Firmware update error / no sd card error / more errors
3999 36 2018-1-10
Gregor288gk
I`ve got serious problem with my Phantom 4. When I tried to update firware I recived error message at 55% when installing  (error code 0x022403) - with DJI Assistant .Tried several times with tree different PC`s, different usb cables.  Now I got no SD card error, connection error - I cannot update with DJI GO - it shows latest firmware, so I cannot click it. My second P4 updated with no problems...
2018-1-10
Nebuchadnezzar
Flight distance : 3462946 ft
I cannot update with DJI GO ..Hi Gregor288gk ,did you tried reinstall the app ?
2018-1-10
RedHotPoker
Flight distance : 165105 ft
Which firmware versions are you currently running?
In the Go app look under About.
RedHotPoker
2018-1-10
Gregor288gk
@Nebuchadnezzar - Yes I did. I tried with two different devices... Go app says LATEST FIRMWARE - and there is nothing I can do...
@RedHotPoker - App- 4.1.22, Aircraft 02.00.0106, RC 1.9.3
Its hard to even check aircraft firmware - it seems to bo loosing connection from RC to Aircraft. Led on the aircraft blinks some times green, sometimes red. Go app shows poor radio, sometimes no signal message...
2018-1-11
RedHotPoker
Gregor288gk Posted at 2018-1-11 08:02
That's odd behavior. Have you thought about sending it in, for analysis?
RedHotPoker
2018-1-11
Nebuchadnezzar
Gregor288gk follow RedHotPocket Advice
2018-1-11
zhangqing
Flight distance : 5959009 ft
China
If you can use it normaly,please don't update it,,,,,,,,,,
2018-1-12
Gregor288gk
Zhangging i can't user it. After update error at 55% there are many problems - SD card error, radio problems...
2018-1-12
DJI Elektra
Gregor288gk Posted at 2018-1-12 06:16
Gregor, please provide us the update log for further analysis. Please tell me the model of your PC. If you use windows, here is the path: :C:\Users\AppData\Roaming\DJI Assistant 2\upgrade_log.
MAC: ~/Library/Application Support/DJI Assistant 2/upgrade_log
2018-1-14
fans230fa015
Flight distance : 728 ft
DJI Elektra Posted at 2018-1-14 03:19
Excuse me, but I'm having the exact same problem. Can I send my log to you ? Tks !
2018-1-14
Gregor288gk
Thanks for Your answer elektra. I`ve got upgrade log. How can I send it to You? My PC is Dell Inspiron 15 7000 running on Windows
2018-1-15
Gregor288gk
Can I ask again where can I send update log?
2018-1-17
DJI Elektra
Gregor288gk Posted at 2018-1-15 06:21
Sorry for the late response. Please upload to the dropbox and post the link here. Thanks for your help.
2018-1-18
Gregor288gk
Sorry for not responding. Its winter You know
Here is the upgrade log:
https://www.dropbox.com/s/pnbvc9 ... 55_upgrade.log?dl=0
2018-2-24
Gregor288gk
And here is one from today. Latest firmware. Same error at 55%
https://www.dropbox.com/s/mrea68 ... 12_upgrade.log?dl=0
2018-2-24
Gregor288gk
@DJI Elektra ? Anyone? Something?
2018-3-3
DontFlyHigh
Flight distance : 20682 ft
I got the same exact problems! identical! 55% and all that. any outcome?
2018-3-5
goran_magnusson
DontFlyHigh Posted at 2018-3-5 00:47
I have the same problem! Fails at 55%. Tried the DJI Go 4 app on my ipad mini 4 and iphone 6 and DJI Assistant on three different computers and they all fail.
2018-3-5
DontFlyHigh
DJI Elektra Posted at 2018-1-18 02:33
any outcome? how do we pay over a thousand dollars, only to use the drone for a month or two, and now it just sits in my closet ever since 2.06 firmware lost my video feed so obviously can't fly, and I spent all m,y money on a p4 that has NEVER been crashed an only flown 20 times?
