LeBT
Vietnam
I have exactly same problem: after opening box, upgrade firmware, connect by wifi, then cannot link again RC with drone.
I think the problem is from the new firmware. I guest the reason of the problem is follow: different countries have different regulations, etc. in radio frequency domain. So in some countries, when your drone/RC detects the location by GPS, it will switch to the radio frequency settings for that country. When you connect by wifi, it will lost information of pairing (frequency) between RC and drone. So when you re-link your RC and drone, both RC and drone will scan only in the frequency range permitted by your country (radio frequency settings preset in the firmware), and here the bug comes. May be due to the restriction of frequency range, RC frequency scan and drone frequency scan cannot match each other (when they are scan, the drone's arm-leds will red flash and the RC will beep beep).
I did not try yet fans24dcb42d's solution (because my lovely seller exchange a new Mavic Air for me ), but I think it will be ok. |
