Wachtberger
Flight distance : 261509 ft
HedgeTrimmer Posted at 2018-5-28 09:16
I agree it is important to take time to track down the root cause.
But when several people report different problems after upgrading to .400 firmware, there is something related to either upgrade process or firmware itself.
I can fully agree to that. This is also why I tested all three take off modes because my initial suspicion has been that just one or two of them might show the symptoms, while I, normally taking off manually, had not experienced any problems. Now I have had no problems in all three modes and have reported that (like others did as well).
I want to put one thing straight here once and forever: It is not at all my intention to play anything down or to protect DJI. If I find a problem I report it frankly and have done so many times before. When I do such tests it is my goal to help identify the root causes of problems that users are experiencing because the same could happen to me any time too and I would depend on the help of other pilots to get it solved.
Here we have a case where the root cause was perceived to be the firmware update, but some doubts must be allowed too. If there was a general issue, this forum would be flooded by relating reports and complaints. This is clearly not the case. Thus what remains is to try isolating the possible cause to the extent possible and identify which particular user settings or other factors might lead to it. If we are lucky it can be found quickly, but it also can be a long and painful search.
It is obvious that some are experiencing problems and that warrants a solution. Thus let's all join our efforts to find it, ok?
