15 Tips For Beginner Drone Pilots
14609 55 2018-1-18
DJI Grace
Flight distance : 405039 ft
Congratulations on being a new drone pilot! We all understand the excitement of getting a new drone. But don’t rush into flying just yet! It’s relatively straightforward to take off, but do you know every button’s function or have a good understanding of how your drone reacts to the remote controller? Before you head out and get it in the air, you should know your drone well.  As it’s the best way to prevent crashes and flyaways. Furthermore, it’s being responsible for the safety of yourself, others, and your drone.
Operating a drone can sometimes be tricky. So to avoid any silly missteps, it’s essential to read the product’s manual and get familiar with DJI’s GO apps and pay close attention to preflight preparations . After you understand your drone’s capabilities and limitations choose a safe test flight zone and practice some basic maneuvers before you take the leash off. Additionally, remember to take advantage of free online resources.
Here, we’ve summarized 15 tips to help first-time drone pilots prepare for their air adventures.
Practice makes perfect. Enjoy the learning process and have fun flying! And one more thing, don’t forget to inspect your drone regularly and store it properly.
The content origins from :BUYINGGUIDES
2018-1-18
Lee Moon
Flight distance : 61850 ft
Thank you for posting these tips! I'm truly enjoying my Spark.
2018-1-18
Woe
Flight distance : 4129268 ft
This should be part of the introduction to new pilots after activation.
2018-1-18
Spaceman_66
Flight distance : 82323 ft
Woe Posted at 2018-1-18 21:25
What he said! Sumpin’ like this should be in the box / manual for sure, even if just a link!
2018-1-18
AlexVideoShark
Flight distance : 4705049 ft
well done...
this with the guide of the manual djigo app ... ( https://forum.dji.com/thread-118397-1-1.html )
they are always very useful
thank you
2018-1-18
A CW
Flight distance : 14754314 ft
Excellent info for all new pilots.
2018-1-19
DJI Grace
AlexVideoShark  Posted at 2018-1-18 23:57
well done...
Really hope that you guys would enjoy it !
2018-1-19
Samoth
Flight distance : 95640 ft
Good thing I read it: my first objective was to run into an obstacle...
Thanks for reminding me that it might be a bad idea
More seriously, I hope it will help some people
2018-1-19
Again a great tutorial!
2018-1-19
Genghis9
Flight distance : 961 ft
There is a disconnect with one part of this guidance, at least for the Phantom 4 series when it comes to your guidance about performing a compass calibration, stating to do one as it is essential before a flight.
According to the manuals for the P4S pg 56 and P4P pg 57 it clearly states to only calibrate the compass when the GO 4 app says to do so.
You either need to qualify your guidance or change the manuals.  It is best that you do not perform unnecessary compass calibrations as it only increases the likelihood of introducing error in to the system.
2018-1-19
GoldenSun
Flight distance : 681903 ft
Great tips for beginners!
2018-1-19
Donnie - Apple
Flight distance : 3636782 ft
One tip I will addd is on the RTH setting , make sure it is higher than any  obstacle in the flight area but Not much more than that , many times if the RTH is activated you may have a low battery as well and you don't want to have any unnecessary altitude  as this just drains the battery power  and increases flight time where you may not have the luxury of extra time. ( that was one long sentence !)
So bottom line set the RTH height at about 5% -10% above the Highest obstacle in your flight area and no more .  Trust me on this as this advice comes from experience.
Also after any update to your system  be sure to check all the TAB settings as sometimes setting values  can change back to the defaults.
donnie
2018-1-19
e-kitiran
Flight distance : 32680 ft
Indonesia
Thanks, print on large paper and stick on my wall.
2018-1-19
WolfgangStiller
Flight distance : 599416 ft
Nice. Glad to see this at the top. That should really help many new pilots.
2018-1-19
KedDK
Flight distance : 1133038 ft
Addition the the "Check weather conditions"point, do not fly against the sun or in strong light.
2018-1-19
Langner91
Flight distance : 3474 ft
Good stuff!  I appreciate the reminders.
2018-1-19
Papa Ski
Flight distance : 90272 ft
Great advice for new and old pilots.  I would add to the list:  "When in doubt, return home and regroup."  (This can be manual or the RTH button depending on your comfort).  Reading through these forums it appears a lot of accidents happen because people see/hear warnings and then push the envelope a little further.  Easy for me to say, but hard to do in the moment.
