Phantom 4 pro Recording video of inverted
7087 160 2018-1-19
RZAS
oi;
Eu não recebi a versão beta.
Já passei 2 emails e não está disponivel a atualização.
rafaelzas@gmail.com e singularagro@gmail.com
Aguardo uma resposta.
Estou precisando urgente desta atualização, pois utilizo o drone para trabalhar.
obrigado
2018-2-28
RZAS
RZAS Posted at 2018-2-28 05:33
oi;
Hi;
I did not receive the beta.
I already have 2 emails and the update is not available.
rafaelzas@gmail.com and singularagro@gmail.com
I await an answer.
I am in urgent need of this update, as I use the drone to work.
thank you
2018-2-28
waterglobe
Flight distance : 1596381 ft
I also have the problem with inverted picture when taking photos straight down. Also, the colors go bananas and can't be corrected all the way afterwards - red becomes blue for instance.
I fly a P4P.
Any solution to this problem yet?
info@waterglobe.net
2018-2-28
VCF
Flight distance : 199787 ft
DJI Thor Posted at 2018-2-28 02:14
Hi, I had forwarded the beta once again. If you are still not able to catch the beta, please kindly register another DJI account just for accessing the beta. Thank you so much.
Hi again Thor:
This is the Assistant 2 I see each time I connect the P$P, as you can see the session is open in my account. I don´t konow if this is an account issue or other thing, Can you help me?
Thanks in advance.
Carlos
2018-2-28
WInged Eye
Flight distance : 1077618 ft
Thor,
The beta firmware is still not showing up in my new account or old one. Ideas?
2018-2-28
VCF
Problem solved. Just download DJI Asistant 2 v1.2 (my instaled versión was 1.1.2), install it and ¡¡voila!! the firmware list apeared with the beta version. Now installing. I hope this beta will be stable and solve all the last issues.
Thank you Thor for your help
2018-2-28
WInged Eye
I wish it were that simple. I've been on 1.2 through all of this.
2018-3-1
MariusLtu
Flight distance : 632641 ft
Can I get beta firmware? I have inverted camera and orange/yellow color problem too. My email marius0126@gmail.com
2018-3-1
Mark_007 Posted at 2018-2-28 03:27
Thank you. Will let you know how it goes.
Think it will work. Looking forward to your reply.
2018-3-2
waterglobe Posted at 2018-2-28 06:07
I fly a P4P.
Yes, I had forwarded the beta, please check your account, see if it works.
2018-3-2
MariusLtu Posted at 2018-3-1 10:03
Had forwarded the beta, please check your account. Thank you.
2018-3-2
Carlos, could you please try to reinstall the DJI Assistant 2 or try another PC? Or you can also try to check if the DJI GO 4 app has the update notification. Make sure that the internet connection is available. Thank you.
2018-3-2
VCF Posted at 2018-2-28 14:03
Thank you for your update and glad that you got it worked. Cheers.
2018-3-2
RZAS
Dji Thor
Please help me
I have been waiting for this beta update for days and it did not appear in any email.
I already reinstalled DJI Assistant 2.0 and it still did not work.
The DJI GO 4 application also does not appear anything.
I do not know what else to do.
2018-3-2
RZAS
Hi;
The update appeared here.
Thank you.
Today I will test and comment here.
2018-3-2
MariusLtu
Can you forward to marius0126@gmail.com again? Not showing up in DJI Assistant at the moment.
2018-3-2
Mark_007
Flight distance : 28497 ft
DJI Thor Posted at 2018-3-2 02:44
Thor,
I received beta .301 within 24 hours. Has fixed inverted image. thank you!
2018-3-2
Velocity35
I too am experiencing this issue. DJI could you please send me that beta file. zach3585@yahoo.com is my email. Thank you!
2018-3-2
RZAS Posted at 2018-3-2 04:17
Hi;
I am relieved, glad to know that you finally got it. Think it can solve the issue. BTW, would you mind telling me how did you get the beta? On DJI GO 4 app or DJI Assistant 2? It seems some users also encountered the same issue.
2018-3-3
MariusLtu Posted at 2018-3-2 08:18
Yes, the beta sent again. Please make sure that you have internet connection, or try to sign in the account again. Hope it works.
2018-3-3
Velocity35 Posted at 2018-3-2 19:05
I too am experiencing this issue. DJI could you please send me that beta file.  is my email. Thank you!
