![](https://forum44.djicdn.com/data/attachment/common/c8/common_2_usergroup_icon.png) Core User of DJI
Flight distance : 11959747 ft
Vyborny83 Posted at 2018-1-3 10:55
Look. It is pointless to argue about it. I am an IT worker. I see the hardware, I see the software, I see the same OTG cable you can use for both DJI Goggles and the phone. The Goggles and the phone are essentially the same (for this purpouse), a hardware with a display and a DJI app that uses the SAME flight data and video. When it works on one device, it must work on the other (unless you intentionally/accidentaly screw it up like in the last two or three releases of DJI GO 4). This is an engineering point of view, marketing will keep telling a different story if it helps boost the sales of larger and more expensive drones.
Also an update for JMR58, please read the following thread https://forum.dji.com/thread-121396-1-1.html. The important part begins in the middle of a second page. A confirmation for you and the others in Europe that if you are able to fly spark as far as you are, it's due to a fact that your phones are violating the CE standards used in Europe. Hopefully this will be resolved soon as well.
Well as I said why not return your drone because it’s suppose to have otg working, surely that’s the right thing to do it’s faulty so return, or is it because you work in IT that somehow your stuck with it.
The thread asked what is dji official position on otg, and that is it is not supported , that’s what they call plain simple English. |
