Update 2 Analysis program
986387 986387 2018-4-25
JJBspark
Flight distance : 12717890 ft
Axeli Posted at 2018-4-30 06:30
I have the same problem like G_Sig [view_image]
busy on this grrrr error...
2018-5-1
G_Sig
Flight distance : 9109311 ft
Iceland
JJBspark Posted at 2018-5-1 01:28
If I open the OPTION INI file without running the FRAP first its (HEDERS) look like this.
[HEADERS]
1=Secs
2=Time
3=LAT
4=LON
5=FlightMode
6=ALT
7=ALT VPS
8=Speed
9=HD
10=HomeLAT
If I run the FRAP it looks like this.
[HEADERS]
1=
2=
3=
4=
5=
6=
7=
8=
Is this normal?
2018-5-1
JJBspark
G_Sig Posted at 2018-5-1 04:09
[HEADERS]
1=Secs
nope, should not be empty. will look into that too
just donwload that ini file again and use that one.
2018-5-1
G_Sig
Iceland
JJBspark Posted at 2018-5-1 04:40
It changes every time I run FRAP .
2018-5-1
DH_Pilot
Flight distance : 3301621 ft
Slovakia
Hi JJBspark,
Great stuff, thanks for sharing. Unfortunately download link is not working anymore will you be posting new version or so?
Thanks.
2018-5-1
G_Sig
Iceland
Have found the reason. If you open FRAP and the path for .TXT files is wrong [HEADERS] will bee empty.
If I edit the config file before running FRAP [HEADERS] is right.
Still having the grrr error.
I'm starting to think this is related to Windows 7 or virus program.
2018-5-1
JJBspark
G_Sig Posted at 2018-5-1 05:29
thanks for that, now to find the reason why they become empty!
Grr error, what does the error say?
2018-5-1
JJBspark
DH_Pilot Posted at 2018-5-1 05:10
Hi JJBspark,
yes, i wil. Hope end of this week
2018-5-1
G_Sig
Iceland
JJBspark Posted at 2018-5-1 06:01
The old error.
2018-5-1
JJBspark
Hi G-Sig, if you did open the CSV file with excel it mayby got corrupted. Try to delete the CSV and open the TXT file in the program. (use the latest version of the conversion tool).
I will PM you a link to exe with kind of debugging written into that, when ypu get the file tell me the code bottem left on the screen. Just need to know when in the programm this error pops up. (and wich txt file you use, or does this error is always there?)
cheers JJB
2018-5-1
Rawsome
Flight distance : 230827 ft
great work right there! thank you for sharing!
2018-5-1
eried
Flight distance : 787621 ft
The new version works perfect with some files that gave me "not valid floating point value". I think this tool has potential to become the de-facto Windows analyzer, I do not really like to a lot relays on the online phantomhelp one.
Major suggestions
  • Resizable window
  • Battery cell micro voltage analysis
  • Retrieve weather info/wind or other info from an external server for the analisis into a new column
  • Plugins/scripting
Minor suggestions
  • Hi DPI support
  • Customizable UI panels
  • Pretty main icon/toolbar icons
  • Non modal dialogs
Open to discussion
  • Normal file selection File/Open Log..., instead of having 3 paths and a file selector
  • Export functions (grid values, plots, etc), maybe with uploads to Google docs/Onedrive for sharing?
I do not know delphi but I can help with some stuff
2018-5-1
JJBspark
eried Posted at 2018-5-1 14:55
Major suggestions
Hi eried, thanks for your info. If some files gives that error it means that some file are not correctly converted. I had once a file where the city name and region was divided with a extra comma, so all the fields after that specific field were wrongly read.
Can you sent me a file wich gives this error? (so i can get a error-work-around procedure to 'loose' this error)
If i have time mayby some suggestion will be written into the program.
cheers
JJB
2018-5-1
HedgeTrimmer
JJBspark Posted at 2018-5-1 22:51
You are doing a great job.
From what I have read about Flight Logs (.txt) file, there are numerous unknowns.   Making it hard to write programs that extract important information.  It is to bad DJI's is playing its cards so close to vest.
2018-5-1
eried
The error does not appear in the latest version I will send you any broken file, if any
2018-5-1
Bokepacha
Flight distance : 149265 ft
LInk is not working anymore?
2018-5-2
G_Sig
Iceland
JJBspark Posted at 2018-5-1 09:53
Sorry for late respond.
I have deleted the .CSV files and always the same error. Will PM you Dropbox link to the CSV  files later.
2018-5-2
marklyn59
Flight distance : 395072 ft
The download link seems to be bad.
2018-5-2
JJBspark
G_Sig Posted at 2018-5-2 16:15
HI G-Sig, thanks for the csv files. I know now what the problem is ; flightrecords files P4 prof have a different sequence format than the Spark and MA. Meaning that the data is converted and sorted in different columns than where i look for.....ofcourse this will result in many errors!
If the data is the same but only in different order than its possible to adjust my program, have to look into that.
