Malakai_UK
Flight distance : 536115 ft
Your machine shouldn't have any issues playing back your content. Maybe check your codecs are up to date or try a different media player. If you are playing content from an external drive, check its USB 3. Try moving the video to an internal drive.
The filesize for 4k content is about right though.
1 min of footage compressed for youtube weighs in about:
3840x2160 (UHD)
H.264 (Youtube Settings)
File size ~1.4GB
As for outputting. I always export out at the same bitrate that the highest bitrate that went in. For example, my camera captures at 90Mbps, Air at 100Mbps and my gopro at 60Mbps. I will always export at 100Mbps as a master file then compress from this master for distribution.
I always upload the master file to YT because they will compress it to work on their platform and as software and codecs get better they will re-compress the original master file and should I need the original again I can re-download it back from YT.
When editing, the newer version of premiere allows transcoding during ingestion. I would highly recommend looking at this. Its an extra step and a bit of a process because it will convert your video files but the benefits are that the working files are easier for the editor to work with. Both during editing and during export. Basically it takes away the need for the editor to decompress the video during editing. Here is a good analogy.
Imagine a rubber band stretched really tight and you want to trim a little off the end. You need to slack the band off, trim a bit off then stretch it back out. (This is your footage straight from the camera, compressed and the editor having to do more work.)
This time let the rubber band hang loose. You need to trim a bit off the end, go ahead. its still hanging there. When you have finished trimming just stretch it back out. (This is your footage transcoded, much less compression, then exported out.)
