DJI Ocusync Air System Unbox
24017 34 2017-12-19
Mad_Angler1
Flight distance : 2741657 ft
The New Ocusync Air System for DJI Goggles Race Edition
This is a standalone Ocusync system from DJI, it allows you to fit DJI’s digital wireless video and control system to pretty much any thing you like,  Car, Plane or Multirotor this is a complete digital transmission system will transmit low latency video and control signal unto 7km and is specifically designed to be used with the DJI Goggles Race Edition.
Ocusync its able to transmit both control link and video over the same digital link, you simply connect your supported 3rd party radio directly to the goggles via the trainer port and the air end to your flight controller via PPM or SBUS and your ready to go, this avoids any interference caused by either system on the same frequency to give you a stable control and video link over great distance.
The system is also able to record your flight video directly on the Air End Module and/or onto the DJI Goggles for playback later.
The Air System
The Set consists of an Ocusync Air Unit, A Digital FPV Camera and Antenna Set.
OcuSync Video Transmission Module
The Spec
The OcuSync Video Transmission Module offers 2.4 and 5.8 GHz dual-band digital video transmission
Latency as low as 50 ms
Maximum control range of up to 7 km.
Up to 1280×960 HD transmission
Automatic Frequency-Hopping Spread Spectrum (FHSS) transmission
12 Selectable Digital Video Channels
SBUS & PPM Control Outputs
MultiWii - MSP Compatible Telemetry
3S-4S Input
Looking Over the Unit  Externally
Duel MMCX Antenna Connections on one side
Micro SD Card Slot for Recording onboard the Air Unit
Camera Input via a custom USB C port and Main Harness input for SBUS, UART and Power, the system supports connection to most common flight controllers such as most F3 or F4 based controllers, KISS or NAZE ext, basically any Sbus or PPM compatible controller, telemetry support is currently for MSP.
PPM Output and Micro USB for Updating Firmware
Size
Its size is 72 × 33 × 14 mm, W 43.7g, comparing its size to a standard 9g servo
Camera Module
The DJI OcuSync Camera has a 1/3'' CMOS Sensor with an effective 1.2M pixels, 2.65 mm, f2.0 lens giving a 148 degree FOV, it offers much higher resolution video transmission than most analog FPV on the market. It also uses a global shutter significantly reducing rolling shutter effect caused by high-frequency vibration.
It has 3 mounting post embedded in each side for fitment to the included bracket
Connection
It has a custom USB C Connection that is keyed
Compared To Runcam
Its size is 29.4 × 28.2 × 22.6 mm and weights 18.2g, its a little smaller than a Runcam Swift when compared together
Included cables and antennas adapters
RC Control cables for attaching you existing radio to the Goggles to send control over the Ocusync system.
DJI Support the following radio systems for connection via the trainer port
X9D (Frsky),DEVO 10 (Walkera), T8FG (Futaba),T14SG (Futaba), WTF09sll (WFLY), AT9S (RadioLink) via trainer port
Antennas
Included in the kit are a number of Antennas so you can choose the ones that best suit your needs
Pagoda
There are two Pagoda 2.4Ghz antennas, one RPSMA and one MMCX Connectors that are recommended for racing
The MMCX Connector
Duel frequency cylindrical circular polarization omnidirectional antennas
These are for both 2.4 and 5.8Ghz use
These are covered in a flexible rubber cover for protection
Dipole antennas
For close up flight in both 2.4Ghz and 5Ghz DJI have included this traditional omni sticks
The Complete Air End Kit
Overall I think  this is a very nice package to go along side the new Goggles RE,the Ocusync system is a real step forward giving us access to DJI’s wireless system in a small package for the first time.
The Complete DJI Goggles RE Kit costs  $859/£899 and includes a carry case
The New Goggles RE are also available on their own too and both are available from the DJI store
Over the coming weeks I will be testing this on multiple flight system such as the F3 and F4 based systems in both Quad and fixed wing, I will be updating this post as time goes one with more info and details on connections and setup ect on as many controllers as I can
Thank You.
2017-12-19
Thank you for sharing the review here, I believe it would be very helpful for many users.
2017-12-20
Mad_Angler1
Some wording info for the Air System
2017-12-23
Mad_Angler1
Some updates on this
2 Very long reviews and an update Video
Dji Goggles RE Unbox and walk through
Goggles RE Info update
DJI Ocusync Air-system Unbox, Setup and Walkthrough.
Goggles and Air System Latency
Ok I have done some tests and I can say that on the bench the latency on the Ocusync system is what DJI are stating and it’s extremely impressive.
