JJBspark
Flight distance : 12686732 ft
Hi deMarco73,
Had a look at your flight, looks OK with no errors etc.
On the chart you see that VPS height 'bump', flying over that harbour "dam" (what is te right english word?)
If the battery drops out than the flightrecord stops, so guess that is the case. If you hit something than you see blocked motors and high pith and roll angles.
So batt eject yes, but that normally happens in sport mode with high speed variations and drone angles. But you did see 2 pieces falling into lake-garda so 99.9 % you know the cause.
Guess DJI will sort this out for you in a good way.
Cheers
JJB |
