Anyone guessed when new firmware 500 will be released for the MA?
123Next >
6270 87 2018-6-5
Brantel
Flight distance : 294997 ft
Poit Posted at 2018-6-8 05:38
Mine flew perfect with .200 when I got it.  Then updated to .400 and now I'm not risking flying it until next update.   The gimbal is turning on the yaw ever so slowly but enough for it to be noticeable in the video.  The drone also almost fell out of the sky when breaking from sport mode.  Please release the next update or just a rollback!
It’s not the gimbal, it’s the drone.  The reports for this keep rolling in.  Please contact support and open a case to help us make sure DJI understands the impact of this bug.
A USA based support manager has confirmed that DJI knows about it and that they are working on a fix but the more people that are having the issue and report it, the better for getting it fixed.
2018-6-8
Nickel
Flight distance : 402175 ft
And still we wait!!!
2018-6-14
fans0a28c148
Flight distance : 58077 ft
Latvia
I have been experiencing different kind of glitches after upgrading to the latest firmware as well. The drone is drifting to the side sometimes. One time it felt like it is blown away, is fighting by high wind, but there was almost no wind at all. Sometimes everything goes rather smooth but still the sound of motors and propellers is not the same.  I have calibrated everything, reset and refreshed firmware / software several times.
DJI please let us downgrade to the previous firmware if you are not able to release a fix! I'm 100% sure that it is firmware issue as the problems begun right after the upgrade.
It is not comfortable even dangerous to pilot a drone which behave unpredictable.
2018-6-14
Tadango
Flight distance : 232359 ft
.400 works great here. No need for an update
2018-6-14
WayneMHK
Flight distance : 694728 ft
Tadango Posted at 2018-6-14 07:06
You're one of the lucky ones.  Don't rub it in.
2018-6-14
Nikolay S Donev
Flight distance : 1290892 ft
Bulgaria
hallmark007 Posted at 2018-6-5 15:24
Of course they know of this problem that’s what the moderators are here for,
I don't know, why are you here?
2018-6-14
TZero
Flight distance : 547618 ft
I do not have any specialization in the technical field.
As I wrote in another post, I believe that these problems are caused by the diversity of components (manufacturers).
Because the firmware is generic, some components supplied in a given series/year may be more sensitive or may malfunction.
I think that's why some MAVICs work well and some do not.
2018-6-14
Nikolay S Donev Posted at 2018-6-14 07:28
And why are you here ?
2018-6-14
Nikolay S Donev
Bulgaria
To say I love you
2018-6-15
I thought there was a good reason alright.
2018-6-15
2018-6-15
TZero
I think @hallmark007 will be more beloved of this forum.
PS.: I love you too @hallmark007 // If Trump and Kim Jong Youn can, why not us?
2018-6-15
Optimus_Prime
Flight distance : 568704 ft
Vietnam
Another week gone by
2018-6-15
North Idaho Guy
Flight distance : 2310082 ft
TZero Posted at 2018-6-14 07:33
Agreed,
Apart from an issue being FW regionally specific (it appears too far spread however) due to DJI’s fly constraints around the world as I do believe DJI has to accommodate specific rules and reg’s with specific regionally FW’s
It also could be.........During MA's production runs, their purchasing dept brought in/allowed in IC's that manufacturing ran where the chip changed die’s or something, a rev/production lot numbers changed and a change(this) happened mid run (hence first run MA's seem ok, mine). A tolerance that DJI might have designed within slipped out of a window somewhere somehow due to a inadvertant IC change.
Sometimes with mixed batchs of a certain "SAME" IC as in the proposed above case, some of them won’t run properly under the exact same or similar code/s that the others do/did during beta testing.
I say this only because I used to work in sustaining engineering and dealt with this a few times in my life. I’m not saying it is happening with DJI specifically, just saying it happens and it’s happened to me a few times.
If this or similar is the case, eng is trying (hence the loooong silence at this point) to indentify what chip/s rev/lot #’s isn't working properly under this and/or the various latest FW’s, how many went out the door and are looking to either re-write the FW so it globally is compatible with all the chips OR…..
Perhaps the chips are simply bad and are too far out of spec and won't run properly under ANY code. In this last case, there most likely is no work-around and they have a BIG problem!! They'll have to recall and replace all of them and someone in purchasing gets fired........
Total guess however, perhaps it's all pilot error.
2018-6-15
Scoobywrx05
Flight distance : 917844 ft
North Idaho Guy Posted at 2018-6-15 06:19
Agreed,
It also could be.........During MA's production runs, their purchasing dept brought in/allowed in IC's that manufacturing ran where the chip changed die’s or something, a rev/production lot numbers changed and a changed happened mid run (hence first run MA's seem ok, mine). A tolerance that DJI might have designed within slipped out of a window somewhere somehow due to a inadvertant IC change.
An engineer friend of mine has run into this problem with some of the things he designs and builds and your assumption about this being the case here is probably correct. They just do not want to say..
