256 gig Micro SD
616 6 2018-3-18
fansc1f99add
Is it safe to put a 256 in a mavic pro?
2018-3-18
Wachtberger
Flight distance : 261509 ft
According to the specs Mavic Pro only supports up to 64 GB SD cards.
2018-3-18
fansc1f99add
Thank you I thought I read that but was sure.
2018-3-18
fansc1f99add
Wasn't sure
2018-3-18
StanfordWebbie
Flight distance : 178018 ft
Yup. I have a 64 gig in mine and always have plenty of room.  I think that 64 gigs will hold far more than your batteries and flying time will contribute.  One thing I found is that, if you delete videos off your card while on your computer, it puts those videos into the trash of the SD card.  So, I always make sure to empty the trash while my card is still "live" in the computer.
2018-3-18
B1houdini
Flight distance : 927927 ft
Not sure if this will be the correct answer you are looking for. I had it in my notes that I keep on the Mavic.
In summary, there are three classes of SD cards:
SD, up to 2GB in size, formatted in FAT12 or FAT16
SDHC, from 2GB - 32GB in size, formatted in FAT32
SDXC, from 32GB - 2TB in size, formatted in exFAT
Regular SD cards, and micro SD cards are capable of any of these classes. SD card class support is backwards compatible (e.g. SDHC cards are supported in a device that supports SDXC cards), but not the other way round (e.g. SDXC cards are not supported in a device that only supports SDHC).
Because a device that supports a 64GB card must already support SDXC cards formatted in exFAT, I don't see why a larger card wouldn't be supported either. But, a card that supports up to 32GB of size only supports SDHC cards, and therefore not capable of using the larger SDXC cards.
Please remember though that there may still be devices that will not support over 64GB SD cards (even though they theoretically should), possibly due to hardware or software limitations.
2018-3-18
Wellsi
Flight distance : 9082933 ft
10 mins of 4K video is around 8Gb...  I've found 32 or 64 plenty...  It will almost certainly handle a higher capacity card but I'm not sure why you'd need one... cards corrupt and you don't want too much on there without being transferred to your laptop or PC
Ian
2018-3-18
