Gimbal Roll Reached Movement Limit ( Limp gimbal) Mid Flight
6076 24 2018-7-6
Mike Davies
Flight distance : 1288885 ft
I had this happen at least a half dozen times over the last few months. Midflight flying and the gimbal momentarily drops the camera and then autocorrects itself. I know there are others that have experienced this but noone has the answer. Share your knowledge.
2018-7-6
DJI Natalia
Hi Mike, we apologize for the inconvenience this have brought you. Have you tried to calibrate the gimbal before taking a flight? You can also update the firmware to the latest version.
2018-7-6
Mike Davies
DJI Natalia Posted at 2018-7-6 09:07
Hi, Yes... I auto calibrate on almost every flight. As for firmware, I am at V 01.05.0600.
2018-7-6
DJI Natalia
Mike Davies Posted at 2018-7-6 13:03
The firmware is indeed the latest, did this happened after the firmware update or even before? Also did  aircraft experienced hard landing/crash?
2018-7-6
Eric13
Flight distance : 15515515 ft
A common issue. Nothing you can do about it unless you move slower.
Worst for the gimbal - even if the flight is not as fast - is when keeping a center point while flying sideways.
Forget what Natalia said. These seem to be computer generated answers as we have figured by now.
Next question might be what device you are using.
2018-7-6
Mike Davies
DJI Natalia Posted at 2018-7-6 13:15
No, no crash or hard landing
2018-7-6
Mike Davies
Eric13 Posted at 2018-7-6 13:23
lol, I had my suspicions
2018-7-6
Mike Davies
Mike Davies Posted at 2018-7-6 13:40
had same firmware for over a month
2018-7-6
DJI Natalia
Mike, please send us the aircraft for analysis by clicking the link below:
Online Repair Request
We will definitely look unto this for you.
2018-7-6
Mike Davies
DJI Natalia Posted at 2018-7-6 14:06
Its the beginning of summer.... I don't want to be without this drone for the whole summer by sending it back.... This is random, happened 3 times in the last 45 days... There are no ideas as to why this is happening???
2018-7-6
Eric13
Mike Davies Posted at 2018-7-6 14:51
Don't follow Natalias advice. Your drone will be gone for weeks and you might get a refurb as exchange.
There is nothing wrong with your drone other than it reaches its limits occasionally.
Then again reaching these limits I find questionable/bad.
2018-7-6
Mike Davies
Eric13 Posted at 2018-7-6 15:30
Thnx Eric.... as I stated earlier, Im not sending my Phantom away so it can be gone for the summer... I believe this is just a flaw with DJI drones. If I think about it, This usually happens around the same time I get high wind warnings and I believe it is just a stressed motor design from that. It has happened 3 times in the last 45-90 days... I will take my chances. Was just hoping they had a solution up front. I did get an email from DJI support telling me to calibrate it 5 times... Could be just blowing wind up my skirt but I calibrated it 6 times. We will see.
2018-7-6
KedDK
Flight distance : 1133038 ft
You can sync up a flight record from a flight this has happened at and then reply Natalia what flight it is about, then they can examine the record.
With a little luck you can export the same from the aircraft by using Assistant2, it would contain a lot more details for them to investigate from.
I have not have this issue myself on the two P4P's i have had so far, only the last one seem to not be as strong to hold the position on fast moves, specially when testing the Pano feature it looked like it was thrown around during the moves.
Will be waiting with excitement for what replacement i receive on Monday ...
2018-7-7
Mike Davies
AFTER I POSTED THIS, DJI HAD ME CALIBRATE THE DRONE AND THE GIMBAL 5 TIMES (I DID IT 6 TIMES) AND SO FAR THERE HASN'T BEEN A PROBLEM.... I FLEW IT AT A JOB THRU 3 BACK TO BACK BATTERIES AND EVERYTHING IS WORKING GOOD....  I WILL KEEP EVERYONE UPDATED IF THE PROBLEM RETURNS.
2018-7-9
Mike Davies
.............................................................................................. AFTER I POSTED THIS, DJI HAD ME CALIBRATE THE DRONE AND THE GIMBAL 5 TIMES (I DID IT 6 TIMES) AND SO FAR THERE HASN'T BEEN A PROBLEM.... I FLEW IT AT A JOB THRU 3 BACK TO BACK BATTERIES AND EVERYTHING IS WORKING GOOD....  I WILL KEEP EVERYONE UPDATED IF THE PROBLEM RETURNS.
2018-7-9
RedHotPoker
Flight distance : 165105 ft
Mike Davies Posted at 2018-7-9 14:43
You calibrated 6 times, but only posted this last bit twice... ??
Four more... hahaha
RedHotPoker
2018-7-9
Mike Davies
RedHotPoker Posted at 2018-7-9 14:52
My bad...lol
2018-7-9
RedHotPoker
Give you a darn good scolding. Hahaha
We all have those moments, while excitedly posting our feelings. ;-)
RedHotPoker
2018-7-9
Mike Davies
RedHotPoker Posted at 2018-7-9 14:59
........lol
2018-7-9
RedHotPoker
Hehe.
I see what you did there... ;-)
RedHotPoker
2018-7-9
Jimmy hoffa
Flight distance : 1824291 ft
Your gimbal should not do this ....i can zip around in atti mode 60 mph and gimbal does not go limp
2018-7-9
Mike Davies
Jimmy hoffa Posted at 2018-7-9 18:56
agreed... I flew it for an hour straight the next day and it never dropped again... Maybe the calibration was off and it fixed it... We'll see
2018-7-11
Mike Davies
I flew the other day, there were strong winds and the gimbal kept going limp and falling constantly... its just a bad design
2018-8-27
Mark Weiss
That looks like the classic case of gimbal roll while doing a roll movement when in fpv mode. Set the gimbal to follow mode and try doing a roll and see if it cures the problem.
2018-8-27
djiuser_9tZCf781CBaf
Flight distance : 65052 ft
Hi Mike, i have same problem, but i have had one crash with my inspire one dji.
2022-8-9
