DJI GO 4 4.2.16 (cannot save brake from sensitivity)
1911 35 2018-6-5
bernardren07
Flight distance : 48504 ft
As my P4P, i tried to adjust speed brake 70 and save it from sensitivity. Reboot it then default back to 100? Same as MP save 100 speed brake but default to 130? I think 4.2.16 have bug which cannot save "brake" from senitivity. Anyone tried? I used ipad 9.7 (2018)
2018-6-5
Nebuchadnezzar
Flight distance : 3462946 ft
delete first valor , then try to write .70
2018-6-5
bernardren07
Nebuchadnezzar Posted at 2018-6-5 09:55
delete first valor? Sorry i dont get it. Can explain me. Sorry my english so so
2018-6-5
Nebuchadnezzar
1st delete the valor you want to change
2nd just write . + valor you want
in this case you must write  .70
2018-6-5
bernardren07
Nebuchadnezzar Posted at 2018-6-5 10:01
1st delete the valor you want to chage
How to write .70? there is only (- and +)
2018-6-5
bernardren07
2018-6-5
Nebuchadnezzar
mhh i see ..  not possible write a value
2018-6-5
Nebuchadnezzar
i though it was like in exponentials part
2018-6-5
Nebuchadnezzar
it is strange you can not set the value
2018-6-5
bernardren07
Lol. It's ok. Want to know if anyone have tried and able to save brake speed value or not. Always auto back default itself.
2018-6-5
Nebuchadnezzar
hope it help
2018-6-5
bernardren07
Before 4.2.12dji go 4. I able to save speed brake 70 for p4p and 100 for mp. But now 4.2.16 cannot save brake only. Other all ok saved as well. I think only bug can't save brake. Must be 4.2.16 bug
2018-6-5
DJI Natalia
Is this only happening when you use your Ipad 9.7 (2018)? Have you tried comparing it using the tested and recommended devices for your aircraft? If you can try it, please let us the know the result so that we can make an action to it. Thank you.
2018-6-5
Eric13
Flight distance : 15551037 ft
bernardren07 Posted at 2018-6-5 10:53
On iOS the setting will not be saved.
I have both iOS + Android and just checked it.
I was only able to save settings via Android. Hooking up the the iPad Mini 4 afterwards the change made on Android showed up.
But when changing it on the iPad, shutting everything down and restarting - the setting was gone.
I verified this with connecting Android afterwards.
Strange thing. Also strange that with Android the keypad pops up and you can manually put in the values between 70-130.
On iOS it shows a slider and +/- buttons.
2018-6-5
bernardren07
Really? Ok I have android. Later will check. Thank u so much
2018-6-5
bernardren07
DJI Natalia Posted at 2018-6-5 11:23
Yes. Only iOS can't save brake speed value. Other ok. I have not try android. Later will let u know. I have to sleep. Now is 4am. Singapore time. Lol
2018-6-5
DJI Natalia
bernardren07 Posted at 2018-6-5 12:28
Thank you for your response. Please let us know the result and I will also raise this concern to our Developer Team.
2018-6-5
bernardren07
DJI Natalia Posted at 2018-6-5 12:39
Hello. I tested and confirm IOS and ANDROID.
IOS- 1) cannot save speed brake value     2) cannot save 2.4ghz and auto back default to 5.8ghz (only phantom 4 pro)
Android- 1) cannot save 2.4ghz ad auto back default to 5.8ghz phantom 4 pro   2) No channel mode (choose auto or custom disappear) phantom 4 pro
Can check image transmission little weak and gps little weak too. Last time it was fine but now little poor transmission and gps. That is all. Can inform DJI to fix app ios and android. Thank you so much. SUPPORT DJI FOR LIFE! Crossed fingers for next new 4.2.17 100% stable well
2018-6-5
Flight distance : 2354357 ft
Saves if the Device is is in US English same with channel mode
2018-6-5
bernardren07
Japan
Bashy Posted at 2018-6-5 20:05
you mean input languages?
2018-6-5
bernardren07 Posted at 2018-6-5 20:34
Think so lol its where you change the main language of the device in your settings, ps, i am only on about android, i dont know about ios
2018-6-5
bernardren07
Japan
Bashy Posted at 2018-6-5 20:42
i also US english device android and ios too but still same. No luck. When i switch to 2.4ghz and flew there. once i change other battery for AC then switch on. 2.4ghz go back to 5.8ghz again. only android can save speed brake value but ios cannot.
2018-6-5
bernardren07 Posted at 2018-6-5 19:13
The brake issue has been forwarded to our engineers for analysis.
As for the channel, if you choose Auto, it will pick up the less interference channel automatically. You can try to set custom to fix on 2.4GHz if possible.
2018-6-5
bernardren07
Japan
DJI Susan Posted at 2018-6-5 23:10
Yes. Ipad 9.7 i tried to set 2.4ghz with auto channel. When i change other battery for AC. i switch on it and auto switch back to 5.8ghz with auto channel itself. Android xiaomi mi 5 plus  i switch 2.4ghz but dont have auto channel. only manual channel. i tried change other samsung note 8 set 2.4ghz but also dont have auto channel and same manual. note 8 and xiao mi 5 plus both same 2.4ghz auto back to 5.8ghz once i restart AC.
2018-6-5
F.KOK
Flight distance : 19037933 ft
Namibia
Hello Natalia, you know I have notice this brake speed issue also for a long while now even before GO 2.16, on the IPAD mini 4 but changed it back every time to 70 before I fly.
I had thought this is not so important to report this issue but after I saw bernardren07  did it and the response on it, we really must thank you at DJI that you want to fix even the smallest of things.
Tell the engineers that there efforts are appreciated. Everything on my P4 is not 100% also but thanks for looking into the issues.
2018-6-6
F.KOK
Namibia
Thanks Susan, see post 25.
2018-6-6
bernardren07
2018-6-6
bernardren07 Posted at 2018-6-5 23:25
You can fix 2.4GHz by selecting Custom, but I would not recommend this.
2018-6-7
F.KOK Posted at 2018-6-6 00:02
Our engineers have been aware of this issue and will fix it in the APP update, thanks for your support.
2018-6-7
bernardren07
DJI Susan Posted at 2018-6-7 01:58
Ok. You can ask engineer to check ios have auto or manual from channel mode but android don't have when use P4P only. MP ok to use both android and ios "channel mode"
2018-6-7
bernardren07
I found that other android update 4 june 2018 apk. I tested it and working which able to choose channgel mode (auto or custom). Android is fine. Now is IOS fix speed brake value only.
2018-6-7
As for the channel mode in Android, I've tested this at V4.2.20, both Auto and Custom work well, please update the latest version to check. And the IOS V4.2.20 has been released at staged rollout as well, please update when you receive it.
2018-6-12
F.KOK
Namibia
DJI Susan Posted at 2018-6-12 01:26
Hello Susan I saw that the sensitivity issue has been solved, thanks, but there is another thing- the last home point on the map is not saved so with every new flight you have to start new on the map.
2018-6-14
F.KOK Posted at 2018-6-14 23:22
Thanks for your feedback. It is recommended to update the home point for every new flight. I'll also forward this concern to our engineers.
2018-6-15
Eric13
The latest iOS version is 4.2.21. Try it with this again.
2018-6-15
F.KOK
Namibia
Eric13 Posted at 2018-6-15 03:58
Hello Eric, thanks, yes I want to see whether .21 maybe fixed it.
2018-6-15
