Just bought Osmo Mobile 2, battery not charging...
2459 3 2018-5-28
minkim
Hi, I just bought Osmo Mobile 2.
I came home and turned it on, the battery was completely drained.
So I tried charging it, not working.
I used the cable that was in the box,
connected it to my apple computer.
The green light starts flickering and then stops flickering while one white light keeps flickering.
If it's working, the green light should keep flickering.
And the white light should move from one white light to two white lights to three white lights until fully charged.
But mine is like one flickering white light and solid green light. The other white lights are not turning on at all.
I don't know what this indicator means but one thing is obvious. It's not working.
2018-5-28
minkim
[url=]https://www.youtube.com/watch?time_continue=4&v=EZWIF5MO-n4[/url]
This youtube video has exactly same problem as mine.
I've checked that thread, no solid answer from DJI.
If you don't get me a solution, I'm returning it...
2018-5-28
minkim
Found a solution.
I left it on the charger for some hours and then suddenly it started charging.
I think the battery was completely drained and it took some time to recover from it.
So, problem solved and I'm happy with the product!
2018-5-28
Glad to know the issue has been figured out in the end, thanks for your update, hope you have a great time with Osmo Mobile 2.
2018-5-29