So for now, Spark and MA does work, mayby other Types (mavic pro works as well i think) but not a P4P.
Update program tomorrow on here
UPDATE see my last post!
Cheers JJB
2018-5-3
Axeli
Flight distance : 339416 ft
Czechia
Weird, I have the same problem like G_Sig with MA
2018-5-3
Vidjcb
Flight distance : 14321112 ft
Thanks a lot! I really appreciate it!
2018-5-3
JJBspark
Axeli Posted at 2018-5-3 02:44
Thanks Axeli, you made my day!
The conversing tool has been updated ; 2 more columns now in the CSV file. So people who use the older vesion has no problem, people who use the latest version gets lots of errors.
Problem solved. (my update programm will use the latest tool).
Cheers
JJB
2018-5-3
JJBspark
Hi all,
See post # 1 for link update version.
cheers
JJB
2018-5-4
G_Sig
Iceland
JJBspark Posted at 2018-5-4 11:57
Hi all,
Perfect look like it work on all drones TXT files. Have tested on P3S , MP, MA and P4.
Great job JJB.
From my old P3S
2018-5-4
JJBspark
Hi G-Sig, thanks for testing on all your drones. A happy person here now!
Cheers
JJB
2018-5-4
Rob.01A
Flight distance : 128888 ft
Works also for me with my MA thanks for sharing JJB.
Rob
2018-5-4
JJBspark
Rob.01A Posted at 2018-5-4 23:52
Rob
Thanks, have fun with my program. I did learn alot about the behaviour of my Spark and MA.
2018-5-5
Axeli
Czechia
Works with MA, thank you
2018-5-5
G_Sig
Iceland
JJBspark Posted at 2018-5-4 23:43
Cheers
JJB
Was testing more records and found that the oldest flight log from P3S don't open do to other format.
If that happen its best to open it in Phantomhelp and save it again then it work.
Have not yet found record which you cant open in this.
My first and only crass.
Old P3S record from 2016.
2018-5-5
JJBspark
Sounds good.
Actually this program was made for Spark and Mavic Air as i own both. (easy testing on your own flightrecords).
Any other DJI type wich works is a bonus to read.
cheers JJB
2018-5-5
fans19af0a0b
Flight distance : 113720 ft
Hello JJB -
THank you for providing this useful application.  I am having trouble running it on a Windows 10 system.  Using FRAP version 4-May-2018, when I try to open a flight record from a Mavic Air, I get the following error dialog box.
I have tried renaming it without special characters, same error message.
TXTlogToCSVtool.exe version 2018/04/21 is in the same directory as FRAP.exe (confirmed present in Options->Configuration).
It successfully converts the FlightRecord.txt file if I do it manually.
What am I doing wrong?  I can provide the original .txt and converted .csv if needed.
Thanks for any help.
2018-5-29
eried
fans19af0a0b Posted at 2018-5-29 03:30
Hello JJB -
Rename the csv to something simple, like flight.csv
2018-5-29
JJBspark
Hello JJB -
Mayby its a known error for me, if the txt file is in a directory not close to the root this can cause this error.
This error originates from the conversion tool.
if so, try to put your flightrecord closer to the root. i.e. x:\txtfiles\flightrecord.txt....
cheers
JJB
2018-5-29
gofaster
JJBspark Posted at 2018-5-29 03:57
Moving the txt files to a directory off the root was indeed the correct solution.  Thanks!
2018-5-29
JJBspark
gofaster Posted at 2018-5-29 04:25
yep, its corrected in version 3.1. (guess next week an update)
2018-5-29
QuadKid
Flight distance : 482349 ft
JJBspark Posted at 2018-5-29 04:42
Hey JJB, last time we spoke you asked if we had any suggestions for the next update. IMO I think if there was a scrollable horizontal bar/line when reading 4x graphs to line up peaks/valleys with the reference numbers on the side of the graph(s) would be useful. Don't know if this is a lot of work definitely not necessary but more of a luxury. Thanks for you ongoing contribution !!
2018-5-29
HedgeTrimmer
JJBspark Posted at 2018-4-30 02:45
No problems here with loading your file....(hmm, what is the problem...)
Edited:  Never mind.  Looks like you solved problem.  Thought I saw another case, after update.
Any chance your program has a library call that is picking up on localized (country) settings of Windows comptuer system or Windows user account?
In this case picking up on number format differences.  1.234.567,89 vs. 1,234,567.89
2018-5-29
Free2be
Flight distance : 229570 ft
Thanks for the good work, JJBspark, I have saved them, when I go to a windows machine! (Mac user).
2018-5-29
JJBspark
QuadKid Posted at 2018-5-29 04:53
Not sure if a moving line peak values is possible, if yes than mayby if i have time.
2018-5-29
JJBspark
HedgeTrimmer Posted at 2018-5-29 05:02
Yes, well its hard-coded now, so user can choose now if a comma or dot is used.
2018-5-29
