Phantom flew with 3 motors
3698 18 2014-11-24
syedfaiq_747
Guys,
How do we know that the motors are about to fail before its actually failed in mid flight and...................crash !
Thanks.
2014-11-24
away-point
Beyond checking how the bearings feel, noticing usual noise or heat, we don't!  Plus, an ESC can suddenly fail with the same result.
A lot of gamble to this hobby!
2014-11-24
syedfaiq_747
away-point Posted at 2014-11-25 11:35
Beyond checking how the bearings feel, noticing usual noise or heat, we don't!  Plus, an ESC can sud ...
Now this is why we do not fly over people head. Appreciate your reply.
2014-11-24
insitb
Syed, did your Phantom manage a landing on 3 motors?
2014-11-24
aerialpicturean
Flight distance : 1322064 ft
I got some warning signs on mine.
Couple of days back when I started the motors, the front right red led started flickering on and off and shortly afterwards wasn't going on at all.
I also noticed that that motor was spinning a bit slower than the rest.
I was too scared to fly, so went to the dealer and discussed with them. We decided to replace the ESC which was still under the 12 month warranty.
I did that over the weekend and now the lights on that arm are back to normal, but the motor is still spinning slower than the rest.
So now I am going to replace the motor as well which is not under warranty (3 months) any more.
Hopefully that will sort out the problem.
2014-11-24
syedfaiq_747
insitb@singnet. Posted at 2014-11-25 13:47
Still didn't try it and hope I dont have to try that...I dont think landing with 3 motors is possible since the phantom need specific algorithm to operate with 3 motors as to keep it balance as its had different of ccw and cw motors.
2014-11-24
syedfaiq_747
aerialpicturean Posted at 2014-11-25 14:29
Couple of days back when I started the motors, the front right red ...
The worse nightmare is when one of the motors start to failing while the phantom in mid air. Hopefully after replacing a new motors, it will turn at faster speed (normal speed).
2014-11-24
Daninho
Flight distance : 70203 ft
When the motor or ESC fail it crashes but this is not the worst nightmare because the phantom will crash down where it is. My worst nightmare is when the flight controller goes mad and it fly out of sight with a full batterie and i dont know where it gone. When a motor crash it will fall down like a stone and you know it cant harm ppl because you should never fly in a city etc.. Thats why i only fly in the countryside. But then flight controller goes mad it can probably fly from countryisde to the city
2014-11-25
insitb
I've seen a quadcopter fly on 3 motors. It's ugly as hell, but at least it doesn't drop like a rock. What you need is for a kind of Failsafe, consisting of a program that automatically switches on when a motor ceases up or when a ESC is fried. The program rotates the entire quad along its vertical axis fast enough for the effect of the knackered arm to be able to be compensated by the 3 other arms spinning at max speed. Forget about controlling the quad, but at least you won't cause any serious injury.
Hopefully, in time, the Phantom will get this.
2014-11-25
aerialpicturean
I rather have mine fix before that happens. I don't think flying with 3 motors will be possible at all.
2014-11-25
syedfaiq_747
Malaysia
Daninho Posted at 2014-11-25 16:50
When the motor or ESC fail it crashes but this is not the worst nightmare because the phantom will c ...
Agreed!! better it crashed and found nearby rather than flyaway lost from sight.
2014-11-25
syedfaiq_747
Malaysia
aerialpicturean Posted at 2014-11-25 20:23
I rather have mine fix before that happens. I don't think flying with 3 motors will be possible at ...
Yup, dont take any chances. get the motors replaced and happy flying
2014-11-25
aerialpicturean
I have repaced the ESC and motor, but it is still spinning slower than the rest.
I can feel this motor has less torque than the rest.
What now?
2014-11-25
syedfaiq_747
aerialpicturean Posted at 2014-11-26 14:18
I can feel this mot ...
Have you done Full IMU calibration thru phantom assistant software? go try for advance IMU calibration including compass.
then power ON the phantom, in idle speed, observe the motors.....
2014-11-26
syedfaiq_747
insitb@singnet. Posted at 2014-11-25 20:05
I've seen a quadcopter fly on 3 motors. It's ugly as hell, but at least it doesn't drop like a rock. ...
DJI should take considerations of this, thinking the damages/injuries that might have cause by motor/esc failure.
2014-11-26
aerialpicturean
Have done all off that. No change
2014-11-27
DJI-Autumn;-)
China
aerialpicturean Posted at 2014-11-27 20:56
Which type of Motors do you use??
If you use 2312 Motors make sure the replacement of ESC is V2.1 version.
2014-11-27
aerialpicturean
I have the original motors - Don't know what model. Got the P2V+ in May 2014.
2014-11-28
DJI-Autumn;-)
China
aerialpicturean Posted at 2014-11-28 16:07
Take a photo of the coils and i will find out the model~
2014-11-28
