Motor Current Error
7713 30 2018-5-13
RichInGa
Flight distance : 449344 ft
So I am flying along and I see this error: "Motor Current Error'.  I've never crashed, and this was the 2nd flight of the morning. Any idea what to do? The Mavic Air landed without a problem, but I certainly don't want to fly it again until I can confirm the issue.   I checked the motors after and they all spin freely, nothing wrong with the propellers.  Can someone let me know what to do from here?
Motor Current Error
Motor Current Error
2018-5-13
A CW
Flight distance : 14588274 ft
Motor current errors are warnings and not malfunctions. What the app is telling you is that the amount of power needed by the battery for the ESC's to accurately carry out the commands you are giving it is too great for the current to maintain a safe level in driving the motors. They usually occur in very cold temperatures and when the pilot is pushing the drone too aggressively e.g. 100% pitch for a while then simultaneously applies heavy throttle to descend or when flying for a while in Sport mode against a moderate wind etc. When this pops up there is no need to land or be concerned - simply ease off the sticks and continue with the flight applying less pitch and throttle or descend to a lower altitude into lighter winds. Upon landing let the drone (motors) cool for a few minutes before taking off again. If however, the message keeps popping up and especially when only hovering then this is when you may have more of a concern and I wouldn't fly the drone in that case. This pop up seems to be happening more on the Mavic Air after the latest firmware so it could also be triggered by a glitch in the software and explains why you are not experiencing any issues after the pop up - in which case try refreshing the FW in Assistant 2 and/or reinstall the app. I do believe DJI have already referred this to their engineers so there may be a fix coming soon.
2018-5-13
RichInGa
A CW Posted at 2018-5-13 05:34
So this is a glitch in the latest firmware not hardware?  I had the throttle full down and forward pitch full not in sport mode and there was no wind. I've done this move many times, and never saw this pop up.  I was very concerned...
2018-5-13
A CW
RichInGa Posted at 2018-5-13 05:51
There you go - full pitch and throttle, even in p-mode, may trigger it. Just ease off the sticks and it will be fine. I have had one over current error message in 25 flights so far with the MA and not surprisingly I was flying in full pitch and applied throttle at the same time. Reduced my air speed a little by easing off the pitch stick and it went away and has never come back. The FW may have been updated to ensure that the warning does now pop up whereas it may not have shown at all before the update. It's actually a good thing to let you know to adjust pitch/throttle so that nothing goes wrong! Note that camera drones like the MA are not desgined to be flown around at 100% for long periods.
2018-5-13
Anton Funfly
Flight distance : 1944606 ft
I had the same message today... I flight with the same way...I had the throttle full down and forward pitch full not in sport mode and there was no wind....
2018-5-17
RichInGa
Anton Funfly Posted at 2018-5-17 11:57
It's really alarming isn't it? I was over water when mine did that.   If anyone else with a Mavic Air could try this?  Just go up to about 300 feet or so then Left stick full Down, right stick full  Forward. in normal p-Mode.
Thanks!!
2018-5-17
richimelo
Flight distance : 33133 ft
Costa Rica
Same error on Saturday after firmware update
2018-5-17
darrc
Flight distance : 5558 ft
Despite what the moderators claim this Motor Current Error is just a wrong information display, the .0400 firmware has shown lots of other problems and no accountability being shown. The fact that the originally pinned firmware post was unpinned pretty much speaks for itself.
2018-5-17
Anton Funfly
RichInGa Posted at 2018-5-17 18:00
Thanks!!
i made a video for this...
2018-5-18
djiuser_GbOdaPfGV7oz
Flight distance : 810 ft
Thanks!!
confirm last night. Same scenario..over water, left stick full down, right stick full forward, in p-mode. 1st time it happened to me.  Message popped up, was abit concern but landed and no other issues.  Reading other post it seems related to the latest firmware .0400 and not a major concern.
2018-5-18
RichInGa
djiuser_GbOdaPfGV7oz Posted at 2018-5-18 06:58
Hopefully this will get fixed fast.  I don't like false alarms.
2018-5-18
Hi there, if the error message exists during normal flight, it is a false positive. The engineers have aware of this, it will be optimized in the next version. Sorry for the inconvenience.
2018-5-20
dronybaloney
Flight distance : 24971795 ft
DJI Thor Posted at 2018-5-20 20:34
The same happened to me yesterday with the mavic platinum with latest fw.
Maybe you can info engineers also that it happens with the mpp
2018-5-20
dronybaloney Posted at 2018-5-20 22:19
For the Mavic Pro and Mavic Pro Platinum, may I know the ambient temperature of your flight environment?
Please check the propellers and the appearance of the motors, and try to change the props if you have the spares, also, restart the drone.
If the error message repeats frequently, I suggest sending it back for an overall check. Please contact our support for a further help. http://www.dji.com/support
2018-5-22
fans8512f205
it happened to me after the update. my drone has about 2 hours of flight, it's new. I was flying in very good conditions without wind and the message suddenly appeared. The drone returned home without any problem and I continued to fly it for 15 minutes.
