SAME MY ISSUE!!!! As you can see from the official release note, the correct firmware should be 1.1.0.21 but i can't upgrade the transmitter firmware from the old 1.1.0.20 ...
I need to use the Gimbal with the second remote operator next week and i don't know how to fix this issue!!!
After forwarded the issue to dji support, a good people help me, and solved my problem. Now everything works well! I confirm that the issue is located in dji assistant that doesn't allow to upgrade the transmitter firmware to 1.1.0.21. now everything it's OK!!!
Ho djiuser_TkHM7! I don't know if I can share my solution because it's a little bit hack the dji assistant ... I'm sorry for that... But you can forward this thread to the online support for the solution.. the solution it's located in the dji assistant that has to open the solution to upgrade the transmitter to the latest firmware 1.1.0.21! They will understand!
Ok guys!!! Jared from dji told me that i can share the solution!
Here the steps:
1 connect your ronin m transmitter to your pc via usb and fire it up.
2 after Windows ricognized the transmitter, open the latest dji assistant, in this case the 2.5.
3 login with your email and password and go to the update menu.
4 inside the specific upgrade firmware menu tipe with your keyboard "door".
5 a new pop up will appear and you have to type into user and password the word "ronin"
6 this allow to force dji assistant to unlock the latest transmitter version to 1.1.0.21 !!
7 follow the intruction and that's it! Don't be afraid if the update fail first time. This procedure first erase the transmitter firmware. redo the same procedure and dji assistant will install the latest firmware 1.1.0.21 Do the calibration and ronin will works PERFECT!!!
InterStellar Posted at 2018-4-7 03:11
I tested my ronin now. After the update my ronin doesn’t recognized the deadband for pan and tilt axis. Please help.
Everytime I connect my thunb control I lose my deadband in my ronin eveb though the settings is set.
I'm terribly sorry for the late response, I just saw your update, but glad to know the issue was figured out, hope you have a great time with it, if there is any other issue, please let us know anytime.
Hey there, I did this update and it work for me!
I only have one problem now.. Mij tilt won't work..
Someone having a solution for this?
It seems like that the ronin M it self, also has a "door" update..
But the password/ username is different
