Genghis9
Bashy Posted at 2017-12-28 22:29
Hey folks, as i mentioned earlier in this thread that i use mode to and occasionally use the wrong stick, Yesterday was no exception, this time it was the right stick, i was hovering over a field at about 4m and i pushed the stick go up, (heres the rookie mistake) my mate said sommat and i looked at him at the moment i pushed the stick, when i looked back at the screen i saw that i was skimming the earth at 4m high, luckily i was in a field and also was going away from me. normally i am accidentally pushing left stick to go forward instead on up an down...
So, what should i do, what would you do, swap the sticks round, left stick to turn and go back and forward and right stick up and down and left and right or is it too late seen as ive used mode 2 for a couple of months now? i could end up in the same boat now i suppose and whos tell if i had set it the other way i would be doing the same blooming thing.
Well
While I don't have any long time experience with RC flying, I'd consider the following.
Look for consistent trends as you go along and learn. Nearly everyone is capable of learning and adjusting to these controls, but it takes some time and some can take longer than most. However, if as you go you are making the same constant mistakes over and over again then that is when I'd consider changing the mode or customizing the layout. At present you are describing common mistakes that many make and they don't appear to be consistent in nature.
Fly safe fly careful and practice... |