2018-6-15
North Idaho Guy
Like I said, IDK for sure, I just write embedded code as a computer/electronics engineer and make a living doing so, I have designed many systems that run on embedded FW and deal with this on occasion as such. Purchasing always has to get a go-ahead (or at least alert design eng) from the designers before changing manu's, lot #'s, date codes, rev's or even vendors in some cases.
The tollkeepers "manu engineering and QA" should have got this stopped  before it even happened, if it happened.
So again, just all guesses guesses, might be nothing, could just be outliers on the bell curve.
2018-6-15
WayneMHK
Agreed,
"Perhaps the chips are simply bad and are too far out of spec and won't run properly under ANY code. .."
Except most of these worked fine before .0400.  Then it's like it gained "reveries" and started having a mind of its own.  It can be more than a little unnerving.
2018-6-15
North Idaho Guy
WayneMHK Posted at 2018-6-15 11:04
Very valid point.......Or they were just simply marginal at best and the new upgrade/new demands on the chips internal resources took them (the proposed suspect devices) over their hairy edge? Stack overflow!! Perhaps even damaging things such that there is no going back........Hmmmm, the plot thickens.
Going backwards(or trying) a rev (and/or viewing chip date codes) c/would  be a tell-tale but, DJI's engs holds that key/answer........Again, just guessing, maybe there isn't an issue at all.
2018-6-15
djiuser_iTYmGJ1Ipw3c
Flight distance : 6766027 ft
Personally I think DJI thinks there's nothing wrong with the 400 firmware and that most of the complaints are due to operator error or possibly some aircrafts that have problems, otherwise they would have done something by now. If they make changes it may not even correct some of the problems people are describing here. I know my MA is a pretty good unit, however I can say that the yaw movement to the left at the start was definitely not there before, and the stability of the aircraft is not the same as with the past firmware. I also believe the camera quality has gone down a bit, I'm getting less sharp pictures than I did with the previous firmware. I still fly my MA and I still feel pretty safe with it, but there are certainly problems that need to be addressed.
2018-6-15
OnlyDarkness
Flight distance : 195371 ft
Argentina
On Tuesday im buying a Mavic Air on Argentina.  Do you guys recommend me not to upgrade the firmware that will come in the drone? Thanks for your help.
2018-6-15
HedgeTrimmer
Scoobywrx05 Posted at 2018-6-15 07:17
Seen a problem with chips having long-term memory failure.  When they were supposed to remember till power down.  Temporary workaround was change OS to update those chips before they forgot.  Final solution replace modules with dementia chips.
2018-6-15
HedgeTrimmer
OnlyDarkness Posted at 2018-6-15 12:51
If you do upgrade firmware, I would not recommend upgrading firmware to .0400 at this time.
2018-6-15
djiuser_7Po6Lb6BFp30
Flight distance : 689334 ft
I AM FROM SOUTH AFRICA, AND THE FIRMWARE LEFT MY DRONE USELESS. THE RC AND MA DOES NOT EVEN CONNECT OR LINK. I HAVE TRIED EVERYTHING POSSIBLE AND READ ALL THE DO,S AND DON,TS ON SEVERAL FORUMS FOR DJI, BUT STILL THE DRONE IS GROUNDED. I AM SICK AND TIRED OF WAITING. WORKED PERFECTLY BEFORE THE UPDATE, SO ROLLBACK OR ANY OTHER FIX NEEDED.....
BS TO PAY FOR A PRODUCT, AND DJI BREAKS THEIR OWN PRODUCT WITH UN WORKABLE SOFTWARE..........
IF IT WORKED FOR YOU, WONDERFUL, BUT I PAID FOR THE PRODUCT, JUST AS EVERYONE ELSE, EXPECT MINE TO FLY AS WELL...................
2018-6-15
cspain
Flight distance : 662644 ft
So the Autel Evo release date was finally announced (there are already YouTube reviews), and just before that the Parrot Anafi was announced (also already reviews out there). Added to that DJI is announcing a new product on  July 18th (https://dronedj.com/2018/06/15/d ... pro-2-announcement/) so I think we are not a priority for them right now.
2018-6-15
Charissa
Anafi looks like a good option if DJI can,t sort out the MA firmware. 21mp camera, more options for photography. True 4k.......
2018-6-16
AirMancer
Turkey
I've been on holiday for 4 days and I was really excited to fly my Mavic Air in this new area. But I was really frustrated when I lost connection with my MA in a 400m distance (I used to reach 3.5+ kms without having any connection issue before upgrading to 400). Dear DJI, if you are listening to your customers' call, either let us roll back to 300 or release the 500 FW update ASAP.
2018-6-16
Scoobywrx05
I DO NOT recommend you even buying one.
2018-6-16
Mr. Commonsense
Flight distance : 45226 ft
EdisonW1979 Posted at 2018-6-5 09:09
Again more meaningless platitudes and insincere apologies, I'm sick of this...
