LoSBoL
Flight distance : 666483 ft
S-e-ven Posted at 2018-2-14 11:23
Again, the Spark has a limited gimbal, too.
And it 'nods', as soon you speed up in sport.
But after some seconds the cam comes back up.
Yes, you've got a clear point aswell, tucking away the camera has it's pro's and con's, the con being it has limited gimbal tilting capabilities. It's not a 50 dollar drone, but it isn't an 1500 dollar drone either. As for the sideway tilting, I got this test from https://myfirstdrone.com/blog/dji-mavic-air-vs-mavic-pro
Speed
The Mavic Pro will go over 40mph, but so can the Mavic Air. Many people would end the comparison there, but that wouldn’t tell the full story. The max Speed in sport mode is only one measurement, but the real maximum speed will change depending on how you’re flying. This is why we tested the max speed in almost every situation we could think of (not just Sport mode).
In Sport mode both drones go around 40mph. When you are controlling both of them with just a smartphone, there’s a huge difference in speed. The Mavic Pro will max out at 7mph (with obstacle avoidance off and the Mavic Air will do 16mph with APAS enabled. That means the Mavic Air would be a much better choice if you want to just use your phone to fly. When using a controller, both drones go 20mph, but if you disable obstacle avoidance on the Mavic Pro, it will go almost 30mph.
Gimbal speed is another thing that most people don’t talk about. While both drones can go up to 40mph, that doesn’t mean that you will be able to look straight ahead at that speed. The Mavic Pro starts to tilt the camera down at 30mph when going forward, however when you’re flying sideways you can go up to 40 without the gimbal reaching its limit.
The Mavic Air has a gimbal design that is closer to the Spark, and because of that it has a very limited range of motion. You can only go about 20mph in any direction before the gimbal reaches its limit. The only way of going faster while still looking forward is to fly backwards.
