Phantom 3 New Pilot Worried about Jello
10234 54 2015-5-1
tonyatmatc
I got my Phantom 3 yesterday and flew it today.  This is my second video.  I have removed the foam, removed the lense plastic.  My concern is that when I took my Phantom out of the box yesterday the plastic clip to hold the gimbal had come off during shipping.
If anyone could take a look at the video and tell me it is nomal or abnormal?  Remember new pilot so I am just flying on beginner mode and not doing much with the camera orientation.
https://www.dropbox.com/s/u5bhrmmoygnwrjt/DJI_0001.MOV?dl=0
Thanks!
2015-5-1
tonyatmatc
https://www.dropbox.com/s/9z60qg4ohko41qy/DJI_0003.MOV?dl=0
Here is another video that is smaller.
2015-5-1
Mikey14
The foam might have split in 2 and there is still a little piece in between the body and top of the gimbal that you might have missed or thought it was part of the gimbal. Take a closer look.
2015-5-1
tonyatmatc
Mikey14 Posted at 2015-5-2 06:02
The foam might have split in 2 and there is still a little piece in between the body and top of the  ...
I did check. The foam came out perfectly.  But the plastic guard was not in place when I pulled the Phantom out of the box.  My concern is that the gimbal was getting knocked around during shipping.  So you do see some Jello?
2015-5-1
Tahoe_Ed
Flight distance : 2605 ft
tonyatmatc Posted at 2015-5-2 06:12
I did check. The foam came out perfectly.  But the plastic guard was not in place when I pulled th ...
You should not worry about that right now.  Take the P3 out and fly it.  Film, take pictures and decide how it works and post your videos here.
2015-5-1
tonyatmatc
Tahoe_Ed Posted at 2015-5-2 06:21
You should not worry about that right now.  Take the P3 out and fly it.  Film, take pictures and de ...
So that shake is normal? I just want to make sure.
2015-5-1
bobasbury
Flight distance : 1140502 ft
Your props need to be balanced.  Stand in front of your Phantom and go UP as fast as you can.  You will see your camera shake from side to side.  That is caused by an unbalanced prop(s).
2015-5-1
erdbeerknoedel2
looks indeed like some jello and shaking but I don't know why. you should double check your gimbal, I hope you don't have to send it back to dji
2015-5-1
Tahoe_Ed
tonyatmatc Posted at 2015-5-2 06:22
There is some degree of shake in the gimbal.  More on the Inspire than the P3 but present in both.  I have not seen it in the video in over 120 flights.  I will say that I got a preproduction unit and it had no foam and the clip was disconnected.  Nothing holding the gimbal.  I have not had an issue.  I have traveled with my P3 to and from the flying field and in a carry on bag on an airplane numerous times without gimbal restraints.  Yes I did pack some socks around the gimbal but nothing else.
2015-5-1
CapitAn
Have you watched it running in the house without the props on, and in a low hover. Check this out at the 2:17 mark, the motor closest to us is doing a serious wobble:
l mentioned it in the video's comments section earlier but haven't got a response. lt doesn't seem normal to me.
2015-5-1
ntfa
Curious, how do you balance props on this?
2015-5-1
Tahoe_Ed
ntfa@sbcglobal. Posted at 2015-5-2 09:10
You can get a threaded shaft and a balancing mount.  There are several available.
2015-5-1
tonyatmatc
Tahoe_Ed Posted at 2015-5-2 12:40
What prop balancer would you suggest?
2015-5-2
Tahoe_Ed
tonyatmatc Posted at 2015-5-2 22:05
I have not used a prop balancer since the early P1-P2 days.  I have found that the DJI props are well balanced out of the box  I have been flying the Inspire since November and the P3 for the last month.  I have not touched one prop.
2015-5-2
tonyatmatc
Tahoe_Ed Posted at 2015-5-3 02:58
I have not used a prop balancer since the early P1-P2 days.  I have found that the DJI props are w ...
So if it not the props then it is the Gimbal that is causing this shake.
2015-5-2
Tahoe_Ed
tonyatmatc Posted at 2015-5-3 03:07
Have you checked to make sure that all the vibration isolation dampeners are fully attached.  That the cables are also seated.  Try filming a short segment 20-30 seconds at 1080p60 and upload to YouTube.  If you are still getting video aberrations, then yes I would contact DJI and share your video with them.  If necessary they will arrange for an RMA for repair or replacement.  I did not download the video but what I saw was mostly the inablity of my internet connection to stream the video.
2015-5-2
tonyatmatc
Tahoe_Ed Posted at 2015-5-3 03:18
Have you checked to make sure that all the vibration isolation dampeners are fully attached.  That ...
Should it have all 4 plastic pins in?  It came with only two attached. If so I can add the other two, and try what you suggested.
2015-5-2
Tahoe_Ed
tonyatmatc Posted at 2015-5-3 03:20
Should it have all 4 plastic pins in?  It came with only two attached. If so I can add the other tw ...