It's obvious you don't care about your customers, given the fact your opening question was answered in the subject line of the post, showing your ignorance and lack of caring, so at the very release re-release Firmware .0300 so we can roll back our drones and start flying again!
Unfortunately companies like this demand transparency from its patrons but refuse to submit transparency themselves....
Personally I am disappointed in dji with their attitude, but as is so very often with big companies they only care about money and profit, not about the legitimate concerns of their customers
2018-6-16
cspain
They're putting out the Mavic 2 on July 18th, so maybe sometime after that?
2018-6-17
HedgeTrimmer
cspain Posted at 2018-6-17 20:04
If that is what is causing problems with getting next version of firmware out, then it won't make any difference after 7/18.   They will be on to something else.
2018-6-17
HedgeTrimmer
Charissa Posted at 2018-6-16 03:45
DJI didn't need to sort out the MA firmware problems.  All they had to do was provide a way to rollback to .0300 or re-issue .0400 stripped of code changes that brought about the problems.  Call it .0410.
2018-6-17
North Idaho Guy
Maybe they scuttled the Air with .400 on purpose? Hmmmm, one way update, take perfomance down a notch or two, shave just a little here and little there, not too much though!! Drag our feet just a bit, let things build up.....And perhaps on the flip side, driving up, just a little, the need for something newer, better, faster. And best of all for DJI, it costs more than the seems now growing ulgier duckling MA. Higher list $$$$$ on new products translates up to the top.
Timing is everything in this game especially with a new building mortgage coming up...........Ahhh just a crazy theory buuuuuut, I wonder, if rev .500 shows up after sales peak and have leveled off on this new flag ship coming, perhaps this theory is not such a stretch after all?......Of course, this is only if there is problem/s with .400
Perhpas there are no problems, oh wait.......Other then the one just an hour ago where my Air, (which I thought was more or less ok) went veerying off to a hard left, normal pre-flight checks and just after take off. Had a full compliment of sats before left the ground, was in GPS mode, no wind and with both perfectly straight forward sticks........No worries though, just slowed down a bit and got off the sticks. Came back around, took same path out, same climb rate etc., etc. and it never happened again.
Just sorta did this on its own though, its never done this before and it took me back a bit........Dang near hit the Harley Davidson dudes tree!!!
So here goes, i'll say it..........I really like the way my MPP flys, I love it...It's sooo smooth and refined, nothing like it, flies like a dream and I want either another one or one just like it or something better, that is now that the MA just ain't cutting it...........SUCKER!!
2018-6-17
Hi all, I understand your concerns, and would like to have more details of the issues you mentioned. With details and data, our engineers can locate the exact reason and see whether it can be fixed by the firmware update or similar. Hope for your understanding.
For those who have troubles of the firmware v01.00.0400, please kindly refer below for further assistance:
1. The main issue you experienced:
2. How often does the issue appear:
3. What troubleshooting you have tried:
4. Issue pictures or video:
5. Corresponding flight logs(if any):
I'll collect regularly and forward to our engineers for review. Appreciate your feedback.
2018-7-12
Airlord
Flight distance : 38048 ft
DJI Susan Posted at 2018-7-12 23:28
DJI kick your Ass and release the 500 whitout Bugs.
The Time is more than over!!!!!!!!
2018-7-12
thebmv
Flight distance : 112940 ft
Belarus
DJI Paladin Posted at 2018-6-5 07:02
As of the moment, DJI is still upgrading our system and we don't have a specific date when our software will be released by our Engineers. We will notify you directly in your app or you can check it directly on our website.
So what is the working model then if there are no specific release dates? You'd better not to tell such things to your direct users)))
That looks like you have 1-2 developers-students who do this as a hobby after hours. Not hopefull at all.
Hope you reconsider your relation to this and will be more specific in future because for now I cannot say that if I knew all this I buy my MA
2018-7-13
TZero
DJI kick your Ass and release the 500 without Bugs.
(Thanks Airlord #74)
2018-7-13
Kapakas
Another month gone with no conclusions. How many flight logs do they need to address the problems and release a new FW?
2018-8-11
HedgeTrimmer
Kapakas Posted at 2018-8-11 15:42
It has only been 100 days................
2018-8-11
MavicEric
Flight distance : 6952 ft
Argentina
It’s a shame. I ran into issues with the firmware and the charger (it doesn’t work and they refused to replace it with a new one though it was a warranty case). This drone is very expensive and Customer Service is terrible. They don’t care about the customer at all. I hope they improve the app as soon as possible. Also, have you tried litchi? Do you recommend it? Thanks
2018-8-11
enriquefc
Flight distance : 1019301 ft
Venezuela
You guys do realize they have a launch of Mavic 2 slated for the 23rd right? We Mavic Air owners will be lucky to get a FW that fixes the .400 issues by December.
They have everyone working on their new flagship product, timing sucked for us, simple as that.
E
2018-8-11
123Next >
