CycleParadise
Flight distance : 385338 ft
fans9553217f Posted at 2018-1-5 09:59
Have you users ever considered that it is not the app or the device or the drone at fault? All the apps, devices and drones are the same as everyone elses. The fault is more likely what you have on your device. Android is plagued by the trivial and rubbish apps that users load on to their devices. Always remove unnessary apps from the device you use to control the drone. Also, kill all running apps and systems before running the go4 app. This will ensure maximum memory is available for the drone app to run with. Apple devices have an advantage here because crap apps are largely prevented from being used. You can free more memory by switching storage to an sd card on the device. Not all apps let you do this but it is still worth doing for those that can be moved. When you record your drone video and snaps, a low res version is stored on the device. This uses vital memory and can cause flight issues.
Exactly!!
I think that's why DJI only lists a handful of supported devices. Even the listed devices have issues. And there are plenty of unsupported devices that have no issues.
As you mention, I think a lot of it comes down to what's been loaded onto the device. And not just by the end user but by the manufacturer and possibly phone carrier. |
