Battery sugestion for F550
18842 28 2014-11-23
Anzek03
Croatia
Dear all,
Can you help me, with what setup of battery should I go for my stock F550, GP 4, H3-3D gimbal and FPV video.
4S or 3S, and what mAh?
I would like to get 10+ minutes flights.
Thank you very much for your help.
2014-11-23
Blade_Strike
Flight distance : 872694 ft
4S something in the 5000mah range.
2014-11-23
VegetalPT
China
Blade_Strike Posted at 2014-11-23 23:12
Hi have a F550 with E300, Naza M V2- Arris 3000Pro gimbal and FPV Video. With battery the weight is 2490g. I'm using a ROC 4S 5800mah 30c 14.8V  and I only can fly max 4 min.
Any bad configuration???, Please help
2014-12-15
Blade_Strike
Sounds like a weak battery.. GENS ACE 5300mah 4S1P  are awesome packs.
2014-12-15
kosmas
AGA Power has 4s batteries at 6200mAh, I'm using these and have about 10-13 mins depended on wind conditions. But don't go with heavier batteries expecially when flying in strong wind.
2014-12-17
stenatb
I have F550, Naza v2, Gimbal H3-3D and white props, with Haiyin 4S 5000mAh and has flight time of 16-18min after wind conditions.
2014-12-21
Anzek03
Slovenia
What about the settings of low voltage alarm in NAZA assistant?
2014-12-22
kosmas
The procedure of setting the voltages is described precisely in NAZA Assistant when you put the mouse pointer over the appropriate voltage setting input box. Take a look at the attached image to learn how.  In general, for the 1st level protection, a setting of 13,80 for "no load" and 13,50 for "loaded" is acceptable (4s Lipos)
2014-12-29
Scotts
I'm using a 4S 10,000 mah battery and I get great flight time.
2015-2-9
EkaPanya
Dear Scotts,
I'm going to use a AGA 4S 10000 mAh with my F550. What is your 1st and 2nd level protection no load voltage setting ?
2015-3-1
Eirlink
the only voltage the naza reads to determine its low voltage warning is the LOADED one.
it does not read the No LOAD  or the LOSS.
theres is no need to enter anything in LOSS....just enter your ist level and 2nd level
personally i dont use the Low voltage alert feature, but prefer to use a timer on ,y radio ( with alarm/ vibrate ) in conjunction with a lipo alarm plugged into the flight battery.
2015-3-1
mark97564
Flight distance : 2067749 ft
@ stenatb,
16 to 18 min flight time with a 4 cell 5000mah battery on a f550 with a gimble? Are you sure? In 8 minutes my f550 with h3-3d gimble, naza v2, and Lightbridge eats up 5200mah running a 4 cell and in 10 min i used 6300mah of my 7200mah packs..
With my f450 with no gimble and just a iosd, fatshark 600tvl cam and immersionrc 2.4ghz 700mw vtx and immersionrc ez-uhf rx i can get 22min with 6500mah used of my 7200mah 4 cell packs...  my 5000mah packs ive gotta land in 15 min..   i can see your times being Accurate with a f450 but f550 uses 13 more amps Than a f450 and i can't get it any lower. ..
What is your secret?
2015-3-5
sfyris
take a look here
https://www.facebook.com/2653986 ... 57154813552/?type=1
2015-4-23
joe
It is not just the capacity of the battery.  You need to look at energy density and weight.
Some of the new multicopter targeted batteries have significantly higher energy density (mah/kg) and therefore lower weight for the same capacity.  This translates into longer flight times.  To compare batteries use the formula  (amp hours* nominal voltage)/weight.
It would be interesting to see what the energy density of the batteries being used are.
2015-4-24
doug.dougjohnso
I ONLY buy my batteries from maxamps.com
http://www.maxamps.com/products.php?cat=F550+Flame+Wheel
I bought a 9000xl (true 100C) battery and it is far and away the BEST battery I've used with the 550. I get 12 minutes where my 6000xl batteries give me 7.5 to 8.
Do NOT buy the 11,000 battery it is only 40c so it simply can't provide the juice over a long flight. You can take off and fly for 3 or 4 minutes, but then you have to set down and let the battery rest, then you can fly again for 3 or 4 minutes. It's just not that great.
I hope that helps
Doug
2015-4-25
joe
Not sure what you are running for motor etc on your copter but 100C batteries with more for a given capacity.
A 100C 9,000 mAh battery can out put 900 amps.  The standard DJI 550 motors are only about 150 watts max so at  ~15 volts this is 10 amps per motor or 60 amps top at absolute full tilt. A 10 C battery of the same capacity if more than capable of handling this.  The DJI batteries for both Phantom and Inspire are about 10 C batteries which give a higher energy density that high C rated batteries.
