My battery's pins burned, my guess is after a charge, but I was still able to fly on them. The problem is, is that it's giving me occasional "Battery Signal Errors" In-Flight. I have not flown on this same battery after the moment I noticed it, being smart . But this 1 out of the 2 batteries I have so is there any chance that I can send it to DJI to be fixed or something? I have not been using any 3rd party chargers, only disclaiming that because I know other's are going to ask .
I have had this happen to mine also, look in the drone and see if it is also melted a little mine was. It looked a little melted and was not letting me plug it all the way in (Just tiny bit out) DO NOT FLY WITH IT!! I think it comes from the battery plug not connecting with plugs in drone. I know it was all way in and snapped in place! Mine was melted in when it shut off in mid air and fell to ground
Big Popie Posted at 2018-2-9 09:18
Unless you have DJI Care or the battery is pretty much new... to be frank, don't bother.
I sent a P3 battery in only after I had emailed beforehand to verify it could be repaired. Short story, many emails and lots of exasperation and ultimately told it couldn't be fixed. Even more emails and exasperation before I could get them to send it back. The whole ordeal here.
It also may have burned the board in the drone, it got very hot, you need to get the power board in drone replace, problem may started with that power board in battery connector in the drone.
Dog Man Posted at 2018-3-10 12:07
This is good advice. The 'burning' you report is caused by a poor connection between the connector pins in the battery and the pins in the charger. Any dirt or contamination can lead to poor connections, and those connections heat up. The only cure is to replace the connectors. Unfortunately the P4 connector system is a bad design compared to the previous P3 system.
