KedDK
![](https://forum44.djicdn.com/data/attachment/common/9b/common_15_usergroup_icon.png) First Officer
Flight distance : 1133038 ft
Mike Davies Posted at 2018-7-6 14:51
Its the beginning of summer.... I don't want to be without this drone for the whole summer by sending it back.... This is random, happened 3 times in the last 45 days... There are no ideas as to why this is happening???
You can sync up a flight record from a flight this has happened at and then reply Natalia what flight it is about, then they can examine the record.
With a little luck you can export the same from the aircraft by using Assistant2, it would contain a lot more details for them to investigate from.
I have not have this issue myself on the two P4P's i have had so far, only the last one seem to not be as strong to hold the position on fast moves, specially when testing the Pano feature it looked like it was thrown around during the moves.
Will be waiting with excitement for what replacement i receive on Monday ... ![](//forum44.djicdn.com/static/image/smiley/emoji/1_2x.gif) |