In general a 10 to 20C battery is more than sufficient for multicopter use and better since for the same weight you get more capacity and flight time.
2015-4-30
Khaptin
Flight distance : 427057 ft
joe@heliflightc Posted at 2015-4-24 21:13
Some of  ...
I assume the higher the solution to the formula you gave, the better the battery?
I'm interested in this because I recently got into flying with an f550. I have a 11000 mAh 3s maxamps battery, and I can get about 12 minutes with my gopro mount, but when I add the gimbal I purchased it seems to struggle with the weight, so I've been planning on upgrading to a 4s battery (in the 5000 to 6600 mAh range) to gain a little more lift.
My rig is about 2.4 kg with the battery and I'm wondering what flight times I could expect with a 5000 or 6600 mAh 4s battery.
2015-5-11
joe
The higher the solution the more energy the battery has to use which all equal translates into longer flight times.
But capacity alone is only part of the issue with flight time.
In your case it sounds like you are near the weight limit for you system with a 3S battery.  More capacity with the same battery type will only make flight time worse when you are at this point as weight will increase.
A higher energy density battery of the same capacity would have less weight and would fly longer.
You are right going with 4S should give more lift a ~8250 4S of the same type would have about the same energy and weight and would give you more lift capacity.  Better yet would be a 4S with higher energy density which would have the same total energy but weight less.
2015-5-12
Khaptin
joe@heliflightc Posted at 2015-5-12 21:10
The higher the solution the more energy the battery has to use which all equal translates into longe ...
I've ordered a 4s. It's 6600 mAh
2015-5-12
learjet2015
Mexico
hello
F550  with e300 motors and standar dji props + h3-3d gimbal+ iosdmini+ 2.4 datalink ground station+ boscam 5.8 video transmitter+ turnigy 9x RX/TX
I use this battery http://www.banggood.com/Wholesal ... -BG709-p-65640.html
flight time 5-6 min
need advise for  a battery and props  combo to acheive a time 10+ time?
thanks in advace.
2015-5-13
Khaptin
learjet2015@yah Posted at 2015-5-14 02:10
hello
F550  with e300 motors and standar dji props + h3-3d gimbal+ iosdmini+ 2.4 datalink ground st ...
Hi, I have an 11000 mAh 3s battery and get about 12 min of flight time (Carbon fiber 9443 props). The battery you are using is somewhat smaller and you have a gimbal on you craft (my battery with a gimbal struggles). You might need to look into a larger battery. I'm looking into a 4s battery hoping that will help with lifting the gimbal.
2015-5-15
learjet2015
Mexico
Khaptin Posted at 2015-5-16 09:50
Hi, I have an 11000 mAh 3s battery and get about 12 min of flight time (Carbon fiber 9443 props).  ...
thanks khaptin
i order 4s zippy 4000 mah 25c  will try  put 2 of them parallel and hope get  good times
props i will use 9x5
2015-5-15
Khaptin
learjet2015@yah Posted at 2015-5-16 10:21
thanks khaptin
i order 4s zippy 4000 mah 25c  will try  put 2 of them parallel and hope get  good  ...
Interested in your results. I ordered a 6600 HK 4s battery. I'm wondering if I'll have to change my props when I get the 4s wired up.
2015-5-15
Khaptin
I wired up my 6600 mAh battery today. It wasn't fully charged when I got it, but wasn't dead, so I flew it a little bit (I think my starting voltage was 15.6).  When I fly with a full charge I'll be able to tell more if I like it. I didn't land until my loaded voltage was about 13.9. The battery felt a little warm, but I'm not sure how warm is to warm. I flew about 10 minutes, but landed to feel my motors to see if they were warm mid flight.  When I cam inside and plugged the battery into my LiPo tester the resting voltage came up to about 4.7v
2015-5-16
DJI-Dave
I like 4S 6600mAh for that set up.
2015-6-12
superkresh
I think that, the relation weight of the drone - flight time is very important!
Remember that for engines E300 DJI recommends a maximum flight weight of 1800g and for E310 a maximum flight weight of 2400g (with battery 4s).
2015-6-25
P3PO
Flight distance : 16083 ft
Blade_Strike Posted at 2014-12-16 01:25
I just picked up a couple of Gens Ace Tattoo 6000MAh 35c for my F550. as soon as I'm finished with programing I will get some flight times.
2015-6-28
DJI-Dave
superkresh Posted at 2015-6-25 16:48
Remember that for e ...
Very true. Relation weight is important.
2015-6-30
DJI-Dave
P3PO Posted at 2015-6-29 08:19
I just picked up a couple of Gens Ace Tattoo 6000MAh 35c for my F550. as soon as I'm finished with ...
Those are good packs.
2015-6-30
