Mavic air propeller issue?
9185 78 2018-2-1
Kyle Stones
Flight distance : 36 ft
Took my new mavic air out for its maiden voyage and heard some weird noises when it was trying to take off and it seemed like it hesitated and then it took off and I could still faintly hear it. Landed it and checked the props and the rear two props were rubbing against the body of the drone and chipped the edges of the props (see photos) it doesn’t seem normal but the white lines by the edges are a little deceiving as if it’s supposed to wear it down a bit
2018-2-1
djiuser_YGXnharQYfpn
Sorry to read and see that! Ouch!!! I have to say mine has no such issues. Just standard go 4 app hating android
2018-2-1
FlyDK
Flight distance : 1636286 ft
That's a bummer.
2018-2-1
A CW
Flight distance : 14754314 ft
Are all of the props you received like that?
2018-2-1
drown84
Flight distance : 176312 ft
Only way for that to happen is if the propeller or propeller shaft was severely bent..looks like there is about 5mm or so of clearance from the blades to the top of the mavic air.
That being said, this is the first drone I have seen with such a short "leg" span. I wonder how much it effects efficiency/lift that a large portion of the spinning blades are spinning over the body instead of free air.
2018-2-1
FlyDK
A CW Posted at 2018-2-1 15:16
The propellers became such after rotating on the drone. They hit the body ... not good.
2018-2-1
Kyle Stones
The front props are fine, and the extra props from the fly more combo are all fine. They were fine before I flew it, once I heard the noises I knew something was off so I landed it and noticed the chips to the propellers and some nicks on the body of the drone where it was making contacf
2018-2-1
A CW
Kyle Stones Posted at 2018-2-1 15:25
Sorry - I missed your opening statement. Thats not good! This would be a DOA unit IMO - I strongly suggest you return it to DJI for a brand new replacement asap
2018-2-1
FlyDK
More pics of the body please. DJI will ask for them anyway and it should definitely be switched to a NEW one.
2018-2-1
A CW
FlyDK Posted at 2018-2-1 15:25
Not good indeed!
2018-2-1
Flight distance : 10186312 ft
I agree with AC W, you unfortunately have a DOA something not aligned correctly, you could try another set of props.
2018-2-1
PS013
Flight distance : 3579409 ft
Normally, the blade should be about 1/8 of an inch ( 2 mm ) above the top of the body, and of course should not touch.
Also, I noticed that you did not remove some protective stickers from the body, Is it possible that one of them was catched by the prop ?
2018-2-1
Kyle Stones
FlyDK Posted at 2018-2-1 15:28
The red circle is one side and the yellow circles are the other side.
I could try the other props but I would like to hear back from DJI and ideally send it back before I’ve had it for long enough for them to blame it on the operator
2018-2-1
Kyle Stones
PS013 Posted at 2018-2-1 16:02
The stickers are still flush with the body, so not likely
2018-2-1
Wachtberger
Flight distance : 261509 ft
Are you sure the legs/wings were fully expanded? What has happened suggests that this might accidentally not have been the case. As I haven't received my Air yet I can't say more. But I would expect some point of resistance that you have to go over until they lock in their final position for flight.
2018-2-1
Kyle Stones
Wachtberger Posted at 2018-2-1 16:06
Tough to say after the fact now that it’s packed up, but I pushed them out to what felt like fully extended
2018-2-1
Wachtberger
Kyle Stones Posted at 2018-2-1 16:09
I suggest you try again and check what the distance to the body will be then. Maybe you have been too gentle/reluctant to push a bit further.
2018-2-1
Kyle Stones
I just took it out to check something and with the rear legs they won’t let them not be fully extended, they sort of snap into place once you’re past halfway extended. If that makes sense.
2018-2-1
PS013
I added a picture of my props  in post #12 ...
2018-2-1
PS013
Wachtberger Posted at 2018-2-1 16:11
In fact, the way the leg fold, you will have to push VERY hard to bend the leg enough so it can touch. So that is quite unlikely.
It looks like the prop was not shaped properly. maybe you can compare with one of the spare you have.
