark I have, that reached a file name of DJI_0370 yesterday now recorded file DJI_0001
This is VERY frustrating!
Please help!
2018-2-3
pmshop
And, I am now able to upload the black box files of both Sparks I have.
Not sure how that changed.
Black Box Files for TWO Sparks
2018-2-3
pmshop
looks like I have lost my admin help
2018-2-8
pmshop
Since the Alpine White Spark of mine is at service so My Sky Blue is picking up the slack.
I am currently at file name DJI_0134 without a reset so far.
No additional action/ troubleshooting to get it there.
2018-3-7
pmshop
Now at file name DJI_0146
But now my gimbal seems to be out of whack and will not hold adjustment.
2018-3-12
The Bash's
So I am having this issue as well.  My file numbers are resetting and my gimbal keeps tilting off the horizon even though I adjust it back straight.  I have not made it anywhere near 146 not even past 50 before it resets.  Have you heard anything about a solution yet?
2018-3-13
pmshop
The Bash's Posted at 2018-3-13 20:54
Nothing yet.
2018-3-14