2018-3-11
Drone 5150
Flight distance : 88294 ft
DontFlyHigh Posted at 2018-3-11 17:12
I have exact same issue.  In the middle of back and forth emails with DJI support.  Engineering analyzing logs as we speak.
2018-3-12
DontFlyHigh
goran_magnusson Posted at 2018-3-5 04:48
Im pretty sure I found our problem. well I definitely found mine. I just got done flying again after 8 months. so luckily for you, theres me. I got my hands on another gimbal with different problems but gave me a video feed and sd card recognition. so "luckily theres me"part...because I switched out everything in the gimbal 10 times. each of the stacks separately  where the heat sink/camera connections/internal sd card/ect. then the completed assembly of gimbal motors and camera and all that,  to eventually get done with with all but one more option , the stupid smaller cable, the shorter of the two that need disconnecting when removing the gimbal from craft body. the one that is so freakin easy to switch out quickly because both ends are easily accessible without disassembling anything (once you separate the gimbal from the craft). I might be wrong for your deal, but our situation was identical. and I don't think I am . sorry for the build up and rambling but figured if im right in your case, then the process of my post to get to the simple answer is much worth it. replace the shorter gimbal wire/cable and you'll be updating and flying in no time
2018-3-19
DontFlyHigh
Gregor288gk Posted at 2018-3-3 05:06
2018-3-19
DJI Elektra
Sorry for the late response. I would forward the log and update here as soon as possible. I would recommend you tap "Reply" to post the data so I can check in the reminder and reply you at first.
2018-3-25
Gregor288gk
DontFlyHigh Posted at 2018-3-19 09:51
So all that You did was replacing shorter cable? Thats all?
2018-3-28
Gregor288gk
DJI Elektra Posted at 2018-3-25 02:06
Ok so here are logs:
can You look at them. The problem is not solved yet...
2018-3-28
DJI Elektra
Gregor288gk Posted at 2018-3-28 08:13
Thanks for your update. I would help you forward it.
2018-3-28
DontFlyHigh
Gregor288gk Posted at 2018-3-28 08:10
after so much trial and error, that was it. and everything you said you had problems with, I also had the same. not one thing different.
2018-4-3
DontFlyHigh
did you get that cable? the whole cable kit is like $15. and you have extras if you ever need later
2018-4-3
DontFlyHigh
Drone 5150 Posted at 2018-3-12 13:55
2018-4-3
Drone 5150
DontFlyHigh Posted at 2018-4-3 19:10
I ended up sending it to DJI. They replaced  that gimbal cable, gimbal roll motor, left landing gear, both shell halves and a prop motor.  For free.  Out of warranty.  AMAZING customer service.  The original quote they gave me was for $195.00.  I mentioned that it flew fine before the upgrade, and they covered all costs, even shipping...  Very cool.
2018-4-8
DJI Elektra
Drone 5150 Posted at 2018-4-8 11:15
Glad you solve it. From the log analysis, we did not find the error. Hope you get the drone back soon.
2018-4-12
Drone 5150
DJI Elektra Posted at 2018-4-12 02:46
I've had it back for a while now.  Very quick service.  It did come back with the latest firmware.  So, when you say nothing was found in the logs, it makes me wonder what is going on with these failed updates...
2018-4-12
DJI Elektra
Drone 5150 Posted at 2018-4-12 16:14
The log may fail to reflect the problem. Please check if your drone work well now. Have a nice day!
2018-4-13
Drone 5150
DJI Elektra Posted at 2018-4-13 00:59
It works great!
2018-4-21
RA Foto Studio
hi
i got same problems with a phantom 4. it stop upgrade at 55%. after this i have a lot of problems (sd card not recognise, transmision error, when in the air is not stabilising). i tried upgrade from app with an ipad and from pc with assistant 2.please check my file. thanks
2018_05_07@18_38_51.zip
9.05 KB, Down times: 3
2018-5-10
DJI Elektra
RA Foto Studio Posted at 2018-5-10 10:19
hi
Did you try to update your drone again? If not, please try again. And I would look into your log to locate the problem.
2018-5-11
fans1aefb7ea
hi
And is it fixed?
2019-3-22
