Flight distance : 10186312 ft
Only left or right stick will work, so let’s say Aircraft is behind you when you hit trace then guide aircraft to the side of you , once it’s there it will hold its position and follow you , if you then want to change its position again just move roll stick until aircraft is in the position you want it to trace you. |