Just two are installed at the factory.
2015-5-2
tonyatmatc
Tahoe_Ed Posted at 2015-5-3 03:22
I know that. Do I add the other two?
2015-5-2
jorski
Flight distance : 171946 ft
Finland
I have use this prop balancer http://www.ebay.com/itm/Dubro-Tr ... hash=item339dba7f3e
You also need this http://www.ebay.com/itm/DJI-Phan ... D221689577278&rt=nc
Here is a video link to Dupro balancer and how to balance self tighten props. Look at 4.35 I use that method, I do not have balance rod.
2015-5-2
tonyatmatc
jorski@netti.fi Posted at 2015-5-3 04:13
You also need ...
Thank you!
2015-5-2
tonyatmatc
I recalibrated the Gimbal, went up to 60fps, and it seemed to have helped greatly. It was much more windy today too with no jello effect.
Thanks for your help!
https://www.dropbox.com/s/oit8rfbfxp9spza/DJI_0002.MP4?dl=0
2015-5-2
jorski
Finland
I order Phantom 2 props to my Phantom FC40 and those original DJI props was not absolutely balanced, I hope it helps you and greetings from Finland!
I am still waiting my P3A....
2015-5-2
radus77
tonyatmatc
In  your Phantom set you got two sets of props. Try to use second one. I had the some problem in my phantom 2. I bought the cheaper props from ebay and put on my Phantom. I had yello effect after I put back DJI original set and yello effect gone.  99% yello effect is unbalanced props.
2015-5-2
felixmiziozniko
replace white isolation rubbers with black ones (from the phantom 2 or get a set on ebay. )
The white ones that are standard have always produced horrible jellowing in videos from day 1
2015-5-2
bryson79
Just checking in, Phantom 3 Advanced 1080 camera. I have been shooting at 25fps and have had absolutely no jello. It looks like the camera is attached to a tripod at the top of a building. Absolutely amazing.
One thing I noticed is that your props were showing in the shot when moving around. I have never been able to get a prop in the shot. Is there a seting for adjusting the field of view of the camera? I did not change anything just flew it at stock settings.
2015-5-2
Tahoe_Ed
felixmiziozniko Posted at 2015-5-3 12:37
The whit ...
Please don't do this.  The P2 and P3 are entirely different craft.  What may have worked on one will probably not work on the other.  Most users are not having any issues with jello.  I have requested that the user post video that has been uploaded to YouTube or Vimeo and have not seen any yet.
2015-5-3
tonyatmatc
bryson79@yahoo. Posted at 2015-5-3 14:51
Just checking in, Phantom 3 Advanced 1080 camera. I have been shooting at 25fps and have had absolut ...
I did not change anything.
2015-5-3
bryson79
Here is a video I shot last night.
2015-5-3
tonyatmatc
Tahoe_Ed Posted at 2015-5-3 23:25
Please don't do this.  The P2 and P3 are entirely different craft.  What may have worked on one wi ...
With Jello
After caliber of gimbal and changing to 60fps
2015-5-3
Tahoe_Ed
I did not see much jello in the first video, mostly compression artifacts from YouTube.  The second was fine and the gimbal was stable.  Great job!
2015-5-3
john.lambert4
tonyatmatc Posted at 2015-5-4 03:08
With Jello
https://youtu.be/pLv4tVBHH2M
You can definitely see the "jello" effect in the first link, especially when it's going up rapidly!  The second video shows none that I can see, so job well done!
2015-5-3
LaurenSRQ
Flight distance : 38074 ft
I am also seeing the "jello" effect in every single video I have shot since taking my P3 out of the box. Here is an example:
2015-5-13
ssteenberg
Dji screwed up anther product. Inspire 1 all over again. I returned my inspire 1 and will not buy DJI products anymore. Worst customer service ever.
2015-5-13
mswall
Flight distance : 39695 ft
I disagree. The worst customer service is any drive-thru at Taco Bell.
2015-5-13
rmh2003
Flight distance : 483917 ft
I had the same issue in yesterday's video. I have shot about 10 videos so far and never had any issues. Flew yesterday and I got a real bad shake on my way up. I do take the props off and on everytime during transport.
2015-5-14
dave
bryson79@yahoo. Posted at 2015-5-4 00:53
Arizona Sunset
Byrson,
What part of Arizona is that?  It looks like Quarzsite area...
2015-5-15
bryson79
It is in the San Tan mountains by Queen Creek.
2015-5-15
peoleo
Flight distance : 25410804 ft
I solved the jello effect by changing to the same vibration rubber on the Phantom 2, they are stiffer and instead of the plastic pinns, I have tied with dental floss. Perfect.
2015-5-16
chamb0 FPV
TBH you shouldn't have to modify your P3 to get stable video. If they have a problem with unbalanced props then they need to sort it!!!
2015-5-16