Yes, the beta has sent, you can update via DJI Assistant 2.
2018-3-3
RZAS
DJI Thor Posted at 2018-3-3 03:31
I was able to upgrade in DJI Assistant 2.0
It was available to me yesterday.
I tested the Phantom 4 Pro and everything is ok. The camera went back to normal.
Thank you!
2018-3-3
fans61a3d615
Flight distance : 84108 ft
Colombia
Hi, can send me the beta too? thank you
fejorca@gmail.com
2018-3-3
Avian UAS
Flight distance : 76191 ft
DJI Thor Posted at 2018-1-20 23:58
Hi there, may I have your DJI email account? I would like to forward a beta for you to try.
Yes please send me the beta to try
email: trickyflix@gmail.com
2018-3-3
Avian UAS
DJI Thor Posted at 2018-2-23 01:55
Hi dear all, I am terribly sorry for the late reply for some reasons. The accounts provided above should be able to access the beta, please check your account, you can upgrade the firmware via DJI Assistant 2. Please kindly let me know if you haven't received it. Thank you.
Hi DJI Thor,
I have asked for this BETA a number of times on this thread. I need to fix this error for my work as i am professional aerial photographer.
My email is trickyflix@gmail.com
PLEASE SEND ME THE BETA FILE!!
2018-3-3
Avian UAS
DJI Thor Posted at 2018-2-27 03:52
Hi there, accounts provided above should be able to access the beta. Please let me know if you haven't received it, please kindly click the "Reply" button to reply me so I can receive the notifications. Thank you.
I have not received the firmware in my account.. this is 3rd time Im asking for this firmware in this thread... PLEASE PLEASE PLEASE send the firmware file to my account:
2018-3-3
Kereplaz
Flight distance : 1846736 ft
Lithuania
Hello im having the same issues with my P4P and it is unacceptable. We need more that just a beta ASAP, this is very disappointing and it ruined my last shoot. Id like to be informed when a solution is available, my email is: lukas.zmejevskis@gmail.com . These kind of things make me consider other solutions than DJI, it is very demotivating.
2018-3-4
Velocity35
DJI Thor Posted at 2018-3-3 03:36
Hi DJI Thor. I checked in DJI Assistant 2 (v1.0.8) and I did not see the beta file. Could you please send the beta file again?  My email address again is zach3585@yahoo.com
2018-3-4
Velocity35
Velocity35 Posted at 2018-3-4 10:57
Hi DJI Thor. I had to update DJI Assistant. It's now up to date and I was able to see the beta file. thank you.
2018-3-4
SergioDenisenko
Flight distance : 419098 ft
Please, let me beta ...
same problem
acc: scamp@yandex.ru
2018-3-4
dddarche
Thor or Susan, I sent a PM, but will also post.  I am having the same problem.  Will you please give me access to the beta version?  My email is ddarche@yahoo.com.  Thank you.
2018-3-4
Avian UAS Posted at 2018-3-3 15:08
email:
Sorry for the late reply, Chris. I had forwarded the beta to your account, please check and let me know if you haven't received it. Thank you.
2018-3-6
Hi all, the accounts provided above are able to access the beta now, please try to update via DIJ Assistant 2, let me know if you haven't received it. Thank you.
2018-3-6
RZAS Posted at 2018-3-3 04:19
Glad to hear that, mate. Should you have any further questions, please feel free to contact us. We'd glad to help.
2018-3-6
SergioDenisenko
DJI Thor Posted at 2018-3-6 01:07
not have
2018-3-7
I had forwarded it again, please try to refresh the list. If it still doesn't exist, I suggest applying another DJI account just for accessing the beta. Thank you.
2018-3-8
Developer_Mode
Hello
i have strong Jelly efect, you cant sent the firmware to my account?
javihost@gmx.es
One million of thanks!
2018-3-17
Serifina
Flight distance : 80659 ft
I also have inverted video, please send beta firmware.  rootsvt@gmail.com
2018-3-29
Overnite
Flight distance : 148327 ft
Just found this thread, thought I was having transmitter errors. Image flips and having crazy color swapping issues. Thanks DJI! Of course it's firmware update issues! Phantom 4 Professional  ???
Send the beta to overnite@gmail.com
2018-4-7
Igrik
Ukraine
Hooray! I found a solution how to fix this "inverted" images. It seems like this "bug" wrights photos with switched red and blue channels. All you need to do is to switch them back!
2018-6-25
