My p4 adv lose gps connection after take off
Sqrwiel
Flight distance : 699728 ft
I have a problem with my p4 adv, from 3 days (after 11 months of use) drone after the start of the summer once 3 min once 1 minute and then loses connection with GPS and goes into atti mode, it does not matter the height of the flight because once I turn on 20 m above the ground once every 80 m above the ground, but loses the GPS connection for each subsequent flight, the connection with the GPS is not found until the device is restarted, please help me
2018-6-15
Eric13
Flight distance : 15515515 ft
Sounds like a compass error. What kind of surface are you taking off from? Make sure you are not on concrete or metal.
Did this occur at the very same location or at different locations?
2018-6-15
Landbo
Flight distance : 502792 ft
Will not guess but see your log instead. Upload a log from a flight here:  http://www.phantomhelp.com/LogViewer/upload/     and return a link in the next post. There is an explanation of where you find your log in the link.
Regards Leif.
2018-6-15
Sqrwiel
Eric13 Posted at 2018-6-15 03:12
Did this occur at the very same location ore at different locations?
compass calibration was the first thing that I did, but it did not help, and as for the location it happens in every one in which it starts, also in those locations where you can start every day and so far there has never been a problem, of course until yesterday
2018-6-15
Sqrwiel Posted at 2018-6-15 03:27
Compass calibration never fixes anything.
That's not what it's for.
Your Phantom goes into atti mode because you lose GPS.
That's what atti mode is - no GPS sats and your Phantom is in atti mode.
You need to post flight data to give some details to work with.
It might have nothing to do with your compass at all and could be a faulty GPS unit or connection.
2018-6-15
Ettienne
This happened to mine. I refreshed the firmware and the problem was solved. Hope it works for you
2018-6-18
fanscfc8c1c6
Flight distance : 451791 ft
This happened to me and I sent DJI my drone. They sent me a new one under warranty. You cannot fix this!
2018-6-19
