Charging warm batteries
2977 12 2018-3-29
nywrecker
Flight distance : 832421 ft
Is it bad for the batteries to be charged right after it has been used?
2018-3-29
msinger
Flight distance : 228255 ft
Yes, you should definitely allow them to cool down before attempting to recharge them. If they are too warm, they probably won't charge anyhow (since they have built-in protection to prevent charging when too warm).
2018-3-29
RobertW
Flight distance : 41818 ft
Yes, but they have built-in protection to prevent charging when warm.
2018-3-29
FlyDK
Flight distance : 1636286 ft
Never charge a hot battery, but it is not necessarily so hot that it can not be charged immediately after the flight has ended. Check the temperature of the battery via the Go 4 app before turning the drone off. Batteries with a temperature below 25 degrees C / 77 degrees F. can easily be charged. Allow to cool if necessary.
2018-3-29
nywrecker
Got it.
Tks.
2018-3-29
PS013
Flight distance : 3579409 ft
from https://dl.djicdn.com/downloads/ ... idelines%20v1.0.pdf
2018-3-29
A CW
Flight distance : 14754314 ft
I tend to leave mine for 20 minutes before recharging
2018-3-29
dronist
Dude, never ever unless you lie the kboooooom
2018-3-29
DJI Diana
Flight distance : 2408 ft
PS013 Posted at 2018-3-29 13:31
from https://dl.djicdn.com/downloads/Mavic%20Air/Mavic%20Air%20Intelligent%20Flight%20Battery%20Safety%20Guidelines%20v1.0.pdf
Useful information, thank you so much for the sharing.
2018-3-29
DJI Diana
msinger Posted at 2018-3-29 13:06
Yes, it is recommended to charge the battery until it cools down to near room temperature.
2018-3-29
HedgeTrimmer
dronist Posted at 2018-3-29 18:26
Attempting to charge a hot battery from wall outlet by dipping it in salt water ice bath sitting next to gas can in garage, while you run out for pizza and beer; what could possibly go wrong.
2018-3-29
dronist
HedgeTrimmer Posted at 2018-3-29 19:04
When you get back, you'll have an EXPANDED view of the neighborhood where  you can fly the MP in an OPEN space after everything get leveled out!
2018-3-29
davidmartingraf
Yes, you don't have to really worry about whether it's damaging in that the batteries will not take a charge if the internal temperature is not in line with its programmed level.
2018-3-29