I have tested it in multiple ways and it showing the below
These are taken in 480P
Phone 03.80
Goggles 03.75
50ms
Phone 04.60
Goggles 04.55
50ms
Phone 05.05
Goggles 05.00
Analog Latency
Analog latency test vs Headplay HD, IMO DJI Goggles is a shade less
Below are two frames that proceed each other, you can see that the both display at the same point, but the Dji Google’s look to be ahead a very little so less lag but this is very small, also see the video for your own decision.
Frame 1 just his start
This is the next frame
The video is below, to confirm this is Analog Speed Test compared to Headplay HD
I have also created some brackets for the Air system.
The first is an QR fracked for the Air unit so you can simply clip it in and out, the second is antenna stand for the MMCX Pagoda antenna when used with the extension cable, and finally the 3rd is an camera bracket that gives it some additional protection over the supplied one.
These are available on Thingiverse here https://www.thingiverse.com/thing:2739234
2017-12-31
fanscedcdda1
Mad_Angler1 Posted at 2017-12-31 04:07
Thank you for all the info and concise review! Amazing! I have the new goggles and ordered the Ocusync system with the intent on using it in an rc car. Two questions;
1. How would it get hooked up for power in a car? Can it connect through a receiver like othe accessories? I have an XMaxx for reference.
2. Other than through the goggles, is there another way to view the feed? Through the Dji App perhaps?
Thanks again!
2018-1-1
Carlos Samanieg
Chile
Mad_Angler1 Posted at 2017-12-23 18:06
Hi, please I need help to locate the Signal Ground. Thanks
2018-1-3
Mad_Angler1
Carlos Samanieg Posted at 2018-1-3 10:38
Rc Donal Ground is Brown next to the yellow.
2018-1-3
Mad_Angler1
fanscedcdda1 Posted at 2018-1-1 14:33
The system used 3-4 S so 12 -16.8V it’s gong. To need to be off a battery directly and not through a controller.
You can also bind the Mavic Pro Remote controler and then use a phone or tablet just like on the Mavic however you do not have RC Controls you simply have live feed via DJI Go.
2018-1-3
Carlos Samanieg
Chile
Mad_Angler1 Posted at 2018-1-3 16:49
Thanks, but where do I connect that cable, in my F4S? In your example, you connect to pin J6. But I do not know where to connect it in my F4S.
2018-1-3
Sbrintz
Flight distance : 657136 ft
I'm sorry for my ignorance!
Is it possible to connect the OcuSync with the CrystalSky and manage it from this device?
Thanks!
2018-1-8
Elektrica
Flight distance : 9674836 ft
Hi, is there an standalone battery you can suggest for powering the system? I cannot seem to find that information anywhere. Thanks!
2018-1-8
wpfreund
Flight distance : 14767 ft
I'd really like to 3D print that white air module clip pictured to take my unit in and out. Could you provide a 3D template/file for that so I can print my own? Thanks.
2018-1-15
Maxheadspace
Thanks for the review and connection details, pinouts, etc.  When I look on DJI.com, I do not see the complete Ocusync package, all I see are the individual components.  I tried the search feature, but no luck.  So, other than purchasing the complete Ocusync package as a bundle with the Goggles RE, where can I purchase the complete Ocusync set?  I already have the Goggles RE for use with my Mavic.
Thanks!
Max
2018-1-15
ucakar
Slovenia
Maxheadspace Posted at 2018-1-15 18:24
Thanks!
Does anybody know if  it is possible to get Eagletreesystems Autopilot Vector telemetry on Occusync HD link?
http://www.eagletreesystems.com/ ... &product_id=148
Thanks,
Andrej
2018-1-16
ucakar
Slovenia
Thanks!
You can buy here complete package:
http://www.kopterworx.com/dji-go ... nit-system-set.html
Regards,
Andrej
2018-1-16
Wilhelm.dutoit
Namibia
Sbrintz Posted at 2018-1-8 14:03
No you cant.
2018-1-17
Wilhelm.dutoit
Namibia
wpfreund Posted at 2018-1-15 06:41
2018-1-17
Wilhelm.dutoit
Namibia
Thanks!
Hi Max,
DJI dont sell it seperatly. The only place i could find is:
https://www.amazon.com/dp/B078NL ... 1WXHTHBVR&psc=0
I haven't ordered mine yet though.
2018-1-17
Carlos Samanieg
Chile
Carlos Samanieg Posted at 2018-1-3 18:01
Hi, this configuration is working OK.
This is how the pins on the CLRACING F4S fligth controller are connected.
2018-1-18
djiuser_16u0VMH
Hello, does the head tracking from the goggles get pushed through the sbus channels to the flight controller?
2018-1-18
Iketh
Can I use Hero6 hdmi output instead of included camera?