2018-5-23
RichInGa
fans8512f205 Posted at 2018-5-23 02:25
it happened to me after the update. my drone has about 2 hours of flight, it's new. I was flying in very good conditions without wind and the message suddenly appeared. The drone returned home without any problem and I continued to fly it for 15 minutes. [view_image]
It's a very disturbing error -- but thankfully DJI Thor stated it's a known bug in the latest firmware.
2018-5-23
Vivekpar
Hello Fellow Mavic air Experts,
I had a disastrous crash yesterday. My mavic is very new, only flew 1 hour or so. I was flying in Singapore over a small lake, aircraft was at about 40 ft over water in perfectly still conditions. I pressed joystick to bring it further up , aircraft made a jerk and started circling. and starting falling down, within seconds it circled fall into water, irretrievable. I stood completely dumbfounded not knowing what to do, and just walked back to home. Later looked at logs and it showed Motor current error as last log. Now what should be done? Have i lost $1000 just because of some FW glitch: or DJI will be nice enough to help me out?
Any help is more than appreciated.
2018-5-28
RichInGa
Vivekpar Posted at 2018-5-28 00:21
I'd call DJI Support. If it's only a month old and it just fell from the sky like that  -- it should be covered.
2018-5-28
SparksBird
Flight distance : 10731690 ft
DJI Thor Posted at 2018-5-22 22:31
Hi DJI Thor it has to do with when you are pushing the AC more than the battery can handle.  This happens about 90% of the time if I am in P-Mode, am full ascend and full forward.  This message comes up due to the battery cannot handle the full load.  Simply letting off the throttle clears it.  It is not due to the props and or temp.  You get a different message if your battery is too hot or cold.
2018-5-28
Vivekpar
RichInGa Posted at 2018-5-28 04:32
Thanks, I have called them, and they have asked for details like log file. I am hoping that they could cover it as it is so unfortunate that mavic air at 40 ft high just in front of eyes just starts circling and drops dead in water.
2018-5-29
SparksBird Posted at 2018-5-28 05:53
Thank you for your feedback, I will also forward your finding to the engineers to confirm.
2018-5-29
Vivekpar Posted at 2018-5-29 19:21
I am sorry to hear your accident. If you have contacted our support, they will help to make a case and help to submit the data analysis as long as the drone is within the warranty period and see if it is a warranty case.
If there is a need, you can provide me with your case number, I will help to keep an eye on it.
2018-5-30
2018-5-30
Vivekpar
Dear DJI Thor
Thanks for your response . Indeed I had contacted support and they asked for bunch of data which I provided. Today I received an email stating that they will send me a new mavic air. I am thoroughly impressed with support and feel that I made right decision to buy DJI. I am delighted.
2018-6-2
aRapic
Flight distance : 74140 ft
Croatia
I've experienced the same problem yesterday on my mavic air, get this error on RTH descending and motors sounded strange, drone started to wiggle and shake in circle while descending. What will I do if it crashes, when will dji give some clear answers for this problem, because in my case this doesn't seem as normal firmware error. And I bought it maybe 20 days ago.
2018-7-20
RichInGa
aRapic Posted at 2018-7-20 04:43
This to me sounds like an actual hardware error -- you should contact DJI support.
2018-7-20
aRapic
Yes I have, it doesn't seem normal
2018-7-20
IM35461
Flight distance : 2235417 ft
I have not used my MA for quite a while awaiting fixes for the erratic flight behaviour e.g. lurching around when doing a precision takeoff and drifting.
Anyway, my one was over the English Channel today in normal flight mode when it started to wander off to the right at a fair speed (it was only going slowly forward at the time).
I released the joystick and it eventually stopped and I then got my first ever warning about overload and check the props!
Anyway, I kept it over land for the rest of that flight and checked the props, etc and just as before takeoff they are fine (still the original ones when I got it).
I did two more batteries worth of flights and other than the violent rotations during "precision takeoff's" and the yaw drift it seemed okay.
What does amaze me is how long these faults have gone on for with no sign of a fix...
EDIT: It seems new MA Firmware is out today 30/09/18.
I should have just waited another week before giving MA another flight.
Using CrystalSky so no internet access when I went flying.
2018-9-30
Cesar Manuel Bravo Garcia
Mexico
Necesito ayuda, ayer tuve varios vuelos sin ningún problema,  deje un rato para cargar baterías y volví a utilizar más tarde al iniciar el vuelo el drone se movía sin tocar los controles y con el sistema de sensores activos y terminó sólo inpactandose, lo revise y inicié otro vuelo y el fallo persistía así que hice un aterrizaje forzoso. El problema es que hoy ya por la mañana intento volarlo y al momento de hacer el despegue automático se inclina hacia un lado y es imposible realizar vuelos, me sale un mensaje de error en el motor o hélices. Las hélices cambie por nuevas ya dos veces y sigo con problema. Que puedo hacer?
2018-12-27
RichInGa
Cesar Manuel Bravo Garcia Posted at 12-27 07:09
Si las hélices están en buen estado, usted ha calibrado los compas y tiene un buen bloqueo de GPS, es posible que desee ponerse en contacto con DJI, ya que podría tener un error. ¿Algún ruido extraño del motor? Además, no hablo español. Usé el Traductor de Google. Lo siento si no es un buen español.
2018-12-27
Lucas775
Flight distance : 50642090 ft
It will always give that warning whenever I have both sticks on full throttle.
2018-12-27
