IMU calibration - where are advanced settings?
879 14 2018-4-8
skipperscott
I viewed the support video at but the 3 dots in top right bring up GENERAL SETTINGS, NOT Main Settings, and there is no Advanced Settings listing.
Advice please.
2018-4-8
msinger
Flight distance : 228255 ft
After connecting your Mavic Air to DJI GO, you'll find the button to calibrate the IMU Here:
2018-4-8
skipperscott
Nope, I just did that again and it gives me GENERAL settings - NOT main (and as I said, no advanced option.
2018-4-8
Jeff7577
Flight distance : 1916821 ft
You don’t see the menu on the left with the drone icon?
2018-4-8
skipperscott
Ah! Different to the video but thanks, that gets me to Advanced/Sensors/Calibration.
Done that, it now seems to be stuck on 2/6 (2 mins & counting), is that normal?
2018-4-8
skipperscott
skipperscott Posted at 2018-4-8 08:19
Calibration stuck on 2/6 for 7 minutes now - is this normal?
2018-4-8
skipperscott
skipperscott Posted at 2018-4-8 08:26
Stuck for 10 mins now, and Controller needs charging yet again... And the aircraft battery.
One day I'll get flying instead of trying to update, setup, and recharge, maybe...
I could be cured of my desire for a drone if I have another weekend like this. It's only when I see the great footage you guys are producing I know it MUST be worth it...
And I thought this would be fun!
2018-4-8
nmac
Flight distance : 256 ft
on step two did you have it flat or on its side.  I say this because i have seen many that miss took the pic and turned it instead of on its side.  i was one.
2018-4-8
skipperscott
I understand now. My error (as expected). I'll get back to this in the morning. Thanks.
2018-4-8
DJI Diana
Flight distance : 2408 ft
skipperscott Posted at 2018-4-8 14:35
Hi there, I'm sorry to reply you late. Hope everything will be fine soon. If there is any further issue, please feel free to let us know, we'll here for help. Thanks!
2018-4-8
skipperscott
Hi Diana, I managed to calibrate this morning (simple now I understand).
I just had a beginner flight. All went well until I was told battery low, battery low, and it shot up vertically into high branches of a tree it was under at that moment, hit a branch  and crashed to roadway beneath, upside down... Not good. I shall change propellers (broken), replace the battery & see if it still works after lunch ( too much in shock now!).
Scott
2018-4-9
QuadKid
Flight distance : 482349 ft
skipperscott Posted at 2018-4-9 03:41
Scott
Always bring the drone home when you hear Low Battery Warning, I have mine set at 35% so as not to trigger Failsafe RTH, it sounds like yours was triggered and it flew up to the preset RTH Altitude as it was under a tree. When flying under trees, bridges ect.. I always set my RTH function to Hover this will give you time to cancel RTH and fly it back.
2018-4-9
skipperscott
Oh boy.
Front left motor is stiff to rotate, not free any more...
I guess that's a send back to base repair job.
2018-4-9
nmac
Sorry to hear about crash but glad you got your imu cal done.  Many new ones are in a hurry to get into air and do not or skim quickly over manuals and that's when things go bad. I am also new but i took the time to read as much as i could and watched many videos so i would have more info and know much more and it has paid off. I think if you would have known much more about the app your crash would not have happened. I hope you get a chance to watch and read more on it and you will see what can go wrong and prevent.   hope all goes good for you.
2018-4-9
nmac
BTW  there are some good videos that explain the RTH in full detail that all can understand.
2018-4-9