2018-2-11
Mad_Angler1
Air System Head-tracking Setup
[size=23.979999542236328px]
2018-3-11
gtoews
Flight distance : 282159 ft
Any one know if I can use the Devo7e transmitter?  I know the Devo10 is listed, there shouldn't be any difference other than telemetry support.  Also what is size of the camera?  Exact same a runcam swift?  I'm wondering if I can fit this all into my Kopis 1 5inch.
2018-3-25
gtoews
Here's another, can the camera be mounted 90 degrees rotated, then transformed/corrected elsewhere?
2018-3-25
Kodachrome
I have a very basic and possibly dumb question. I bought the DJI Google RE kit to add FPV to a DIY drone I'm building. FC is a Quadrino Nano and TX/RX is the FRSky V8.
What exactly is the point/benefit of connecting the Signal, UART up (if possible on the Quadrino, I know it has SBUS support of some sort)?  I'm just kinda confused as I cant see what this has to do with HD video broadcast and reception...
2018-5-15
Mad_Angler1
The UART is for telemetary data on the display.
So Sbus is of your going to use the inbuilt transmitter in Ocusync, remember if your using a 2.4Gjz radio controller you can’t use the Air system on 2.4 GHz too as it will completely cost out your RC singnal in no time.
So the alternative is to either put the Air system in 5Ghz that will give reduced range or use the built in system by connecting your radio to the Google’s RE via the trainer port and then the Sbus to your F.C.
The UART connections are socyou can see telemetary from your F.C. on the Google’s display.
2018-5-15
Kodachrome
Mad_Angler1 Posted at 2018-5-15 15:18
Great thanks, that clears up that part.
I have a more "interesting"  follow on question that I just cannot comfortably answer with google.
- To use the Ocusync for RC control  via SBUS on my Multiwii based (Quadrino Nano) controller I just need to connect up the Ocusync Air mobule SBUS connectors to my Quadrino Nano AND connect my FrSKY powered Turnigy 9x transmitter (trainer mode) to the RE Goggles - correct?
If so, what happens to the FrSKY Receiver on the quad? Its a PWM receiver and doesnt receive or understand SBUS. Same as the Transmitter, its a DJT module which is PWM only.  Does the RE Goggles transcode/convert the RC signals to SBUS and therefore I dont have to scrap my existing build TX/RX AND can remove existing receiver from the quad?
If thats true, then how do the ESC  get their signals? I presume these are PWM too..
2018-5-17
luciens
That's right. The existing receiver simply goes away. Its function is taken over by the R/C link in ocusync - it's transmitted out through the antennas in the goggles along with the video downlink. The control signals are inputted to the goggles via the trainer cord and the air unit supplies them to your flight controller via SBUS.
The nifty thing is it removes the entire extra R/C radio link of your transmitter and RX, which greatly simplifies the whole system.
The bad news, though, is the ocusync R/C link has a lot of latency. Presumably because the trainer port -> goggles connection is probably PWM or something like it (which I think most trainer port connections are on the typical R/C radio) and then there's likely the additional latency of digitizing it over the ocusync protocol. So you will notice more latency over against just using your FrSKY 2.4ghz R/C setup and the ocusync video by itself...
So don't throw away your FrSKY receiver until you test the ocusync R/C link for latency. On a small racing drone it might be too much. On my F550/Wookong FC, it's enough to notice over my former Futaba 7-10ms latency R/C link, but not enough to interfere with flying it, so I just use the ocusync....
2018-5-19
Kodachrome
Excellent news thanks. Im hoping to connect it to a Hunter VTail 500 with big props and motors, so not a racing drone by a long shot!
Next challenge is seeing if the MultiWii based Quadrino Nano FC can take these SBUS signals. Lynxmotion claim to support only the Futaba brand SBUS.. confusing.
2018-5-20
TannaLDietrich
The world moves on technology that we can see everywhere as a proof of development. In this way, Ocysync system makes a wireless video and bearing many features like control of low latency video and low signal video. That invasion is very useful in 3D printing technology development because it saw many scopes and another side is service area of the printer business are getting more advanced.Ricoh printer support is planning to use this technology for giving better service to their clients
2018-6-21
Adrian Bear
Great review and video's, 1 quick question...whats the best antenna orientation for dual 5.8/2.4 Ghz and how do we get them oriented if we can't bend the shafts?
2018-7-7
Adrian Bear
FYI, I've had issues with the ppm out port, so reverted to using SBus.
Adrian
2018-7-7
Mad_Angler1
Adrian Bear Posted at 2018-7-7 17:25
Ideally you want to have them in a rabbit ears setup or like a V, as for how that is the challenge unfortunately.
2018-8-6
gtoews
Thanks for all the great info.  Are you sure the pagoda antennas are not for 5.8Ghz only?  I think so.
2019-5-21
gtoews
2019-5-21