2018-2-1
Wachtberger
PS013 Posted at 2018-2-1 16:15
Exactly, your last picture in post 12# shows how it should be. In that position they cannot touch the body. No idea what might have gone wrong before, but I hope that DJI support will assist you well with this.
2018-2-1
Wachtberger
PS013 Posted at 2018-2-1 16:17
It's not me, it's PS013 who has had the problem. I was just trying to figure out what might have happened. And the latest picture seems to confirm that the legs might not have been fully unfolded when the incident has happened. And I am not saying that this was users fault, it can have been a malfunction of the mechanisn as well.
2018-2-1
PS013
Wachtberger Posted at 2018-2-1 16:25
Just to avoid any confusion I do not have the probolem
The 2nd picture in post #12 in my own Mavic Air, not Kyle's.  ;)
2018-2-1
Wachtberger
PS013 Posted at 2018-2-1 16:29
Oh sorry, it was the first picture in your post 12# that has made me believe it was you. Apologies for the confusion caused.
2018-2-1
Tviscomi
Flight distance : 106886 ft
I read about this same thing happening with the MP flying in Sport Mode on 2 separate occasions.  The pilots had attributed to the arms flexing when flying at high RPMs
2018-2-1
Kyle Stones
Tviscomi Posted at 2018-2-1 16:47
Haven’t even thought about leaving beginner mode yet haha
2018-2-1
Kyle Stones
I could see one prop not being shaped properly, just strange both of the ones in the rear were rubbing
2018-2-1
G_Sig
Flight distance : 9109311 ft
Iceland
How is it packed in the box? Could the props have been pressed for some time?
2018-2-1
Wachtberger
I am very sure now that for whatever cause the legs were not fully unfolded.
2018-2-1
AIister
Flight distance : 626647 ft
why dont you slowly unfold a drone and see if the prop can touch at any time during the unfolding.. why speculate ?  rrrrr
2018-2-1
cyborg
Flight distance : 123960 ft
from the pictures the nick on the body is next to the air vents, which means it is caused by the rear props. The rear arms needs to be pushed down from the body to fully extend, which means if the arm is not fully extended the props will stay further away from the top (air vents) of the MA. The only way it can get so low as to touch the body is if the arm is bend the wrong way by putting too much pressure, or the props are bend. This mostly looks like bend props..
2018-2-1
Sorry to read on this. I have now forwarded your case to our engineers to check and confirm. May I have a short video about the rear legs unfolding? And could you please provide me with your drone's serial number? Appreciate your help.
2018-2-1
PS013
Wachtberger Posted at 2018-2-1 17:04
Once you receive your Mavic Air, you will realize that if the leg is no unfold completely, the prop is further away from the body, not closer.
2018-2-2
Wachtberger
PS013 Posted at 2018-2-2 08:13
Yes, I have received it today and fully agree with you. My assumption was wrong but what has happened with Kyles Air is really weird. Both props would need to be significantly bend for this to happen. I hope the cause can be identified.
2018-2-2
PS013
Wachtberger Posted at 2018-2-2 08:41
Congrats on your new bird !! Welcome to the hair club ;) ...
2018-2-2
Wachtberger
PS013 Posted at 2018-2-2 09:41
Thanks a lot, this machine is just so great! :-)
2018-2-2
DJT_MVSP
Flight distance : 2018645 ft
Kyle Stones Posted at 2018-2-1 16:02
One of the prop looks bent on the last photo.It could have bent when you stored the Air
2018-2-2
M2Wair
Flight distance : 1192231 ft
Wachtberger Posted at 2018-2-2 09:49
Yes indeed, took mine up for a quick flight today, very impressed to say the least. Perfect little travel drone.... That said I must be due a holiday somewhere warm, free of rain and high winds. I can hear the Mediterranean calling me, better take the wife too I guess.
2018-2-2
Wachtberger
M2Wair Posted at 2018-2-2 10:08
Very good idea! :-)
2018-2-2
Hi, I got your PM and I will wait for your update, you can upload the video to Dropbox and PM me the link. Thank you so much.
2018-2-3