2018-1-19
Flight distance : 10186312 ft
Genghis9 Posted at 2018-1-19 04:19
Correct and it is the same in all up to date manuals.
2018-1-19
Genghis9
hallmark007 Posted at 2018-1-19 10:03
I thought as much but I have not gone through them to know for sure...
It makes sense, as why would you change it for one and not the others since the procedure and systems are nearly identical.
Copy all
2018-1-19
Brambleman
Flight distance : 20627 ft
This guide says that to calibrate the compass before every flight, but in the Spark forum it has been repeatedly stated by moderators that you should not calibrate unless you are prompted to by the application. Which is the best advise for my Spark? Calibrate every time? Or only when it tells me to?
2018-1-19
Genghis9
Brambleman Posted at 2018-1-19 12:52
What does your manual say...
2018-1-19
fans7bfe1625
Flight distance : 61309 ft
Thank you great tips
2018-1-20
FlyinMajic2day
Flight distance : 361552 ft
Great Tutorial! I actually read and watched videos for hours before my first flight! Loving my Spark I received from brother as a Christmas gift. This forum has been very helpful..Thank you as I continue learming.
As far as Compass Calibration, this is what I understand..
Only calibrate the compass when the DJI GO 4 app or the status indicator prompt you to do so. Observe the following rules when calibrating your compass:
DO NOT calibrate your compass where there is a chance of strong magnetic interference, such as near magnetite, parking structures, or steel reinforcements underground.
DO NOT carry ferromagnetic materials with you during calibration such as cellular phones.
The DJI GO 4 app will notify you if the compass is a ected by strong interference after calibration is complete. Follow the prompts to resolve the compass issue.
hope this helps
2018-1-20
Yasser & Amir L
Flight distance : 2728986 ft
Tips that will be useful to many beginners for sure!
2018-1-21
Donnie - Apple
I only calibrate  after firmware updates or if the machine starts flying out of character ( you learn this over time what is and is NOT normal). Also if you travel more than 150 miles from the last point of compass calibration.  It is not so much the distance as it is North -South ( or vice versa )  Travel but the  150 miles is a guideline.
So bottom line do it once and with success and then only on occasion , doing it before each flight is asking for trouble .
donnie
2018-1-21
TIm b
Great advice.  had my phantom 4 pro i day and crashed it.  £800 later............  My mistake was two fold.   i read the instructions played on the simulator took my time with the first flight and all went well.    Then i got over confident as i learnt the controls fairly easily, or so i thought!  decided to do a sprint home and didn't look behind me.  The rest is a very expensive lesson.
so don't assume you can't fly this thing effectively because you have worked out which is forward and reverse on your controls.
very good footage of a drone crash though
2018-1-21
CoreyB10
Flight distance : 1665023 ft
The manual should be included in the box and not just the quick-start guide. Always found that strange. It would encourage people to read it instead of downloading it online 1st. Bit like getting a new car with no operating guide really.
2018-1-22
Linny&HerSpark
Flight distance : 20830 ft
Great post. But I am curious about one thing: Under Set Return to Home (RTH) Altitude it mentions you can set a distance and altitude limit to prevent flyaways. How does doing that prevent flyaways? Does the drone just stop and hover when the limit has been reached?
2018-1-22
FatherXmas
Flight distance : 4058619 ft
Very nice, any chance of making this a downloadable PDF?
2018-1-22
DJI Grace
FatherXmas Posted at 2018-1-22 14:15
Maybe you can use screenshot to record it!
2018-1-22
DJI Grace
test test test
2018-1-22
Dorset_Horn
Flight distance : 93379 ft
Most helpful !
2018-1-24
Easy Ed
Flight distance : 41414 ft
nicely done - thanks for sharing.
2018-11-2
darkfull1
Flight distance : 13114 ft
I just started with my Spark and these tips are really good.
2018-12-28
pianoplayer7
Flight distance : 259055 ft
Thanks for the tips!
2019-1-3
Master.
Flight distance : 623432 ft
I guess most people try to fly their drone indoor when they first got it. LOL
2019-1-13
RockytheSquirrel
Great tips.  Thanks for posting!
2019-1-31
Eick willson
Sri Lanka
This is Truly great, I learned lot of tips from here.
Tutuapp
2019-2-1
smartuser
Philippines
I cant believe that flying a drone is that easy. I hope you can also customized drones easily according to codes
Website
2019-5-31
Miro Perez
Flight distance : 25374 ft
Great tips
2019-8-24
