Can’t find my drone
705 15 2018-7-23
keysersoze63
Flight distance : 988 ft
I lost contact with my spark, it showed it’s final location on find my drone.
I went to exact location and did an exhaustive search with no luck.
It was on a heavily treed area and my last known coordinates were 124m above ground.
What is the chances it will be close to these coordinates?
What does drone do when it looses contact with controller?
I am a newbie, any help would be appreciated.
David
2018-7-23
Hi, I am sorry to know what happened to your DJI Spark. Since this issue happened the best thing you need to do is to contact DJI Support. Please email DJI Support at support@dji.com. Please indicate what happened to your Drone for further help.
2018-7-23
S-e-ven
Flight distance : 5922034 ft
http://www.phantomhelp.com/logviewer/upload/
upload your log and post the link here
perhaps you can get an idea where to look, after the one or the other checked on your flightrecord!
2018-7-23
wobbles
Flight distance : 547438 ft
if you had it set it should return home at 30 meters ..so should have avoided trees, and in theory be back at homepoint
2018-7-23
Hi. Please sync the flight records of your DJI Spark using your DJI Go 4 application for further assessment on what happened to your Drone.
2018-7-23
wimherman
Flight distance : 208556 ft
Hei,
I had it twice, and the first time i had a little trouble working with the "find my drone" solution. But both times, my drone was exactly on the location indicated in the "find my drone" utility. So its there. But might be in a tree. Can be useful to ask maybe a friend with a drone to help and look from above.  2nd time i had to use "find my drone" it also was in a tree 16 meter above the ground.. took some time to find it. But i did. It was more trouble getting it down though... Good luck!
2018-7-23
keysersoze63
http://www.phantomhelp.com/LogViewer/ISTFEL21D3N5DBMSY0AJ/#
here is the log, in find my drone it showed last location only about half way that log shows?
2018-7-23
keysersoze63
it shows a new ending location but still at a very high altitude...not sure if it would just land straight down?
2018-7-23
N2QLT
Flight distance : 29229 ft
keysersoze63 Posted at 2018-7-23 10:56
Something similar happened to me. I searched the wrong area for almost two days. It's probably somewhere near where the red line ends in the log analysis that you posted. I would start there and continue in the same general direction that the red line was leading. Several people searching in a grid would help. When Mirek6 gets here, he can probably tell you right where it is. Which may be in a tree  :-(
2018-7-23
Alexey Batalov
Flight distance : 24101106 ft
Sorry for your loss man. I lost my first spark a month and a half ago in woods in Russia. I took it up 250mts at night without knowing about the wind, so the wind took it forever away and we could not find it anymore((
Here i bet your drone drifted with the wind and 100% its not going to be where find my drone tells you it is. To be honest find my drone is pretty much USELESS as the ac disconnects from the rc and its bye bye forever drone. Im not taking the chance again and i bought a small gps for the drone that you stick a sim in and it ALWAYS NO MATTER WHAT tells you exactly where it is.
2018-7-23
Alexey Batalov
If the aircraft disconnects from the remote, then the find my drone feature will tell you THE LAST CONNECTION POINT WITH THE REMOTE AND NOT WHERE THE DRONE ACTUALLY LANDED.
2018-7-23
DMX_MT
Malta
Try to Contact DJI on your Case.
It looks Very Genuine, as you pressed the RTH to go Home, the Drone obeyed you as you where in P-GPS but then after few seconds the Drone re entered ATTI and drifted away. This is NOT your Fault. When you pressed RTH you should pretend that the Drone Returns to Home, which it did not. You have a Good Chance here.
This case is not a Pilot Error, but an RTH Failure. It shows that you did try to bring it back when you where in P-GPS Twice, and Twice the RTH has Failed. In both RTH Cases the RTH was initiated and then the Drone lost GPS again and jumped out of RTH into ATTI alone. So RTH is not as Safe as it should be.
Best is to ALWAYS Fly in VLOS and when in doubt or in ATTI best is to land the Drone asap. When you are far away like when the second RTH initiated and you go to ATTI Mode the Drone can get drifting and you won't see where it will end. On the Second RTH it was about 2000ft away.
5m 24.8sP-GPS19satellites382.2ftN/A0.2mph1,833.1ft60%11.236V3.748V3.748V3.74V0.008V
5m 24.9sGo Home19satellites382.2ftN/A0.2mph1,833.1ft60%11.231V3.75V3.745V3.736V0.014VAircraft  is returning to the Home Point. Minimum RTH Altitude is 30m. You can  reset the RTH Altitude in Remote Controller Settings after cancelling  RTH.
Contact DJI Support here - https://www.dji.com/support
First RTH Failure
2m 26sP-GPS18satellites158.5ftN/A0.8mph249.8ft80%11.69V3.904V3.896V3.89V0.014V
2m 26.1sP-GPS18satellites158.5ftN/A0.6mph249.7ft80%11.69V3.904V3.896V3.89V0.014V
2m 26.2sP-GPS18satellites158.1ftN/A0.6mph249.6ft80%11.69V3.904V3.896V3.89V0.014V
2m 26.3sP-GPS18satellites158.1ftN/A0.5mph249.5ft80%11.69V3.904V3.896V3.89V0.014V
2m 26.5sP-GPS18satellites158.1ftN/A0.4mph249.5ft80%11.693V3.903V3.897V3.893V0.01V
2m 26.6sP-GPS18satellites158.1ftN/A0.2mph249.5ft80%11.693V3.903V3.897V3.893V0.01V
2m 26.7sP-GPS18satellites158.1ftN/A0.2mph249.5ft80%11.693V3.903V3.897V3.893V0.01V
2m 26.8sGo Home18satellites158.1ftN/A0.2mph249.5ft80%11.693V3.903V3.897V3.893V0.01V
2m 26.9sGo Home18satellites158.1ftN/A0mph249.6ft80%11.693V3.903V3.897V3.893V0.01VAircraft  is returning to the Home Point. Minimum RTH Altitude is 30m. You can  reset the RTH Altitude in Remote Controller Settings after cancelling  RTH.
2m 28.9sGo Home18satellites158.1ftN/A3.8mph252.2ft80%11.606V3.868V3.873V3.865V0.008VSpeed Error
2m 30.5sGo Home17satellites158.1ftN/A7.0mph244.8ft80%11.673V3.898V3.892V3.883V0.015VYaw Error
2m 30.6sATTI17satellites158.1ftN/A7.0mph244.0ft80%11.673V3.898V3.892V3.883V0.015VCompass Error. Exit P-GPS Mode; Yaw Error
2018-7-23
MarkMN
Flight distance : 77100 ft
You had 48% battery when you lost contact. I'd say it drifted on the wind in the same general direction it had been moving for another 4-5 minutes, then when the battery became critically low it started to land.
2018-7-23
keysersoze63
DMX_MT Posted at 2018-7-23 12:35
thanks for looking, i have reached out to dji, apparently they are reviewing it. I will see.
2018-7-23
DMX_MT
Malta
keysersoze63 Posted at 2018-7-23 12:45
Good luck Buddy. I wish they can help you and supply you with a New Drone !
Keep us updated with the outcome, if you have time.
2018-7-23
keysersoze63
DMX_MT Posted at 2018-7-23 12:47
Thanks, i will update for sure, these forums are awesome, really appreciate everyone's help.
2018-7-23
