Why "Warning:Shooting is currently not permitted." ??
1378 11 2018-3-11
pashas_dad
Flight distance : 982723 ft
Was flying the Mavic Air late this afternoon and tried to take a panorama and kept getting the warning that:
There was almost no wind, thought that perhaps that is what prevented pano shootong in the past. I could shoot single exposures, videos and AEB photos just fine,
why the restriction in pano mode?
Anyone have any idea?
2018-3-11
Aeromirage
Flight distance : 1778045 ft
I get this occasionally on mine and simply moving the gimbal up or down seems to make it go away. I think it is a bug in the software.
On mine also, if I try to shoot a pano in S mode, the camera locks up and the only thing that will unlock it is to land and reboot.
On Spark, if trying to shoot pano in S mode, shooting not permitted comes up but that is all. Switching back to P mode fixes that.
2018-3-11
pashas_dad
Aeromirage Posted at 2018-3-11 16:04
Hmmm...I did in fact move the gimbal up and down but mine never made it go away. There's got to be some other cause unless its a possible "feature" of the software.
2018-3-11
csevengo
Flight distance : 1172221 ft
If I remember correctly I had the same warning while trying a pano in sport mode. I switched back and all was fine.
2018-3-11
HedgeTrimmer
You were to close to a Classified Top-Secret DOE/DOD site.
You violated new Class T unmarked no-fly zone.
Class T are unmarked because they Classified Top-Secret.
2018-3-11
pashas_dad
csevengo Posted at 2018-3-11 16:15
Wasn’t in sport modewhen this error occurred.
Any additional ideas on its source?
2018-3-11
ChaosKnign
Flight distance : 402877 ft
I would get this error with my Mavic Air if I was at my maximum flight altitude (122m or ~398ft). I have to fly down to 120m (~392ft) and then it would let me.
See if this is the case with you.
2018-3-11
ChaosKnign
As an aside, I changed max flight alts to see if it was a built-in restriction in the US or if it was based on my settings.
I found that I had to fly 5 - 8 feet under whatever I set as max flight alt.
2018-3-11
Keule
Flight distance : 3733015 ft
pashas_dad Posted at 2018-3-11 21:34
I had the error also and i tried:
- Switching WiFi channels from 2.4 GHz to 5.8 GHz
  It seemed to work for a few flights ... but at the end, again the Warning: ... not permitted
- flying at different altitudes - same thing
- flying at different wind situations (All within the specs)
  Here i thought there is a common root cause - Wind speed (If speed exceeds a [unknown] velocity, the warning is triggered).
  But after a few tests, it looked that there is also no relationship.
  i.e.: Trying to shoot a pano multiple times at one location, i always got the Warning, but moving the aircraft approximately 0,5m laterally in another direction, it worked...
So, why does DJI not tell us the reason(s) that triggers the Warning and we are unable to take the pano?
2018-3-11
pashas_dad
ChaosKnign Posted at 2018-3-11 21:45
That’s interesting, thank you.  I was at max altitude. Will try lowering a bit to see if that helps.
2018-3-11
ChaosKnign
Another interesting bit, since I see you have a Spark as well, this doesn’t seem to be the case with the Spark. Only the Air gives me these errors.
2018-3-11
pashas_dad
Never got this error on my Spark, only on the Mavic Air.
2018-3-12
