frank320
![](https://forum44.djicdn.com/data/attachment/common/c2/common_12_usergroup_icon.png) lvl.3
Flight distance : 1440459 ft
wsalhab,
Sorry you feel that i am trying to "cloud" the issue. I am not. Read all my above posts, because if I was trying to "cloud" the issue, i wouldn't have spent the time to write 3-4 long detailed posts, explaining the math, physics and aerodynamic properties(VRS) of why flying a 3kg Inspire, 4 meters above ground level, at a speed of 60kmh, directly at a building 40-50m ahead, then letting go of the controls, was surely going to result in a crash...the first 15 seconds of your video clearly showed you turning the Inspire and then going full forward towards the building as the aircraft build up speed to 16m/s, directly towards the building, 4m AGL. My argument is, after that point(15s into the video), it didn't matter what you did, or whether you have any more control, it was too late and destined to crash into that building.
The reason i spent so much writing and explaining this, from which i get zero benefit, is that i think this is important for everyone pilot to understand:
It is NOT ok to fly your 3kg Inspire, 4m AGL, at full speed greater than 60kmh, pointed directly towards any object, less than 50m away(i would venture to say the safe limit here should be 150m).
Consider youself lucky that it only crashed into the building and will cost you only a couple hundred pounds. If you had hurt or killed someone, with the video above, given the flight charateristics, you be charged with gross negligence, or worse.
